My Increasing Interest In Forming. - Page 15 - Construction - Contractor Talk
Old 12-04-2011, 03:40 PM   #281
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
Re: My Increasing Interest In Forming.
Originally Posted by J.C. View Post
4" thick round walls, flat roof and a cut out for a doorway.
keep in mind its only 18" sqaure. so 4" might be kinda beefy.
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Old 12-04-2011, 03:43 PM   #282
J.C.'s Avatar
Rewards Points: 242
Ohh, you're killing me. 2-3" thick round walls, flat roof and a cut out for a doorway. I'm out of ideas after that.
I do not prize the word "cheap." It is not a badge of honor...it is a symbol of despair. Cheap prices make for cheap goods; cheap goods make for cheap men; and cheap men make for a cheap country. ~ William McKinley
J.C. is offline
Old 12-04-2011, 03:44 PM   #283
Forming and Framing
FramingPro's Avatar
i was thickening like on the second floor deck have a round cantilever with concrete braces going down into the columns but.
i want something round though so hmm
Old 12-09-2011, 06:17 PM   #284
Forming and Framing
FramingPro's Avatar
today i went to work. Started off placing bar and what not. Concrete came..... poured had a few blows outs, when they poured the one part the concrete had been sitting in the pump so it was wet and the end of a block just blew out. and then in the windows the endcaps popped. Sure isn't a good feeling to be standing right in front of a wall as it blows out.
there was a some film crew for a promotional video on green construction or something. the filmer didn't want to come up on the tall walls so i built a little model wall and poured it...
i was supposed to crouch so it looked like a tall wall
My increasing interest in forming.-img_9761.jpg   My increasing interest in forming.-img_9764.jpg   My increasing interest in forming.-img_9766.jpg   My increasing interest in forming.-img_9769.jpg   My increasing interest in forming.-img_9770.jpg
Old 12-09-2011, 06:35 PM   #285
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
That wasn't a blow out...that was a minor movement of foam, anything you repair in under a couple minutes is nothing
Chris
Chris Johnson is offline
The Following User Says Thank You to Chris Johnson For This Useful Post:
Dirtywhiteboy (12-09-2011)
Old 12-09-2011, 06:38 PM   #286
Forming and Framing
FramingPro's Avatar
it got resolved quickly but it just blew. at the window and beside it a piece just snapped off the end of a block.
did you not need help on senlac site? Monday and tues after skool if i am needed. i will be there
Old 12-09-2011, 08:45 PM   #287
Forming and Framing
FramingPro's Avatar
if your looking at the pics then yes that was minor , but i don't think you were there when the wall popped. a bit more then minor movement
Old 12-09-2011, 09:33 PM   #288
tgeb's Avatar
Rewards Points: 886
Don't be a sissy.....
www.gebcon.com
tgeb is offline
The Following User Says Thank You to tgeb For This Useful Post:
Mud Master (01-25-2012)
Old 12-12-2011, 09:47 PM   #289
mw31's Avatar
Trade: Concrete/Masonry
Rewards Points: 75
Also to be considered a blowout there has to be over a yard of concrete on the ground.
mw31 is offline
Old 12-12-2011, 10:21 PM   #290
Forming and Framing
FramingPro's Avatar
What i meant by blow out is not represented in the pic. It actually blew out. 1 of the blocks.. 1/2 metre lost probably.
Old 12-28-2011, 04:23 PM   #291
Forming and Framing
FramingPro's Avatar
your right, provided the top is supported.
You should see lintel details above openings, depending on the span and load it's carrying plus the width and height of it dictates bar size and stirrup spacing. I did a 34' clearspan beam, 6" core, 42" high with 2 #11 bottom bars, 40d splice (call it 4' splice), #5 @ 18" o.c.H and Stirrups #4 @ 6" o.c.V, 12' from each end. The #11 just about killed me, second floor sliding them in from the outside and the splice was ridiculous consolidating it.
What does all this mean? I get the stirrups and stuff but hats this V and H mean
Old 12-28-2011, 04:44 PM   #292
I'm a Mac
H - Horizontal
V - Vertical
Chris
Old 12-28-2011, 05:47 PM   #293
Forming and Framing
FramingPro's Avatar
H - Horizontal
V - Vertical
imagine that
The Following User Says Thank You to FramingPro For This Useful Post:
Dirtywhiteboy (12-28-2011)
Old 12-29-2011, 07:34 PM   #294
Forming and Framing
FramingPro's Avatar
today..
i worked with the 2 other guys and helped install the insul decking and shoring, I tied a fair bit of bar. I know that i would not enjoy being a robuster . Tomorrow is pour day. Maybe ill get to pour some
yea,
these decks are gonna be covered in limestone and be the roof over the section below. Its gonna be interesting to see how they waterproof this
My increasing interest in forming.-img_9816.jpg   My increasing interest in forming.-img_9817.jpg   My increasing interest in forming.-img_9820.jpg
Old 01-25-2012, 05:36 PM   #295
Forming and Framing
FramingPro's Avatar
Originally Posted by JustaFramer View Post
Your beams should terminate on top of the columns. A d your slab on the top of the columns is to thin. 1" of concrete is not structural enough. Next time instead of nails or rebar try chicken wire it should be enough to demonstrate what would happen.
i had the deflection rating of a 2" slab but the shear rating of a 1"
JustaFramer (01-30-2012)
Old 01-30-2012, 01:28 AM   #296
JustaFramer's Avatar
Trade: Exiled For Life
Rewards Points: 2,000
You need to get yourself this book. Maybe get Chris to buy it for you on a condition of employment.
JustaFramer is offline
Old 01-31-2012, 05:02 PM   #297
Forming and Framing
FramingPro's Avatar
right now im reading concrete formwork third edition by leonard koel.
Its odd. all my books out from the library are about concrete. FHB foundation book and what not.
By no means have i lost interest in framing its just now i have read all the framing books and get them so..
Old 01-31-2012, 10:20 PM   #298
Dirtywhiteboy's Avatar
Rewards Points: 4,720
Hey Nick isn't it all framing but now you're framing boxes for giving concrete shape. It is all important parts of building
Dirtywhiteboy is offline
Old 01-31-2012, 10:25 PM   #299
Forming and Framing
FramingPro's Avatar
i guess so. concrete forming is just interesting to me.
Its like framing but after you pour concrete you wreck it.
I don't like demo. but pouring concrete is always exciting.
Old 02-04-2012, 12:24 PM   #300
Forming and Framing
FramingPro's Avatar
what is pencil rod and how do you use it as form ties..
Im reading in my forming book that if you need to form an irregular section of wall you can use pencil rod and bolts. I guess you just drill holes. put the rod in and put big washers. of course using a spacer?
no payment, no interest for 1 year contractorjay Business 6 05-24-2011 12:51 PM
What tools does everyone carry for forming mw31 Concrete & Paving 7 12-27-2010 11:12 AM
Boral USA Acquires Entire Interest in MonierLifetile LLC Grumpy Roofing 0 08-12-2010 09:17 AM
Forming a cap slab BSCi Construction 4 02-12-2010 03:40 PM
Tidy forming EPD Construction Picture Post 6 02-09-2010 11:47 PM
