How To Step Down From First Floor - Construction - Contractor Talk
Old 10-26-2016, 05:46 PM   #1
3 Jacks 2 Nines
bwiab's Avatar
Trade: Wannabe Homebuilder
Rewards Points: 294
So the Archie didn't really design a way to get down from the back of the house into the back yard.
If I flash the rim board, can I backfill up above the foundation line and pour a slab within an inch of where the door will be? (On top of the floor) Or do I have to attach a treated wood deck/step here to get down to grade?
Thanks
bwiab is offline
Old 10-26-2016, 07:45 PM   #2
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
Re: How To Step Down From First Floor
a deck step would be my first way to deal with it. check with the building inspector
pappagor is offline
Old 10-26-2016, 08:05 PM   #3
slowsol's Avatar
Rewards Points: 2,248
Concrete step?
-John
slowsol is offline
Old 10-26-2016, 08:16 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 332
Flashing protects against water coming down from above. Doesn't do diddly to prevent capillary or other seepage from dirt above its lower edge.
You need a step or two.
Tinstaafl is online now
greg24k (10-26-2016)
Old 10-26-2016, 08:52 PM   #5
3 Jacks 2 Nines
bwiab's Avatar
Rewards Points: 294
Right. Say I flashed all the way from the floor over the foundation by 4" and glued it on there real good. Could I backfill 6" or so and pour a deck up against the flashing close to the top of the floor? Owner want's to do concrete if at all possible and would like to do it without a couple of steps.
bwiab is offline
Old 10-26-2016, 09:19 PM   #6
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 332
Any sealant you try may work. For a while. But ultimately it will fail.
You need a way for gravity to do its thing and keep moisture from pouring itself into any wood, or sneaking its way up by capillary action. To put fill within 1" [height] of the threshold in that scenario, you'd have to have a gap that drains to below the level of the concrete--and won't get gunked up over time.
Gotta say, it blows my mind that anyone in Colorado would even consider a threshold at ground level.
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
bwiab (10-26-2016), slowsol (10-27-2016), VinylHanger (10-27-2016)
Old 10-26-2016, 10:11 PM   #7
3 Jacks 2 Nines
bwiab's Avatar
Rewards Points: 294
Yeah... guess I'm just a little grumpy at myself for not catching it earlier... Would've been easy to step the wall up a foot and hang the joists at the door... then pour the slab back to the wall.
bwiab is offline
Old 10-26-2016, 10:28 PM   #8
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,974
Guys here flash and pour to threshold so no steps all the time. Not a big fan of doing it that way myself. Do it to make them more or less handicap accessible. And yes we get a lot of snow too.
Randy Bush is online now
Old 10-27-2016, 12:27 AM   #9
Nowhere's Avatar
Trade: Architectural Design and Drafting
Rewards Points: 134
Builder should have seen that coming and poured a section of wall up higher so that with a mudsill on it top of mudsill was equal to top of floor joists. That way you could do masonry right up tight.
But you don't and you should build a small set of steps just as you would a deck. Deck ledger, spaced away from the rim, I like Dek2Ledgers, all the flashing, counterflashing, etc. And then you need to figure what those steps will bear upon at grade.
Anything tight to the wall will cause the ledger to turn to mush, and whatever it is will have to be demo'd away in order to replace the rim and sheathing.
Nowhere is offline
Old 10-27-2016, 02:04 AM   #10
General Contractor
greg24k's Avatar
Rewards Points: 8,478
The entire foundation should have been higher. By the time you pur finish grade and topsoil, there will be nothing left between the mudsill and the grade, and you need a minimum of 6" separation if I'm not mistaken.
greg24k is offline
Old 10-27-2016, 06:15 AM   #11
Tom M's Avatar
Rewards Points: 7,498
6" for siding, more for the actual framing
Tom M is online now
greg24k (10-27-2016)
Old 10-27-2016, 08:48 AM   #12
General Contractor
greg24k's Avatar
Thanks Tom Yes, it's 8"... 3am my head wasn't working yet
greg24k is offline
Need recommendations to fix newly but poorly finished concrete floor MikeGC Concrete & Paving 20 03-08-2014 07:11 PM
degreasing garage floor - prep for carpet MarkJames Flooring 5 03-25-2013 09:59 PM
FS: Panther Floor Stripper Scraper 6280 HD Allfloorremoval Contractor Swap 1 07-16-2012 08:45 PM
Cross-laminated PE vapor barrier under floating floor after leveling with sleepers sjkm Flooring 11 06-14-2009 10:03 AM
Dealing with Floor Joists dcapone Low Voltage 0 08-18-2008 01:45 AM
