Moving Building Several Feet - Page 2 - Construction - Contractor Talk
Old 01-01-2019, 01:00 PM   #21
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,556
Re: Moving Building Several Feet
Originally Posted by dayexco View Post
got to looking at this again.
see there's only 12 foot sidewalls on that building. were it me moving it for myself, i'd figure out a way when i sat it down, to add 4' to bottom.
the day will come you're going to want to park a trailer, motorhome, etc. in there and need 14' min. doors and sidewalls. plus along sidewalls you have enough height to put in a mezzanine to give you storage on ground level, and one level up.
Really looks to be more like 14' tall now. Also looks like must be an overhead door on each end. Not it makes much difference in how to move it .
Randy Bush is online now
Old 01-01-2019, 01:19 PM   #22
dayexco's Avatar
Rewards Points: 30
on that endwall pic, i'm assuming those girts are 2' apart? 12' door?
dayexco is offline
Old 01-01-2019, 01:35 PM   #23
Randy Bush's Avatar
My take too, but then another 2' above the door, thus guessing side walls are 14'. door on the opposite end looks to be a 10' from outside picture.
Old 01-01-2019, 09:26 PM   #24
JAH's Avatar
Trade: carpenter
Rewards Points: 1,910
I see 3 options.
1- Build a new foundation & walls. Then have a crane move the roof. If the roof is to big, cut it in half.
2- Disassemble & relocate.
3- Burn it.
JAH is offline
Old 01-02-2019, 04:48 PM   #25
Lettusbee's Avatar
Rewards Points: 906
Ok.
Keep wall on left in place.
Deskin all metal on walls.
Place new posts to left of original wall, at perfect location to land gable truss roof system on.
Decouple roof. Boom it over with big ass crane, landing on original left wall, which is now the right wall, and landing on new left wall.
Put wall metal back on.
Leave original slab and original right hand posts for disgruntled property owner to deal with.
Lettusbee is offline
Old 01-02-2019, 08:17 PM   #26
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 13,882
Originally Posted by dave_dj1 View Post
which way does it have to be moved? Can you simply take one end off and add it to the other end?
If concrete slab is an option, cut the posts at the bottom of siding, move entire building onto a slab with proper post bases bolted in, easy peasy.
Edit: I see it has to go sideways, should be easy enough as described above. Who put the property stake there? Maybe have it surveyed?
That was my idea as well. Set it on post brackets
A&E Exteriors is online now
Old 01-02-2019, 10:00 PM   #27
tgeb's Avatar
Rewards Points: 1,104
You really need to do some leg work and find out what the issue is with the property. By searching the pics you posted I found the listing.
In 2 years the price of that property has gone down by more than 50%
12/28/2018 $52,500
1/13/2017 Sold $123,000 -- $100 Public Record
Looking at the satelite view, I don't see enough room to move that closer to the house, most zoning won't allow a building that close, but you won't know until you ask them.
www.gebcon.com
tgeb is online now
The Following 4 Users Say Thank You to tgeb For This Useful Post:
dayexco (01-03-2019), griz (01-02-2019), mrcat (01-03-2019), Rio (01-04-2019)
Old 01-03-2019, 09:36 AM   #28
dayexco's Avatar
Rewards Points: 30
12/28/2018 $52,500
1/13/2017Sold$123,000--$100Public Record
Here, by looks of that pic, he'd have trouble getting permit for yard shed
Sent from my SCH-I545 using Tapatalk
dayexco is offline
The Following User Says Thank You to dayexco For This Useful Post:
tgeb (01-03-2019)
Old 01-03-2019, 07:05 PM   #29
test
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 874
reminded me of this story.
http://www.aaron.ca/columns/2009-08-29.htm
I've worked with Rick Michaels before. Specializes in "special permits" for home owners now.
He isn't cheap.
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is online now
Old 01-03-2019, 07:32 PM   #30
TheConstruct's Avatar
Rewards Points: 1,166
He isn't cheap.
I remember reading about that too. Absolutely insane
TheConstruct is offline
Old 01-03-2019, 07:40 PM   #31
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,713
Just thought I'd mention that the property was taken off the market Jan 3. So one way or the other, this horse is probably dead. :
Tinstaafl is offline
tgeb (01-03-2019)
Old 01-03-2019, 08:01 PM   #32
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 6,462
Pole buildings rely on the poles being set into the ground for lateral strength. You'd have to re-engineer, add shear, etc.
Golden view is offline
griz (01-03-2019)
Old 01-03-2019, 08:02 PM   #33
I understand that
The Following User Says Thank You to A&E Exteriors For This Useful Post:
Golden view (01-03-2019)
Old 01-03-2019, 08:07 PM   #34
edward trowelhands
Trade: Diplomat
I understand that
I always figured there must be more of a reason than I understand for this. I'd rather have extra cost for shear bracing so I could have the pole bottom elevated so it would last longer. I suppose pole barns are all about lowest cost to build. Plus those poles are generally surrounded by a slab and stay pretty dry, so odds are they are going to last a very long time anyway.
Old 01-03-2019, 08:21 PM   #35
tgeb's Avatar
Maybe Kowalski picked it up. You can't find a house that cheap around here.
www.gebcon.com
tgeb is online now
The Following User Says Thank You to tgeb For This Useful Post:
Tinstaafl (01-03-2019)
Old 01-03-2019, 08:58 PM   #36
Lettusbee's Avatar
Rewards Points: 906
Check out this guys videos on Pole Barn Building:
Piers and Brackets, Braces throughout the construction, but not permanent.
Old 01-04-2019, 01:07 PM   #37
rblakes1's Avatar
Rewards Points: 3,344
That is a huge framing gun
rblakes1 is offline
Old 01-04-2019, 02:40 PM   #38
Randy Bush's Avatar
Thing is the slab should not be tight to the poles, have seen where the slab moved and pulled the poles down with it. This was in a case where coils of roof metal was stacked at the out walls.
Old 01-04-2019, 03:49 PM   #39
Lettusbee's Avatar
Rewards Points: 906
For shooting huge nails.
Old 01-04-2019, 04:18 PM   #40
edward trowelhands
Trade: Diplomat
https://www.youtube.com/watch?v=6JzNAhNDQGo
I see that. Near the end he says the steel provides all the shear needed.
Lettusbee (01-04-2019)
Why Haven't These Buildings Toppled? Tim Garrison PE Framing 99 11-10-2009 09:25 AM
Joasis (and others) how much would this building cost in your area? Mike Finley Construction 8 09-15-2008 02:51 PM
??? Whats the best way to spread the news about your company? jmgrahamjr Marketing & Sales 21 06-24-2008 03:46 AM
Certified Green Building Professional Training CatAlii Green Building 6 05-11-2008 03:20 PM
