My Increasing Interest In Forming. - Page 7 - Construction - Contractor Talk
Old 09-21-2011, 06:01 PM   #121
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
Re: My Increasing Interest In Forming.
Originally Posted by Chris Johnson View Post
Building a basement, which side of the wall does the rebar go on? This is a trick question or loaded question, research it and give me the answer and tell me why
it goes in the centre?
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Old 09-21-2011, 06:59 PM   #122
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
No...research it
Chris
Chris Johnson is offline
Old 09-21-2011, 08:41 PM   #123
J.C.'s Avatar
Rewards Points: 242
A good part of the answer has already been mentioned in a post within the first 30 posts of this thread. What is concretes strength and what is it's weekness? Where should the steel go based on the type of stresses on the concrete?
I do not prize the word "cheap." It is not a badge of honor...it is a symbol of despair. Cheap prices make for cheap goods; cheap goods make for cheap men; and cheap men make for a cheap country. ~ William McKinley
J.C. is offline
Old 09-21-2011, 08:59 PM   #124
Forming and Framing
FramingPro's Avatar
it goes inside the concrete
hmm.
I will take a guess, for i cannot find anything. I always thought it goes in the centre. I would say it goes on the inside so that it puts the outside of the wall in tension to hold the dirt back better also having it on the inside protects it from groundwater and soil. Must be covered with 1 1/2" min on the inside and 3" out
Old 09-21-2011, 09:20 PM   #125
I'm a Mac
Close....
It goes on the inside based on there being something holding the top of the wall i.e. Floor System creating a diaphragm and helping evenly disperse pressure around to the other walls. Everything is working together and the rebar cannot or does not have the ability to stretch as much since it is further from the pressures of the backfill.
If nothing is supporting the top of the wall the rebar goes to the soil side and the footing is enlarge with a bigger portion to the inside (non backfill) to prevent the wall from tipping or pushing.
And since we have the advantage of the ICF form, coverage is only 3/4" min. (Both inside and outside) this allows aggregates to get in that area and the ICF gives us the balance of coverage.
Chris
Old 09-21-2011, 09:25 PM   #126
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Originally Posted by Dirtywhiteboy View Post
36DD
I feel a motor boat coming on!
CrpntrFrk is offline
Old 09-21-2011, 09:25 PM   #127
CrpntrFrk's Avatar
You gonna take the job kid or what?
Old 09-21-2011, 09:29 PM   #128
I'm a Mac
Okay...next...what are the 3 S's in concrete?
1 - S-------
2 - S-------
3 - S-------
And why do I think in about 4 hours DirtyWhiteBoy will be posting a new pic and a comment?
Chris
Old 09-21-2011, 09:30 PM   #129
I'm a Mac
1 - S-------
2 - S-------
3 - S-------
Chris
Old 09-21-2011, 09:46 PM   #130
J.C.'s Avatar
Rewards Points: 242
Close....
The way it was explained to me is, once you backfill, the outside of the wall is under compression and the inside of the wall is under tension. Just like when you load a floor joist. The top of the joist is under compression, the bottom is under tension. Concrete has great compressions strength, not such much tensile strength. So, you want to put your rebar towards the inside side of the wall.
J.C. is offline
Old 09-21-2011, 09:48 PM   #131
I'm a Mac
your right, provided the top is supported.
You should see lintel details above openings, depending on the span and load it's carrying plus the width and height of it dictates bar size and stirrup spacing. I did a 34' clearspan beam, 6" core, 42" high with 2 #11 bottom bars, 40d splice (call it 4' splice), #5 @ 18" o.c.H and Stirrups #4 @ 6" o.c.V, 12' from each end. The #11 just about killed me, second floor sliding them in from the outside and the splice was ridiculous consolidating it.
Chris
Old 09-21-2011, 09:54 PM   #132
J.C.'s Avatar
Rewards Points: 242
That is interesting about walls with no top support. I never really thought about it and never heard anyone discuss it.
J.C. is offline
Old 09-21-2011, 10:38 PM   #133
Dirtywhiteboy's Avatar
Rewards Points: 5,162
Nope, I not gonna touch that one. By the way I was as lost as Nick on that 36D stuff so all I could come with was Ayna And no there not Ds they are DD I've asked her bout em
Dirtywhiteboy is online now
Old 09-22-2011, 09:18 AM   #134
Forming and Framing
FramingPro's Avatar
1 - S-------
2 - S-------
3 - S-------
The 3 s's are the exposure to sulfate classifications
S1 (Moderate)
Soil: 0.10% ≤ SO4 < 0.20%
Water: 150 ppm ≤ SO4 <1500 ppm (and Seawater)
S2 (Severe)
Soil: 0.20% ≤ SO4 < 2.0%
Water: 1500 ppm ≤ SO4 <10,000 ppm
S3 (Very severe)
Soil: SO4 > 2.0%
Water: SO4 >10,000 ppm
SO4 is sulphate
Old 09-22-2011, 09:21 AM   #135
Forming and Framing
FramingPro's Avatar
d represents the diameter of rebar in the eqaution that will give you the minmum splice in my area when you multiply it by 36, for you and others such as in cali its 40d
eg.
#4 rebar is 1/2"
40 times .5 = 20" minumum lap on #4 rebar
The Following User Says Thank You to FramingPro For This Useful Post:
Dirtywhiteboy (09-22-2011)
Old 09-22-2011, 10:30 AM   #136
I'm a Mac
Stone size
Slump
Spacing of trucks
Chris
Old 09-22-2011, 10:31 AM   #137
I'm a Mac
And how are you replying to threads during school hours?
Chris
Old 09-22-2011, 10:33 AM   #138
I'm learning a lot on this thread
Old 09-22-2011, 10:52 AM   #139
Forming and Framing
FramingPro's Avatar
Stone size
Slump
Spacing of trucks
oh. well i gave you an alternate
my school has computers, i have construction class
Old 09-22-2011, 04:50 PM   #140
I'm a Mac
Me too...Like when I get to Hawaii I need to find Ice Coffee really quick
Chris
The Following User Says Thank You to Chris Johnson For This Useful Post:
no payment, no interest for 1 year contractorjay Business 6 05-24-2011 12:51 PM
What tools does everyone carry for forming mw31 Concrete & Paving 7 12-27-2010 11:12 AM
Boral USA Acquires Entire Interest in MonierLifetile LLC Grumpy Roofing 0 08-12-2010 09:17 AM
Forming a cap slab BSCi Construction 4 02-12-2010 03:40 PM
Tidy forming EPD Construction Picture Post 6 02-09-2010 11:47 PM
