Garage Built In A Lake - Construction - Contractor Talk
Old 03-30-2015, 03:52 PM   #1
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
Got a garage built in the middle of an existing slab with about a one inch lake in the center. The water is running into the garage through the saw cuts in the slab and possibly some under the plates as well. Any good way to remedy this?
"Industry without art is brutality"
shanekw1 is offline
Old 03-30-2015, 04:06 PM   #2
TimNJ's Avatar
Rewards Points: 5,686
Re: Garage Built In A Lake
Cut in perimeter drains??
First guess off the top of my head.
TimNJ is offline
Old 03-30-2015, 04:15 PM   #3
GettingBy's Avatar
Rewards Points: 6,486
From a high groundwater level?
To check the refill rate you need to know the shape of the volume of water and the puddle diameter.
http://mathworld.wolfram.com/SphericalCap.html
(flip the image upside down)
Or maybe it's cone-shaped.
Is the slab perfectly flat? How much out of level are you allowed to make the slab by jacking a corner?
GettingBy is offline
Old 03-30-2015, 04:34 PM   #4
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
No, not high groundwater, just rainwater. The slab is an inch low in the middle. The slab is also two feet thick, with solar panels and a giant boiler building on it.
shanekw1 is offline
Old 03-30-2015, 05:26 PM   #5
Renaissance Man
superseal's Avatar
Rewards Points: 5,840
Channel drains, waterproof chamfer or tnt.
Pictures would be of great help...
supersealconstruction.com
superseal is offline
Old 03-30-2015, 05:27 PM   #6
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
put in a sump pump and basket
pappagor is offline
Old 03-30-2015, 08:10 PM   #7
AustinDB's Avatar
Rewards Points: 1,426
clean out the saw cuts leading out the front for the water to drain gets it out. first thought is filling the cuts with BASF NP1, but if it's coming under the sill plates and the concrete comes out too far, address infiltration first.
AustinDB is offline
Old 04-01-2015, 01:05 AM   #8
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
Here's a couple pics. The low spot on the slab is near the middle of this wall and extends under the wall to the inside.
I told them cutting in channels to get the water flowing off the slab instead of pooling in the center was the best bet. They are going to call whoever poured this slab in the shape of a bowl to see if they will rectify it.
If it wasn't 2+ feet thick, I would have drilled a couple drain holes in it but there is no way I am drilling through a two foot slab.
Garage built in a lake-2015-03-31-16.24.49.jpg   Garage built in a lake-2015-03-31-16.25.11.jpg
shanekw1 is offline
Old 04-01-2015, 06:04 AM   #9
rrk's Avatar
Rewards Points: 3,466
I saw a slab that held some type of electrical gear that had a swale ground into it for probably the same reason. It was about 18" wide and not difficult to walk on/across, it seemed to do the trick. Water never puddled again.
rrk is offline
shanekw1 (04-01-2015)
Old 04-01-2015, 09:01 AM   #10
GettingBy's Avatar
Can you make it flat or give it a slight crown? Is it now low because of the weight of everything that is on it (when cured it was perfectly flat)?
Old 04-01-2015, 09:55 AM   #11
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
Being that the slab is @ 30 x 50 and 2 feet thick, with the part under the sea can in the pic they say is 4 feet thick, I doubt anything is moving it.
shanekw1 is offline
Old 04-01-2015, 10:48 AM   #12
Chopsaw Chick's Avatar
Rewards Points: 589
I don't think you want drain holes or you'll slowly wash out the soil under the slab. It would be better to keep the water out in the first place. How about flashing under the exterior wall in conjunction with a water-tight curb that will keep water from getting under - and/or soaking through - the bottom plates?
Chopsaw Chick is offline
Old 04-01-2015, 05:57 PM   #13
Obi Wan Cannoli's Avatar
Trade: Residential Remodel
Rewards Points: 88
I'm not sure what kind of rules and regulations you have to follow, but if you can't:
1) Move the slab
2) Resurface the slab to correct pitch
then you'll have to give the water a path of less resistance to drain by cutting a drain into it.
I can suggest 2 things:
A) A trench drain
or B) Use a concrete saw and cut a couple of parallel long slits into the concrete then chip it away to make a little trench drain out of the slab itself.
I'd go with A personally
Obi Wan Cannoli is offline
Old 04-01-2015, 07:01 PM   #14
rrk's Avatar
1) Move the slab
A) A trench drain
Did you miss the part where its 2' thick and 4' thick in places?
rrk is offline
Old 04-01-2015, 07:03 PM   #15
Rewards Points: 88
Good thing he doesn't have to cut all the way through.
Old 04-01-2015, 11:49 PM   #16
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,403
Survey the low spot(deepest water in the catfish pond) saw a groove/kerf to daylight with a walk behind floor saw using a laser to level the "ditch" botttom, angle cut sides. cash check.
The tough part is keeping trash out the ditch during dry spells/
Fouthgeneration is offline
Crazy site built cabinet business idea Bearded Wonder Business 114 03-20-2014 03:45 PM
Insulation options for living area above garage zach477 Insulation 4 04-16-2013 03:36 PM
2 spare breakers 15 & 20a, want to wire outlets in garage pitterpat Electrical 8 05-13-2012 02:58 PM
garage floor issue Home Serve Masonry 6 05-17-2010 06:55 AM
Garage problems.... nwksremodeler Remodeling 29 05-12-2010 02:55 PM
