Header Question - Construction - Contractor Talk
Header Question
Old 01-10-2019, 09:03 AM   #1
Remodeler
jhicks226's Avatar
Rewards Points: 30
Header Question
I’m going to be opening up a kitchen wall. I will setting a 5 foot header but am really strapped for vertical space. Here’s my question: can the doubled top plates act as part of the header reducing the size of the header needed. There will be no cripples between the header and top plates. Thanks
jhicks226 is offline
Old 01-10-2019, 09:32 AM   #2
hdavis's Avatar
Rewards Points: 2,168
Re: Header Question
No.
You may be able to cut out one top plate to gain more depth for an lvl.
hdavis is online now
TheConstruct (01-10-2019)
Old 01-10-2019, 09:44 AM   #3
TheConstruct's Avatar
Trade: Renovations & Carpentry
Rewards Points: 1,712
Re: Header Question
What's above? Why are you stuck for space? Install it flush?
TheConstruct is online now
The Following User Says Thank You to TheConstruct For This Useful Post:
Rio (01-10-2019)
Old 01-10-2019, 10:01 AM   #4
hdavis's Avatar
Re: Header Question
Old 01-10-2019, 10:10 AM   #5
Remodeler
jhicks226's Avatar
Rewards Points: 30
Re: Header Question
Ok. Thanks for the input.
The Following User Says Thank You to jhicks226 For This Useful Post:
hdavis (01-10-2019)
Old 01-10-2019, 10:30 AM   #6
Re: Header Question
However you approach it you'll need to make sure the load is transferred down to adequate bearing.
hdavis (01-10-2019)
Old 01-10-2019, 10:41 AM   #7
hdavis's Avatar
Re: Header Question
I was going to say figure out how it would be if it was built that way originally, and then do that.
I've taken out double top plates that someone left and sheet rocked over for no good reason.
Old 01-10-2019, 10:42 AM   #8
Remodeler
jhicks226's Avatar
Rewards Points: 30
Re: Header Question
I’m just gonna do a drop header properly sized and piers under load points.
The Following 2 Users Say Thank You to jhicks226 For This Useful Post:
hdavis (01-10-2019), TheConstruct (01-10-2019)
Stupid question? Anyone ever mix sodium bicarbonate with recycled glass? MasterBlaster Sandblasting 7 03-23-2013 06:14 PM
Vinyl Flooring Adhesive Question josephdan General Discussion 1 03-05-2013 05:36 PM
Window and Door Header question davinci Framing 79 09-12-2010 07:28 PM
Improper Header Size greg24k Framing 9 03-27-2009 07:18 PM
