Lifting Beams - Page 2 - Construction - Contractor Talk
Lifting Beams
Old 04-28-2011, 06:14 PM   #21
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,030
Re: Lifting Beams
Originally Posted by greg24k View Post
He would need a dolly like this, it has adjustable side plates, you can spread them from 0-9" and you can turn that dolly on the dime...easy to move across the lawn and it will not mar the floor.
Were the F did you find that, I WANT ONE!!!!!!!!
festerized is offline
Old 04-28-2011, 06:17 PM   #22
David Festa
festerized's Avatar
Re: Lifting Beams
Originally Posted by Aggie67 View Post
Add a leverage arm and remove the axle, and you have a Grasshopper. It'll fit through a 35 inch door jamb.
+ YouTube Video
That device looks like trouble
Old 04-28-2011, 06:29 PM   #23
Structural Engineer
Aggie67's Avatar
Trade: Mechanical, Structural
Re: Lifting Beams
Originally Posted by festerized View Post
[YOUTUBE]http://youtu.be/CpAJOPzKK-M[/YOUTUBE]
I surf fish quite a bit, and I've seen a guy at IBSP a couple times that uses one of those things to launch his bait.
Aggie67 is offline
Old 04-28-2011, 06:32 PM   #24
David Festa
festerized's Avatar
Re: Lifting Beams
Or to scare the Benny’s away
Old 04-28-2011, 06:33 PM   #25
Structural Engineer
Aggie67's Avatar
Re: Lifting Beams
Surf cannon
http://www.youtube.com/watch?v=-6tB0...1&feature=fvwp
Aggie67 is offline
Old 04-28-2011, 08:06 PM   #26
General Contractor
greg24k's Avatar
Rewards Points: 8,110
Re: Lifting Beams
Trojan DC-9 Dolly-Cartin' 2 Wheeled Clamping Cart Unit with 9-Inch Clamping Capacity on Amazon.com $131
greg24k is offline
festerized (04-28-2011)
Old 04-28-2011, 09:18 PM   #27
General Contractor
Willie T's Avatar
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Rewards Points: 12
Re: Lifting Beams
I made something similar to move my kayaks. (See the photo.) Works well in open, flat spaces, but it turns out the center pivot point is really a pain in close quarters with only a 16' long kayak... and forget steps.
The ends of the kayak (or beam?) hit at both the front and the rear before the wheels reach the steps. And this is with the cart carrying the kayak way up high at about 20" off the ground.
The hassle with a center pivot is that if you need the front to go left, the rear has to go right at the same time and for the same distance. So it's impossible to come down a hallway and even begin a turn through a doorway or around a fairly tight corner.
Fortunately my heaviest kayak weighs only 65 pounds, and I can muscle it. Not sure I could do that with a 28 foot long, 1,120 pound "I" beam.
(Besides, my little plastic "Barbie Jeep" wheels might not hold it.)
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is offline
Old 04-29-2011, 12:41 AM   #28
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 496
Re: Lifting Beams
The beam buddy
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
Old 04-29-2011, 06:13 AM   #29
tcleve4911's Avatar
Trade: Remodeling contractor
Rewards Points: 1,008
Re: Lifting Beams
Scraps of 6" PVC as rollers and skids.
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 04-29-2011, 07:09 AM   #30
General Contractor
Willie T's Avatar
Rewards Points: 12
Re: Lifting Beams
Do yourself a huge favor and get something with fully pivoting wheels at BOTH the extreme front and back of the beam. Unless you have almost unlimited open and flat areas to transport across, you will positively regret a center pivoting setup... especially for 28'.
Think this through.
Willie T is offline
Fence posts lifting Emo Decks & Fencing 23 05-05-2010 12:57 PM
Free I beams guyute65045 Excavation & Site Work 1 03-07-2010 09:33 PM
Foam beams Trim40 Finish Carpentry 10 01-13-2010 10:07 PM
Rotten Beams - must replace MHMConstruction Remodeling 8 03-05-2007 04:45 PM
Help with painting rough cedar beams jgladdy Painting & Finish Work 9 04-21-2006 03:18 PM
