LVL Beams Vs Built-up Dimensional Lumber - Construction - Contractor Talk
Old 06-13-2011, 11:18 AM   #1
Invikta's Avatar
Trade: Designer
I am trying to figure out what sort of LVL beam I should order for the construction of my house.
It is a bi-level split with a half second story. On the main floor I was going to build up 3 2x12s for a 36' long beam (supported about every 10' by 3 1/4" lally columns) with 2x10 joists running 14' lengths on one side (16" OC) and 12' lengths on the other side (total floor is 26' x 36'). What kind and dimension of LVL beam should i choose as an alternative to this built-up beam - and what dimension i-beam joist should I choose instead of the 2x10s?
The second floor is also currently planned to have a same beam and joist configuration (total floor is 20' x 26') - here I was going to run the beam laterally (that is 26' long - with 10' long 2x10 joist on either side). I assume the same type of LVL and ibeams will work for the second story?
Any help would be appreciated.
Invikta is offline
The Following User Says Thank You to Invikta For This Useful Post:
Michael396 (07-10-2011)
Old 06-13-2011, 11:26 AM   #2
Kent Whitten's Avatar
Rewards Points: 2,040
Re: LVL Beams Vs Built-up Dimensional Lumber
Before I close the thread, I want to make sure that you understand that the questions you are asking are indicative of being way over your head. Structure is nothing to mess with. Go to the lumber yard and they will help set you up and point you in the right direction.
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
SalmonFallsCabinetry.com
Kent Whitten is offline
Whats The most expensive deck you've built deck king Decks & Fencing 96 07-10-2010 08:02 PM
Best Lumber for Trellis LaurieC Carpentry 25 02-12-2010 05:26 AM
PT Lumber variants wallmaxx Framing 7 10-04-2009 09:47 AM
lumber distortion Scott Young Decks & Fencing 2 04-09-2006 10:32 AM
