Concrete Detail - Construction - Contractor Talk
Concrete Detail
Thread Tools
Old 03-04-2019, 11:46 PM
futurebuild's Avatar
Trade: General contractor
Rewards Points: 8
Concrete Detail
Hi Guys,
I am interested in polished concrete for a future build. However, I would like to recess hardwood into various section throughout while keeping both surfaces level(not laying the hardwood on top of the concrete). Additionally, I would want to keep the silestone walk-in shower at the same level as the polished concrete. Lastly, I would like to recess the window tracks into the concrete so that I can have the floor to ceiling glass illusion. I am attaching pictures of the results I'm after.
How would you go about this? Should I pour the polished concrete floors first then pour the concrete for the shower, door areas and recessed floor section after?
Thank you for your help!
concrete detail-conctet-question-floor.jpg   concrete detail-shower-concrete-detail-2.jpg   concrete detail-wood-floor-polished-concrete-detail-.jpg   concrete detail-window-frame-concrete-question.jpg
futurebuild is offline
Old 03-05-2019, 12:35 AM
duburban's Avatar
Trade: building
Rewards Points: 1,752
Re: Concrete Detail
Is that Rhino by chance ?
Hereís what I would do, but Iíve never done it. Iím sure someone here has.
duburban is online now
Old 03-05-2019, 12:50 AM
Rewards Points: 8
Re: Concrete Detail
Yes! Good eye, I set the view to artistic and captured the image via print to jpeg.
Great detail, thank you very much for your help.
Old 03-05-2019, 09:24 AM
Fishindude's Avatar
Trade: Industrial
Rewards Points: 860
Re: Concrete Detail
Yep, only way to hold that sharp edge on the recess is to do in separate pours. I'd pour the lower slab first, then fasten a wood screed board on top of the perimeter of lower slab so you can screed and pour the upper slab at the appropriate height. I would "pin" the two slabs together with rebar dowels so you don't get movement between the two.
Fishindude is offline
Old 03-05-2019, 10:30 AM
Rewards Points: 8
Re: Concrete Detail
Thank you guys really helpful information.
Old 03-05-2019, 10:48 AM
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,525
Re: Concrete Detail
Just curious. Will the wood be in somewhat of a wet environment, or have wet feet?
MarkJames is offline
Old 03-05-2019, 11:02 AM
Rewards Points: 8
Re: Concrete Detail
No hardwood in the bath area.
Old 03-05-2019, 12:35 PM
duburban's Avatar
Trade: building
Re: Concrete Detail
Two pours seems 2x easier than making my detail actually work!
Thread Tools
Rate This Thread
concrete foundation detail at exterior doors. Knosaj Construction 16 08-15-2014 06:07 AM
Powder actuated pins in 4500 psi concrete Calidecks Concrete & Paving 10 10-03-2012 05:55 PM
Crown molding on concrete ceiling CadetC Finish Carpentry 13 09-15-2012 09:14 PM
Recommendation on changing concrete color with breathable product? RDBD Specialty Coatings 0 06-07-2011 08:57 AM
