Difficulty Of Irregular Angles? - Construction - Contractor Talk
Old 04-07-2013, 11:56 PM   #1
MM88's Avatar
How much more difficult and time consuming would it be to construct a four story building with irregular angles? We are looking at a site that is rather strange and the architect is proposing some rather irregular angles in his design. The are still mostly 90 degree joints but several acute angles as well.
Just wondering what a more experienced contractor would think in terms of time, difficulty, cost, etc.
MM88 is offline
Old 04-07-2013, 11:58 PM   #2
Mavis Leonard's Avatar
Trade: Different phrases of construction
Rewards Points: 250
Re: Difficulty Of Irregular Angles?
i no i hat drywall fininshin in acute angls
an i say tht isvague quesoin
Mavis Leonard is offline
The Following User Says Thank You to Mavis Leonard For This Useful Post:
MM88 (04-08-2013)
Old 04-08-2013, 12:08 AM   #3
MM88's Avatar
I am sorry it is vague. spoke with boss about the project the other day. He didn't sound to excited, but as someone just starting out, it is more about care and attention to detail or difficulty and cost and time.
MM88 is offline
Old 04-08-2013, 12:11 AM   #4
Rewards Points: 250
good lerning experence for u if he get job the
Old 04-08-2013, 12:11 AM   #5
mbryan's Avatar
Trade: Ministry
Rewards Points: 568
A big advantage is nothing has to be square...
I personally don't like them, they just seem like wasted space.
mbryan is offline
The Following User Says Thank You to mbryan For This Useful Post:
MTN REMODEL LLC (04-26-2013)
Old 04-08-2013, 12:55 AM   #6
Thom
thom's Avatar
Rewards Points: 4,748
Slab is only a little more difficult, maybe no more difficult.
Wall framing is only a little more difficult.
Floor framing might be a little more difficult or a lot more difficult.
Floor decking will have a lot of waste in time and some in materials.
Roof framing will be similar to floor if it's a flat roof, if pitched it could be a real PITA.
Wasted drywall mtls and a little more time.
Trim should be only a little more difficult, little difference.
Watch out for the electrician, 480's going to charge a lot more for the obtuse bends.
Patriotism is being loyal to your country all the time and your government when it deserves it. Mark Twain
thom is offline
Old 04-08-2013, 12:59 AM   #7
Rewards Points: 250
pitched wth trusss could meen som really custom trusssess
Old 04-23-2013, 09:25 PM   #8
ubcguy89's Avatar
Trade: carpenter/ interior systems
Rewards Points: 742
not much more dificult. Get a total station with the PDA for building layout. It will save on layout times. when you pour your decks your forms may be a PITA but you will more than likely sub that out?
ubcguy89 is offline
Old 04-26-2013, 07:14 PM   #9
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,428
A lot easier than stick building it.... and with their computerized truss designs, I don't know that it would be that extravagantly more expensive, certainly more expensive because they jig each different truss, but those tables/jigs, adjust pretty quickly.
Certainly more difficult to estimate what you're looking at... good luck
As an after thought , if you did get involved in any complex trusses, double... no triple check your truss layout/design when delivered. Seems that I get alot of mis-built trusses delivered on some relatively simple designs (inverted hip designs and some remodel type semi complicated roof tie in designs). It's a real pain to get them up there, sometimes set them, and then discover that the jig-saw puzzle doesn't go together. .. and wait two days to get the corrected truss back out to the site.
Never stop learning (xcep fer speling en typeing)
MTN REMODEL LLC is offline
Polymeric Sand for Irregular Bluestone? Tommy C Masonry 32 06-29-2015 05:58 AM
Deck with some odd angles - How to cut rvdsabu4life Decks & Fencing 28 10-08-2012 12:12 AM
Irregular roof with equal overhangs,dropped and shifted hip with square tailed facia. mike86 Framing 4 12-07-2011 07:18 AM
best way to do shallow angles in vaults? d's Drywall 5 09-27-2009 03:51 PM
Square hung facia on irregular hip roof? skinnyjimmy Framing 22 07-28-2009 01:15 AM
