Gutter Hangers In Stucco Wall - Construction - Contractor Talk
Old 05-22-2012, 01:07 AM   #1
go_hercules's Avatar
Trade: painting
Rewards Points: 16
What is the best way to attach gutter downspout hangers to a stucco wall so that water does not get behind the tar paper and into the wall cavity. Seems that if a screw goes through to the sheathing and/or stud, then water can follow the screw and get behind the paper and into the wall cavity. I've seen guys just coat the screw with caulk or silicone but it still seems like a leak waiting to happen. Any ideas on this one?
go_hercules is offline
Old 05-22-2012, 06:32 AM   #2
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Gutter Hangers In Stucco Wall
seems to me you would need to cut in then flash a proper fascia
Tom Struble is offline
Old 05-22-2012, 10:43 AM   #3
aptpupil's Avatar
Rewards Points: 1,894
drill the hole, blow out the dust, fill with caulking, insert screw. if you are really cautious you can follow up with more caulking between the downspout strap and the stucco, but i've never gone that far myself.
aptpupil is offline
Old 05-22-2012, 02:05 PM   #4
Trade: painting
Rewards Points: 16
Thanks for that. I guess that's what I will do. I'll make sure to clean the holes good like you say and pack it full of caulk. Really no other way I suppose.
Old 05-22-2012, 04:42 PM   #5
Designer/Contractor
Rio's Avatar
Rewards Points: 324
Use a caulk like vulkem or similar type of polyurethane and goop a lot in the hole..........
Rio is online now
Old 05-22-2012, 05:17 PM   #6
aptpupil's Avatar
yeah. i use geocel 2300. just use something better than painters' caulk and you should be good.
aptpupil is offline
Old 05-22-2012, 06:40 PM   #7
Trade: siding
Rewards Points: 20
oh downspout ok got it,i miss readed it sorry
Old 05-22-2012, 06:43 PM   #8
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,130
Originally Posted by Tom Struble
I think he means downspout straps not gutter straps...
overanalyze is offline
Tom Struble (05-22-2012)
Old 05-23-2012, 12:37 AM   #9
Trade: painting
Rewards Points: 16
Yeah, sorry about that. I titled this post gutter hanger but I meant downspout strap.
Basement wall caving in JT Wood General Discussion 19 10-21-2010 06:14 PM
brick wall renovation or coverup rusty2010 General Discussion 9 05-25-2009 02:55 PM
brick wall renovation or coverup rusty2010 Commercial Construction 0 05-25-2009 08:26 AM
brick wall renovation or coverup rusty2010 Contractor Swap 0 05-24-2009 07:39 PM
Tight Space Stucco Question - Undershot between roof sections CGofMP Construction 3 03-24-2009 08:10 AM
