Moisture Proofing Sill Plate Near Most Vulnerable Areas - Construction - Contractor Talk
Old 11-24-2018, 07:26 PM   #1
smit2018's Avatar
Trade: plumber
Rewards Points: 40
Hi,
I am working on finishing a basement and would like to make sure the sill plates are mositure proof especially the ones which are closer to drainage pipes as they are most vulnerable in case if pipes break there.
Any ideas on ways to moisture proof the sill plates from inside,any metallic flashings available in market that will help seal the sill plates before patching with dry wall?appreciate your input
Thanks
smit2018 is offline
Old 11-24-2018, 07:42 PM   #2
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 1,456
Re: Moisture Proofing Sill Plate Near Most Vulnerable Areas
Are your sill plates below grade?
Why would they be close to footing drains?
Wait....
What??????
I just re-read your post. Now I"m really confused.
Footing drains? Or just crappy plumbing work, where waste lines routinely break?
I'm not understanding.
Old 11-24-2018, 08:06 PM   #3
Tom M's Avatar
Rewards Points: 10,748
Maybe he's worried about sills on the floor of new wall framing.
Just use treated and leave an air space behind the wall
Tom M is online now
greg24k (11-25-2018)
Old 11-24-2018, 08:18 PM   #4
smit2018's Avatar
Trade: plumber
Rewards Points: 40
Apologies if I was not clear, I am talking about the wooden framing that rests on top of the concrete foundation and there is a drainage pipe from kitchen and laundry from the floor above.The drainage pipe can potentially break for many different reasons so I was wondering if it makes sense to somehow waterproof that wooden framing in that particular area where there is a drainage pipe.
Last edited by smit2018; 11-24-2018 at 08:20 PM. Reason: to better articulate the problem statement
smit2018 is offline
Old 11-24-2018, 08:26 PM   #5
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 17,773
Don't worry about it. If there were ever a leak to repair, the sill plates would dry out and survive just fine.
MarkJames is online now
Old 11-24-2018, 08:44 PM   #6
smit2018's Avatar
Trade: plumber
Rewards Points: 40
I am just trying to be overly careful here ,I had a customer friend in the past and unfortunately for him a leak went undetected for almost an year and the wooden framing above the concrete slab in his basement got rotted out due to the incessant water leak,which can potentially create structural issues, so just want to err on the cautious side before finishing the basement.
smit2018 is offline
Old 11-24-2018, 10:36 PM   #7
Jay hole's Avatar
Trade: General contractor
Rewards Points: 1,507
Be careful when you say something like “water proof”. It can get you in trouble!!!
Jay hole is online now
The Following User Says Thank You to Jay hole For This Useful Post:
hdavis (11-24-2018)
Old 11-25-2018, 09:16 AM   #8
General Contractor
greg24k's Avatar
Rewards Points: 7,802
Use PT lumber, most PT now is rated with ground contact so you don't have to worry about water either way.
greg24k is offline
Old 11-25-2018, 11:04 AM   #9
PNW Painter's Avatar
Trade: Painter
Rewards Points: 68
The most cost effective route is using PT lumber. Beyond that you’re probably overthinking it.
PNW Painter is online now
Old 11-25-2018, 11:40 AM   #10
smit2018's Avatar
Trade: plumber
Rewards Points: 40
Thanks lumber is already in place,should I replace it with PT lumber?sorry
I am confused.My perception about wood is its like a blotting paper and it can wick moisture quickly during plumbing incidents(I could be wrong here) so I am considering somehow waterproof that area before finishing the basement with drywall.
smit2018 is offline
Old 11-25-2018, 12:03 PM   #11
hdavis's Avatar
Rewards Points: 2,810
This is an exercise in futility. Any waterproofing you do will trap any moisture that gets past your barrier.
hdavis is online now
Fouthgeneration (11-25-2018), Rio (11-25-2018)
Old 11-25-2018, 12:06 PM   #12
hdavis's Avatar
If you want to replace it all with ground contact rated pt, go for it. Don't forget HDG or stainless fasteners.
Old 11-25-2018, 02:02 PM   #13
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 7,635
Never "trap the RAT of water vapour" in the porous materials, wood, masonry, whatever, the water seeks the path of least resistance, thus leave an wide open exit path whenever possible.
Two water barriers never have a happy ending on the same wall, floor, or roof.
When lapped vapor barriers need to gravity flow to DAYLIGHT(or a sump pump to day light), like a shingle roof.
No porous material between the W.Barriers.
If your are truly anal, jack the house & sill up an 1/8th of inch and insert some metal or plastic vapor barrier on top of the out gassing foundation wall, If there isn't any there.
Fouthgeneration is offline
Attaching a non-bearing wall sill plate to a post tension slab? TimberlineMD Framing 13 07-01-2013 03:31 PM
No sill plate? wtf mastersplinter Framing 35 12-24-2012 05:19 PM
Rotted sill plate and broken joist repair netlinks Framing 0 07-18-2012 10:24 PM
Sill plate on outer walls? sout101 Framing 21 04-13-2012 09:12 AM
High moisture in slab, moisture barrier or not for travertine? eezeekial Tiling 20 11-22-2011 08:03 PM
