Cutting 6x6 With A Chain Saw ? - Construction - Contractor Talk
Old 06-09-2015, 11:06 AM   #1
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,272
Building this swing set.
I've never cut beams with a chain saw. How goes it ?
I have a good Stihl 16"
Cuts 6x6 pretty good or what ?
I have a Makita worm drive also.
We Fix Houses is offline
Old 06-09-2015, 11:20 AM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 142
Re: Cutting 6x6 With A Chain Saw ?
Cutting large beams and timbers with a chain saw can work just fine.
It depends completely on how good you are with a chain saw.
Chain must be brand new sharp & tensioned correctly for best results.
griz is online now
Old 06-09-2015, 12:19 PM   #3
Thanks - I have a new chain and the one on it I sharpen with the file kit.
Haven't used the saw itself too much.
The Following User Says Thank You to We Fix Houses For This Useful Post:
JAH (06-09-2015)
Old 06-09-2015, 12:38 PM   #4
GettingBy's Avatar
Rewards Points: 6,486
Is it possible to build a saw guide for a chainsaw to give you a square cut on that beam?
GettingBy is offline
Old 06-09-2015, 01:10 PM   #5
Agility's Avatar
Trade: Carpentry; Kitchen & Bath Reno
Rewards Points: 1,016
You could probably build one but there are a few manufacturers who already make them. They're great for timber framing and SIPs panels.
Agility is offline
Old 06-09-2015, 01:17 PM   #6
Doing this tomorrow. I'll look on YT.
Old 06-09-2015, 01:26 PM   #7
I'll have to get a look at "Scarface" again tonight.......
GettingBy (06-09-2015)
Old 06-09-2015, 01:59 PM   #8
Fire up the BBQ
griz's Avatar
Rewards Points: 142
Yes.
Clamp or screw on some 2x4 scraps, on the flat on the top and either one or both sides to help you out.
Go slow and keep the bar square to the face of your 6x6.
Don't over think it.
griz is online now
Old 06-09-2015, 03:56 PM   #9
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 76
You can make a jig for just about anything, if it's worth your time...
Tinstaafl is offline
Old 06-09-2015, 04:34 PM   #10
JAH's Avatar
Trade: carpenter
Rewards Points: 1,910
You might want to make some practice cuts first. I find a skill saw and sawzall much easier. A 6x6 isnt really big enough to justify a chain saw.
JAH is offline
Old 06-09-2015, 05:09 PM   #11
We Put Poles In Holes
baerconstructio's Avatar
Trade: Post Frame Builder
Rewards Points: 325
http://www.coastaltool.com/a/ab/praz...es/pr-2700.jpg
baerconstructio is offline
The Following User Says Thank You to baerconstructio For This Useful Post:
CrpntrFrk (06-09-2015)
Old 06-09-2015, 05:32 PM   #12
muskoka guy's Avatar
Trade: framer/builder
Rewards Points: 558
I agree cut them this way all the time. Even a hand saw to finish the cut. Mark a line all the way around the post and make sure the lines match when meet back at the start.
muskoka guy is offline
Old 06-09-2015, 08:41 PM   #13
GettingBy's Avatar
If you extend the bolt that clamps the bar and hold the bolt axis parallel to the beam axis then the saw can pivot like a chop saw.
Old 06-09-2015, 09:08 PM   #14
pizalm's Avatar
Rewards Points: 826
Do you overthink everything in life?
A circ saw and recip will work fine, or a chainsaw if you're decent with it.
Sent from my iPad using Tapatalk
pizalm is online now
Old 06-10-2015, 08:14 AM   #15
David7586's Avatar
Trade: General
Rewards Points: 185
::whistles:: I'd love to see the pocket hole jig needed for plugs that size...
Sorry I didn't have anything useful to contribute, but that's all I could think when I saw the picture.
David7586 is offline
Old 06-10-2015, 08:18 AM   #16
Thanks for the replies. I'll be at the job a bit later today.
It's been awhile since I've done 6x6's. Aside from the weight, I needed a re-up on cutting.
I can use my worm drive and sawzall I think will work well. Can't get my chain saw running.
Old 06-10-2015, 10:19 AM   #17
GettingBy's Avatar
Only lately.
I've also adapted a strategy of coming up with at least two solutions to a problem even before I pick up a hammer. And usually the first doesn't work or is less desirable for one reason or another.
Think of it as a stretching or a weight lifting exercise for your mind.
Another good way to give yourself a heavy cognitive load is to balance your checkbook without a calculator. I'm working up to doing it without paper.
Push yourself.
You'll build up a reserve that you may need someday, maybe in a crisis.
California Style Chain Link Fence hwfence Decks & Fencing 38 01-29-2015 05:41 PM
chain smokers and painting ceilings toolman65 Painting & Finish Work 11 09-15-2012 09:05 PM
Cutting rafters [email protected]#e Framing 79 12-13-2010 08:25 PM
apprentice having trouble cutting accurately likeke34 Carpentry 193 12-21-2009 01:29 AM
vinyl siding cutting table platinumLLC Windows, Siding and Doors 16 08-15-2009 10:54 AM
