Curved Wood Beam Connection To I-beam - Construction - Contractor Talk
Old 05-29-2015, 03:43 PM   #1
packerphil4's Avatar
Rewards Points: 12
Hello,
I need some sort of tie (or strong tie) or something else to connect an I-beam that sits horizontal on top of a wall to a curved wood beam that is going to provide the framing for the ceiling or roof. I might leave the curved beam exposed as part of the ceiling, haven't decided yet.Any suggestions?
Thanks,
Phil
packerphil4 is offline
Old 05-29-2015, 04:23 PM   #2
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
Re: Curved Wood Beam Connection To I-beam
bolts..............
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
The Following User Says Thank You to jaydee For This Useful Post:
Calidecks (05-31-2015)
Old 05-29-2015, 05:24 PM   #3
Rewards Points: 12
The curve of the beam will expose the bolt, which we are trying to avoid. We would like some type of cap or tie in to go in between the I-beam and curved beam to hold the two together.
Old 05-29-2015, 06:36 PM   #4
Designer/Contractor
Rio's Avatar
Rewards Points: 1,688
Maybe something along these lines..... instead of attaching to a post attach to the I beam.
Rio is online now
Old 05-29-2015, 06:38 PM   #5
Rewards Points: 12
something more along the lines on what is in this picture, but accounting for the fact that it will be sitting on a metal I-beam
Old 05-29-2015, 07:00 PM   #6
muskoka guy's Avatar
Trade: framer/builder
Rewards Points: 558
Have the brackets welded onto the I beam. We have unusual brackets fabricated and welded on all the time. You could also drill holes and bolt them on.
muskoka guy is offline
The Following 5 Users Say Thank You to muskoka guy For This Useful Post:
Calidecks (05-31-2015), Obi Wan Cannoli (06-01-2015), Rio (05-29-2015), Sabagley (05-30-2015), tenon0774 (06-01-2015)
Old 05-30-2015, 12:31 PM   #7
I'm The BOSS
jaydee's Avatar
well, a picture is worth a thousand , words..
Facebook
jaydee is offline
Old 05-30-2015, 01:45 PM   #8
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 638
That last picture was not even worth a thousand turds.
I have no idea what Phil the OP is talking about or describing to us.
Sketch it out or something so we understand.
We will probably end up suggesting you go to an engineer and have it spec'ed and drawn for you.
That is what I would have done before asking us lame-brains on this forum.
Andy.
ScipioAfricanus is offline
Old 05-30-2015, 06:29 PM   #9
CarpenterSFO's Avatar
Rewards Points: 2,044
Andy.
How to attach an arched glulam to the top beam of a steel moment frame, without an "exposed bolt", and presumably without any wood bolted to the top of the steel.
Unless this building will be on the moon or some other low-gravity place (for example Green Bay), I would expect to need an engineer's stamp, and would go right there.
- Bob
CarpenterSFO is offline
Old 05-31-2015, 10:50 PM   #10
Rewards Points: 12
In the last picture pretend that the beam the curved wood is sitting on is an I-beam.
Here is an artistic photo. I need something to attach the I-beam to the curved beam
The Following User Says Thank You to packerphil4 For This Useful Post:
ScipioAfricanus (06-01-2015)
Old 05-31-2015, 11:03 PM   #11
GC/carpenter
Calidecks's Avatar
Rewards Points: 94
Here's your answer
Calidecks is online now
Old 06-01-2015, 08:19 AM   #12
All right, I'm curious. What is the span of that roof? A 7 1/2" deep arch member isn't that deep. What will be preventing the walls from spreading? or that steel beam from tipping over?
- Bob
Old 06-01-2015, 09:34 AM   #13
Anti-wingnut's Avatar
Rewards Points: 3,430
If it is critical that the fastener be close to invisible, then that requires the bolt to be vertical thru the GLB, with the GLB landing in some saddle or the such. A archy, engineer or detailer could supply the detail
Anti-wingnut is offline
Old 06-01-2015, 12:44 PM   #14
Rewards Points: 12
My drawing is terrible, the 7.5'' is supposed to be the width of the curved beam, not the height.
Old 06-01-2015, 12:56 PM   #15
Does this application have an engineer?
Old 06-01-2015, 09:46 PM   #16
Rewards Points: 12
Next drawing. The part in black is what I need. It will be bolted onto a 5.5 inch wide I-beam and be bolted into both sides of the curved wood beam. What's this piece called? Some sort of bracket?
Old 06-02-2015, 03:55 AM   #17
Phil, I don't believe you're a contractor.
- Bob
Old 06-02-2015, 10:31 PM   #18
Rewards Points: 12
I work for a contracting company on the financial side of things. I am rarely involved in the actual work, but was assigned the task of finding us a bracket of some sort to put all this together
Old 06-02-2015, 10:34 PM   #19
It's obvious that he's a draftsman
The Following 2 Users Say Thank You to Anti-wingnut For This Useful Post:
CarpenterSFO (06-03-2015), Morning Wood (06-02-2015)
Old 06-02-2015, 10:43 PM   #20
Box Builder
Morning Wood's Avatar
Rewards Points: 6
I think you're going to need some brackets welded up. Shouldn't be too hard or pricey. How tall is the curved beam? Basically three pieces of metal to create a saddle. The bottom should be longer than the width of the beam by enough so you can drill and bolt it to the I beam. Or just weld it to it
This has already been suggested
Morning Wood is online now
What Species Wood Should I Use? NC2X4 Carpentry Picture Post 23 04-19-2016 08:39 AM
Timber Frame vs Post & Beam Dustincoc Framing 18 06-26-2014 08:32 PM
Lotta wood, #1 common white oak, finished natural pinwheel Flooring Picture Post 18 05-31-2013 10:01 PM
little curved job Bone Saw Decks & Fencing 14 07-20-2012 05:38 PM
