Finishing A Barn Vs Finishing A House - Construction - Contractor Talk
Old 03-02-2013, 01:08 PM   #1
4 seasons lawn&'s Avatar
Trade: Landscape
Rewards Points: 25
Hopefully this is the right spot to post this general construction question.
I'm looking at a newly built, very large barn to possibly finish the upper level into house/apartment living space. Im wondering if there are any issues and additional expenses with finishing a barn structure into a heated living space above and beyond finishing a typical house. For example, most homes have basements. Barn is just a slab. Maybe there are differences in the venting for barn vs house construction. Maybe there are dozens of differences that Im not aware of that make barn conversion difficult.
If it makes any difference the barn is concrete floor and cement block construction up to the first floor ceiling with extensive steel beams on top of the cement block, supporting the upper floor (also concrete) and large gambrel roof structure.
Thanks for any advice.
4 seasons lawn& is offline
Old 03-02-2013, 01:35 PM   #2
astor's Avatar
Trade: FI
Rewards Points: 704
Re: Finishing A Barn Vs Finishing A House
no basements here...and the houses are still stands..you may neet to insulate the ceiling of the first floor so the second floor won't kill you with heating/cooling bills.
Just like elevated houses in coastal communities... search for elevated houses on Google...
astor is offline
Old 03-02-2013, 06:04 PM   #3
Thom
thom's Avatar
Rewards Points: 4,748
This is a change in occupancy which requires a permit and insuring the structure meets current building codes for the new occupancy rating. So, get a building permit that shows all portions of the building meeting code. These include:
site grading
foundation specifications
slab specifications
framing structure
siding
electrical
mechanical
insulation
exterior finish
interior finish
adequate natural light
adequate natural ventilation
proper interior and exterior door sizes
adequate roofing
and I probably missed some.
Just make sure it conforms to the rules that any new house in the area conforms to, insure that you can document things that are existing, you will be golden.
Patriotism is being loyal to your country all the time and your government when it deserves it. Mark Twain
thom is offline
The Following User Says Thank You to thom For This Useful Post:
griz (03-02-2013)
Old 03-02-2013, 06:32 PM   #4
mikeswoods's Avatar
Trade: interior remodeling
Rewards Points: 2,664
Before you even think of this as a project---get drawings done by an architect or designer----fire proofing and proper roof ventilation both may be beyond the 'design as you go' that you may be considering----
mikeswoods is offline
If you're not on Facebook, you should be. Sir Mixalot Marketing & Sales 1862 02-15-2020 02:59 PM
airless fine finishing coin9961 Painting & Finish Work 2 12-15-2012 01:10 PM
Moving mountains, or maybe a big barn? Joasis Off Topic (Non Trade) 1 11-07-2011 02:13 PM
Floating house, house floats up during hurricane medusa General Discussion 62 01-03-2011 08:08 PM
