Considerations For Pouring A Rather Tall Concrete Pier? - Page 2 - Construction - Contractor Talk
Old 04-23-2013, 09:04 PM   #21
ubcguy89's Avatar
Trade: carpenter/ interior systems
Rewards Points: 742
Re: Considerations For Pouring A Rather Tall Concrete Pier?
Originally Posted by acro View Post
Is there an engineer around that you can call on to give you some specs for sizes?
I am not familiar with any, but I am in southern Ohio if you know of any.
The culvert pipe is a good idea but what size? (22? 24?)
About 22"
Are you going to lay steel in it?
Was not planning on it.
What strength concrete are you thinking?
5k psi, but that was one of my initial questions.
I don't like the idea of dropping the concrete 13' but if you vibrate it as you go up you can lessen the separation that might occur.
What about adding any friction modifiers or other additives to the mix? The drop would be straight down, so nothing to hit that could separate the mix and cause graveling. That's my thought anyway.
This building is an old service facility for DT&I trains.
here is the deal, you need to get an engineer!!!
If you decide not to get an engineer, you need to get a pressure test done on the soil. If the soil is soft, you may need to drive piling, or possibly dig deeper for a caison.
ubcguy89 is offline
Powder actuated pins in 4500 psi concrete Calidecks Concrete & Paving 10 10-03-2012 05:55 PM
Crown molding on concrete ceiling CadetC Finish Carpentry 13 09-15-2012 09:14 PM
Concrete overlays, anyone use one? Little Excavation & Site Work 3 08-24-2012 07:09 PM
TYPARŪ Flashing BA - under a concrete floor?? AmeliaP Masonry 5 07-27-2012 04:08 AM
Tire line in concrete after finishing. aydin_eng Flooring 34 03-09-2010 10:03 PM
