New Block Construction Question(s) - Construction - Contractor Talk
Old 05-14-2013, 09:02 AM   #1
TLHWindows's Avatar
Trade: Windows Doors Siding Hurricane Shutters
Rewards Points: 734
I'm not sure were to exactly put this, but the construction thread seemed reasonable.
Ok, so 13 years installing windows and I've never actually installed windows in a new construction Block building. Many installs in existing block, replacing windows, never new.
So a couple of questions:
Does block construction get a water proof barrier (a wrap like wood construction) before stucco goes up? I am assuming they are using synthetic stucco since that is the most common around here.
I've seen a few details for flashing the sill, but not the sides or headers. The windows we use call for silicone along the outside flange as they are mounted (these are vinyl flanged windows, not finned windows going over 2x6's). I don't know if it is normal to wrap the 2x's with tape before the window goes in?
Or if there needs to be a top flashing detail normally.
Yes, I have asked the local inspectors, but its like pulling teeth and I am waiting on a reply. Just trying to see what is common for people.
Adding a picture, except that we will be using 2x material
Thanks
Cool, lets put some fabric over a window and let a hurricane throw some stuff at it. I'm sure it will protect you and your windows.
http://www.gulfbreezewindows.com
TLHWindows is offline
Old 05-22-2013, 01:02 PM   #2
Florida GC
olligator's Avatar
Rewards Points: 250
Re: New Block Construction Question(s)
The inspectors down here are anal about getting some silicone underneath the bucks and on the exterior-facing gaps between the bucks and the masonry and that's about it. I haven't seen anyone do flashing for a new construction masonry installation like what you pictured. The justification is that the bucks are PT and if the stucco is applied and sealed properly, you should be fine. If you do any flashing at all it should be for the sill.
Here's an article I read at Building Science about moisture issues in Florida; There's a section in it about rainwater intrusion from sills on impact window installs that might give you some extra insight on the best way to flash the sill for your particular install.
article: http://www.buildingscience.com/docum...chterm=florida
Check the sections around Figures 3a and 3b
______________
If you're not a Gator, you're Gatorbait!
olligator is offline
The Following User Says Thank You to olligator For This Useful Post:
NeilRoss (05-23-2013)
Old 01-31-2014, 01:42 AM   #3
Kickler's Avatar
Not very familiar with block construction and window/door installation. However, in West and South Florida, I have seen the perimeter of the rough opening flashed with a white compound approximately 4" from the opening. Any insight into this?
Kickler is offline
If you're not on Facebook, you should be. Sir Mixalot Marketing & Sales 1854 02-24-2019 04:59 PM
Building with Adobe as a Cost Effective Solution for Home Construction? tierraconcepts Green Building 14 09-19-2015 05:52 PM
Roofing new construction LeeFowler Roofing 20 12-20-2012 07:50 PM
Commercial Contract / Lien questions PierceIdaho Business 1 10-26-2012 02:56 PM
Hello Out there in construction world contractorguy New Member Introductions 1 12-16-2010 04:42 PM
