Leveling My House....Question - Construction - Contractor Talk
Old 05-22-2015, 09:22 AM   #1
TLHWindows's Avatar
Trade: Windows Doors Siding Hurricane Shutters
Rewards Points: 734
My house sits on about 30 block pillers with 2x's running along them.
I am going to level it out, and that is not an issue.
The issue, or question is... what do I shim it with?
I am sure there will be small gaps and some large. Thought about PT ply, but can't get it real thin.
Any ideas would be great.
-Andrew
Cool, lets put some fabric over a window and let a hurricane throw some stuff at it. I'm sure it will protect you and your windows.
http://www.gulfbreezewindows.com
TLHWindows is offline
Old 05-22-2015, 09:32 AM   #2
VinylHanger's Avatar
Rewards Points: 10,018
Re: Leveling My House....Question
I always use the large roofing shingles.
VinylHanger is online now
The Following User Says Thank You to VinylHanger For This Useful Post:
illbuildit.dd (05-22-2015)
Old 05-22-2015, 09:43 AM   #3
Dan_Watson's Avatar
Rewards Points: 2,594
We use steel shims. But are not near the water.
I would use galvo steel shims and then mortar them in.
Dan_Watson is offline
The Following 3 Users Say Thank You to Dan_Watson For This Useful Post:
festerized (05-22-2015), greg24k (06-08-2015), hdavis (06-02-2015)
Old 05-22-2015, 09:47 AM   #4
House surgeon
illbuildit.dd's Avatar
Trade: building/remodeling
Rewards Points: 2,078
Or cut your own shims different sizes from pt using a circular saw
illbuildit.dd is offline
Old 05-22-2015, 09:51 AM   #5
madmax718's Avatar
Trade: General
Rewards Points: 3,272
If you can actually level it out, and the heights are that small, you can probably either rip some PT shims and coat it with the green copper stuff for added protection.
You can also get metal shims at your local truck shop (they are used to shim axles). Aluminum ones will resist rusting better. If only steel available, scuff it up, and use cold galvanizing spray.
you could also probably use cement, just depends on the height difference, you may want ones without stone aggregate.
madmax718 is offline
Old 05-22-2015, 10:08 AM   #6
TLHWindows's Avatar
Rewards Points: 734
Thanks for the suggestions.
I'll look into some plates and fall back to cutting down PT wood if I have to.
Old 05-22-2015, 10:26 AM   #7
Philament's Avatar
Trade: Whatever the customer wants
Rewards Points: 2,220
Might not work on pillars as well, but when levelling houses and replacing the sill, we'd wrap the underside of the new sill with either tyvek or membrane, reattach the sill, then fill the gap from levelling with non shrink grout.
If the gap was really small, we'd make a little form and pour it soupy, if it was big, we'd mix it dry and pack it in
Philament is offline
Old 05-22-2015, 11:10 AM   #8
mrcharles's Avatar
Trade: GC, Remodeling
Rewards Points: 1,652
If your house is out of level within 3/4" of an inch (guess from your plywood comment) why not just floor level it and install new flooring?
mrcharles is offline
Old 05-22-2015, 12:18 PM   #9
madmax718's Avatar
Trade: General
Well, if the floor started level, there's no reason to tear it out. leveling the house fixes many issues at the same time, and prevents further issues (such as buckling walls, crumbling plaster, windows not opening, kitchen floors out of level, etc.
Old 05-22-2015, 12:31 PM   #10
mac_will's Avatar
Trade: general contractor
Rewards Points: 6
I've used UHMW sheets and cut shims out of them. Works very well and will outlast wood and metal.
(Note it is pretty slippery so you would generally be advised to secure it in place)
mac_will is offline
The Following User Says Thank You to mac_will For This Useful Post:
Morning Wood (05-28-2015)
Old 05-22-2015, 01:02 PM   #11
mrcharles's Avatar
If you are trying to get a warped, over-spanned old floor back to level by jacking and shimming it you are going to spend tons of time and it still will be at different elevations over the span of the floor. On older stuff it never moves how you want it to.
Don't get me wrong, there are a lot of situations where jacking and leveling are the way to go, and that is some of my favorite work. If what the OP described is really all within 3/4" I don't think they should jack and level.
You are going to have drywall cracking and door window movement issues either way you go. When you start jacking a house everything is going to move. Existing cracks open up, new wallboard cracks form. Windows and doors that have been shimmed/shaved or are working will now require attention.
Old 05-28-2015, 04:12 AM   #12
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Unless you're me, I jack twisted and pulled my house back together this past winter, now none of my doors close
jlsconstruction is offline
The Following User Says Thank You to jlsconstruction For This Useful Post:
mrcharles (06-05-2015)
Old 05-28-2015, 11:21 AM   #13
TLHWindows's Avatar
Rewards Points: 734
If my house was 3/4" out of level, I would not touch it. But alas it is more. Such as it is living in sand.
I am re-leveling my house before I start more reno work. Rather fix it now than later.
Old 06-05-2015, 01:51 AM   #14
Contractor Joe's Avatar
Trade: Drywall
Rewards Points: 153
-Andrew
Go to a new construction site. See if they have bundles of wood. And take the wood shims out of that. LOL!
Wood shims from Home Depot or Lowes should suffice.
Contractor Joe is offline
Old 06-05-2015, 04:48 AM   #15
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
I use under course cedar shingles
Framer53 is offline
The Following User Says Thank You to Framer53 For This Useful Post:
Old 06-08-2015, 09:07 AM   #16
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 1,894
used to be able to buy cut metal shims at lumber yard by the pound .but have not seen them for years . recently i cut squares of sheet metal and stacked them . anything big enough gets nonshrink grout .
you could always grab some scraps from your local welding yard ,pieces 1/4" or whatever thick . not familiar with seeing rust under a house unless something is wrong . so steel should work fine.if putting on PT wood then put a membrane to seperate it from contact
JFM constr is online now
Old 06-09-2015, 08:16 AM   #17
TLHWindows's Avatar
Rewards Points: 734
I have yet to do this. I checked the lumber companies, no metal shims.
I think I will split it up between PT boards for the larger gaps and cedar shingles for the smaller ones.
I have to cut the straps away too, and then re-strap them after I am done.
On another note, pulled down latices that my insurance required me to put up years ago, discovered 2 young Oak snakes in some under pinning. Wonder what else it up there?? Good times.
Stupid question? Anyone ever mix sodium bicarbonate with recycled glass? MasterBlaster Sandblasting 7 03-23-2013 06:14 PM
Finishing a Barn vs Finishing a House 4 seasons lawn& Construction 3 03-02-2013 06:32 PM
Flip this house still a joke BCConstruction General Discussion 9 09-01-2012 12:55 PM
Just bought a house so this is a home owner question flyjaysun Finish Carpentry 6 06-16-2010 04:20 PM
