Dlb.. Top Plate / Dlb. Joist? - Page 2 - Construction - Contractor Talk
Old 08-07-2014, 07:43 PM   #21
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,428
Re: Dlb.. Top Plate / Dlb. Joist?
Originally Posted by tenon0774 View Post
Why is that, Warren?
Not being a smart a$$, serious question.
I've been out of production framing for a while.
Because if you put up your non load bearing interior walls after framing up, you can't stand the interior wall up.
Never stop learning (xcep fer speling en typeing)
MTN REMODEL LLC is offline
Old 08-07-2014, 08:51 PM   #22
GC/carpenter
Calidecks's Avatar
Rewards Points: 3,204
Originally Posted by Warren View Post
Because precut studs are only cut to 92 5/8", 104 5/8", and 116 5/8"
It also allows you to tie all the walls together via an overlap at all corners and partitions.
Ours are 92-1/4"
Calidecks is online now
Old 08-08-2014, 01:42 AM   #23
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Decks, Additions
Rewards Points: 14,418
Rigidity
A&E Exteriors is offline
? Curbless shower with wood floor joist sycamorebob Tiling 8 11-04-2012 10:18 AM
Rotted sill plate and broken joist repair netlinks Framing 0 07-18-2012 10:24 PM
Replacing rotted rim joist entry door...first timer! r1dannyzx Carpentry 22 04-20-2011 04:06 PM
stocking service trucks MO-AMPS Electrical 23 11-25-2009 10:39 PM
Framing Roof Joists for Addition when top Plate is not Level personalt Framing 3 07-20-2007 05:52 AM
