Golf Ball Broke Stationary Side Of Sliding Bay Window - Page 3 - Construction - Contractor Talk
Old 01-23-2019, 02:18 PM   #41
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 1,366
Re: Golf Ball Broke Stationary Side Of Sliding Bay Window
Originally Posted by Lettusbee View Post
Any glass shop can get the correct glass in a more timely manner. It would just be up to you to get the correct info regarding lo-e, individual pane thickness, and overall thickness of the IGU. (Insulated glass unit)
I think we've got this squared away.
Caslon is offline
Old 01-23-2019, 04:11 PM   #42
Lettusbee's Avatar
Rewards Points: 1,618
C'mon let's talk it to death
Lettusbee is online now
Old 01-23-2019, 04:12 PM   #43
Lettusbee's Avatar
Originally Posted by Big Johnson View Post
Local glass shops around here charge big money for iguís. I had a fixed window break once and it was cheaper to buy a whole new window than it was to get a local glass shop to make me an igu. It was surrounded by vinyl sididing so it was easy to replace the whole window.
Man I know that can be true half the time around here.
If it's a vinyl window and I can get glass from original manufacturer, that helps keep the cost down.
Otherwise, no mercy from local glass shops.
Old 01-23-2019, 06:51 PM   #44
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
I've done it a number of ways. Local shop comes out & measures. They may order, or build at shop. Depends if can match tempered, Low E, other special warranty specs.
Sliders - generally easiest to just get the entire fixed panel and not fck with setting glazing.
Breakage is common in new builds, and you will not get a Final Build green tag nor C of O with broken glazing.
SmallTownGuy is offline
Old 01-23-2019, 09:44 PM   #45
Caslon's Avatar
Right. This window wasn't like one where you cut two panes of glass and fit them in to the stationary section. There wasn't any trim to remove to get at where the new glass would fit in. Many glass shops would have done what is happening now. Get the window info off the spare slider, contact Simonton Windows and have them produce a completed section. Then... whoever... will install that section. That's what's in the works now.
Caslon is offline
Old 01-23-2019, 10:59 PM   #46
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 1,220
How to fix broken window in a rental
Step 1 : call property owner and inform him/her of damage
Step 2 : see step 1
Note: this method is effective for plumbing issues also
Idothat is offline
The Following 2 Users Say Thank You to Idothat For This Useful Post:
Calidecks (01-23-2019), SmallTownGuy (01-24-2019)
Old 01-24-2019, 02:07 AM   #47
Caslon's Avatar
Case or topic closed.
$500 at least to replace. He has a $1000 deductible.
The owner should attend the next HOA meeting and propose permission to attach a clear acrylic piece over that entire window.
Caslon is offline
Old 01-24-2019, 09:38 AM   #48
AustinDB's Avatar
Rewards Points: 1,582
I use to install a lot of Simonton windows and there may be a sticker at the top of the inside vinyl channel (move the sliding portion out of the way) with an order number. Call the rep and he can order a replacement insert with that number.
From the outside, remove the four pieces of trim-a couple of putty knives works well. I use a putty knife to break the adhesive bond between the glass and vinyl frame. Reinstalling, I've siliconed them in IIRC. I don't recall if he double sided tape comes w/ the replacement. It's not rocket science.
That window looks like a slider, not a bay window.
AustinDB is offline
Old 01-29-2019, 02:31 AM   #49
Caslon's Avatar
Ya...slider not bay window, I corrected that brain freeze earlier on.
Yes, there was a sticker on the spare slider, the installer coming over has that Simonton info. Simonton actually made a factory run for that one section. Takes two weeks. I'm gonna check out how he replaces that stationary section, for sure. For DIY sakes. Not rocket science, but I'd still order the finished section, for all best reasons.
Caslon is offline
Old 01-29-2019, 08:17 AM   #50
Lettusbee's Avatar
If this same window is always getting nailed by golf balls, you could upgrade to laminated glass at the next replacement. Won't be cheap, but is an option.
Old 01-29-2019, 06:09 PM   #51
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,004
I just want to know what happened to the golf ball. Did it receive first aid, at least?
Tinstaafl is online now
Lady Dreamer (01-30-2019)
Old 01-30-2019, 12:48 AM   #52
Caslon's Avatar
The lone golfer on foot didn't bother to come over and get his ball. He walked up to the green like nothing had happened, glanced over my way a few times.
Caslon is offline
Old 01-30-2019, 05:39 AM   #53
John the Builder
He just let it lay, Tin.
Old 01-30-2019, 10:36 AM   #54
GC/carpenter
Calidecks's Avatar
Rewards Points: 10,102
He had a choice to play it from thier dining room or move it one club out and deduct a shot. Lol
Mike.
_______________
Calidecks is online now
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
Lady Dreamer (01-30-2019), SmallTownGuy (01-30-2019)
calking lower piece of exterior window casings to window unit ryanthereal Windows, Siding and Doors 0 01-24-2018 05:57 PM
Measurement around window off ModusOdderandi Windows, Siding and Doors 10 09-23-2017 08:17 AM
Grading & base InterCounty Masonry 8 06-11-2013 10:11 PM
Nailing Utility Trim Under Window for Vinyl Nick R Windows, Siding and Doors 3 07-16-2012 05:25 PM
