Finished Basement Walls(exterior) - Construction - Contractor Talk
Old 08-09-2011, 08:30 PM   #1
Dan
ApgarNJ's Avatar
Rewards Points: 2,000
hey guys, I have a pretty good system for doing exterior walls in finished basements. Most of the basements in my area are block, or poured.
The newer houses are poured.
Do you guys that use foam board insulation, install drylok waterproofting paint on the concrete or block first? I think this could be a double vapor barrier so if the basement is dry, I just put the foam boards against the block, tape the seams and then build my wall right up against that. I don't use plastic behind the drywall either.
Do you think it's bad to have drylock then rigid foam insulation up against it?
I won't use fiberglass insulation in basements anymore.
Thanks
Dan
ApgarNJ is offline
Old 08-09-2011, 09:58 PM   #2
Renaissance Man
superseal's Avatar
Rewards Points: 5,844
Re: Finished Basement Walls(exterior)
Nope, not at all...Drylok is similar to Thoroseal which i use and are negative side waterproofers. Thoro claims to breathe vapor anyway and good choice on the rigid. U use steel studs/furring for the framing or still using wood?
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
ApgarNJ (08-10-2011)
Old 08-10-2011, 05:13 AM   #3
Dan
ApgarNJ's Avatar
I still use wood unless it's a damp basement. I guess I haven't ventured into the steel stud world yet, but it's something that I'm not opposed to. I am going to bid this next finished basement with steel studs and see how different it is to work with. What's the best thing to cut them with a cutoff saw or are they thin enough that you can use a fine tooth carbide blade in a miter saw. I have an older non slider dewalt miter saw that I use for cutting aluminum with. I was thinking of using that.
ApgarNJ is offline
Old 08-10-2011, 07:46 AM   #4
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 4,768
Apgar, that is how I did my last basement, Patch all gaps and fill holes + 2 coats of Dryloc, wood vrs metal - I used both on this last one.
http://www.contractortalk.com/f18/fi...ob-year-96040/
The Following User Says Thank You to Snobnd For This Useful Post: Leo
Snobnd is offline
Finished Basement kcbasements Remodeling Picture Post 13 09-07-2012 07:05 AM
Finished Basement EMINNYS Remodeling 16 07-16-2011 07:17 PM
Oily basement walls? tgschwer General Discussion 9 06-27-2011 06:47 PM
Basement Remodel. BamBamm5144 Carpentry 59 03-07-2010 12:26 PM
Questions about basement finish Danno6102 Remodeling 5 05-18-2009 12:37 PM
