Concrete Deck - Construction - Contractor Talk
Concrete Deck
Old 02-15-2015, 08:41 AM   #1
cdkyle's Avatar
Trade: Concrete & General Construction
Location: The Heartland of the United States of America
Rewards Points: 606
Concrete Deck
I have a concrete floor to pour on an elevated metal. Plans call for 3 1/2" of concrete. The architect did not call for any reinforcing other than fiber mesh. Any thoughts?
cdkyle is offline
Old 02-15-2015, 08:53 AM   #2
Mark122's Avatar
Rewards Points: 464
Re: Concrete Deck
if you deviate from the approved plans its on you... if your really concerned about it bring it up but you will more then likely be told to stick to the plans.
Mark122 is offline
The Following 2 Users Say Thank You to Mark122 For This Useful Post:
fjn (02-18-2015), rustyjames (02-15-2015)
Old 02-15-2015, 08:53 AM   #3
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 196
Re: Concrete Deck
Seems O.K. to me but I am not the engineer on the project.
What gauge does it call out for?
Andy.
ScipioAfricanus is online now
Old 02-15-2015, 09:09 AM   #4
Board Shortener
Johnny_5's Avatar
Trade: Carpentry / Remodels
Rewards Points: 706
Re: Concrete Deck
RFI to the engineer.
Johnny_5 is offline
Old 02-15-2015, 12:11 PM   #5
Joasis's Avatar
Rewards Points: 892
Re: Concrete Deck
I have seen it done a lot of times. The strength is in the joists, and the dispersing of the load. The concrete is the cheapest, stiffest deck available.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
Old 02-15-2015, 12:53 PM   #6
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
Re: Concrete Deck
We are doing the same right now, about 5000' slab and only 2.5" of concrete above the highest ribs, 4" from the lower part of the pan. Our joists are 5' o.c. too
Chris
Chris Johnson is offline
Old 02-15-2015, 01:17 PM   #7
rustyjames's Avatar
Rewards Points: 1,782
Re: Concrete Deck
Since the decking is only 9/16" the joist spacing is probably no more than a few feet, if that. This type of deck is typical for a mechanical mezzanine.
rustyjames is online now
Old 02-15-2015, 03:07 PM   #8
cdkyle's Avatar
Rewards Points: 606
Re: Concrete Deck
Yes, I'm not so concerned about the load &/or joist spacing. That has all been through engineering. The joists are on 2'0 centers. Slab is roughly 8000 sf. I was referring more to how the 3000 psi concrete (which was spec) would react and perform at 3.5" on the galvanized deck with no rebar or wire mesh. Rebar would be difficult, because with only 3" of concrete there would not be enough cover unless it was laid on the bottom. At that point, what is the use?
cdkyle is offline
Old 02-16-2015, 09:47 AM   #9
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
Re: Concrete Deck
9/16" decking? Ha, never seen that before.
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Old 02-16-2015, 09:52 AM   #10
Joasis's Avatar
Rewards Points: 892
Re: Concrete Deck
9/16 allows for a stiffened pan, and is not for structural, per say.
I have seen decks with welded wire panel reinforcement, but in thinner slabs, rebar pushed to the bottom of the slab could actually cause a structural problem.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
My Facebook Page
Joasis is offline
Old 02-16-2015, 06:25 PM   #11
Alldayrj's Avatar
Trade: Mason
Rewards Points: 284
Re: Concrete Deck
Pretty normal, its interior so not seeing freeze/thaw. We did a 110x125 church the same way. The fibermesh is enough
Alldayrj is offline
Old 02-17-2015, 03:39 PM   #12
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
Re: Concrete Deck
The ones we have been involved in have had wire mess in the pour. We've always done EPDM between the decking and the concrete.
1985gt is offline
Old 02-25-2015, 07:46 PM   #13
Woodroe's Avatar
Rewards Points: 18
Re: Concrete Deck
pour it according to the plans...ditto what mark said.
Woodroe is offline
Old 02-26-2015, 05:39 PM   #14
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Re: Concrete Deck
Shortly after Falling Water was built and the cantilevers started to sag,Frank Loyd "Wrong" blamed the problem on the concrete contractor.....he added more steel to the pour.
P.S. Even though he reasoned the steel was insufficient and added more,the architect needed someone to blame.
fjn is offline
Old 02-26-2015, 06:08 PM   #15
Agility's Avatar
Trade: Carpentry; Kitchen & Bath Reno
Rewards Points: 1,016
Re: Concrete Deck
I was just reading about those sagging cantilevers. Deflection eventually reached 7 inches over 15 feet!
Agility is offline
The Following User Says Thank You to Agility For This Useful Post:
fjn (02-27-2015)
Old 02-26-2015, 07:12 PM   #16
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,074
Re: Concrete Deck
I thought it was worse than that, the contactor told the homeowner that he thought there should be at least double the steel. The HO told Wright and he freaked out as he took it as an insult. The contractor went ahead and doubled the steel.
Then after it was poured on of Wright's employees realized his load calculation was half of the actual load and double the steel would be required.
But the damn thing sagged anyway.
Inner10 is offline
Old 02-26-2015, 09:45 PM   #17
Woodroe's Avatar
Rewards Points: 18
Re: Concrete Deck
I believe the concrete contractor was an engineer (by education?)...
Woodroe is offline
Old 02-27-2015, 05:39 AM   #18
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,403
Re: Concrete Deck
Use dimpled tin pans so the tin is bonded to the deck...., 4 or 5kPSi crete would crack more but be stronger.... sealing the crete or covering as soon as it can be walked on with out damaging it would give maximum strength for the $
methods of fastening steel to joists make a large difference and the length of the sheets, the greater the # of 3 span vs 2 span the stronger the deck at the = cost of materials/labor mostly
Unskilled labor will over load the deck/trusses while pouring creating "pot holes" of way over thickness, I NEVER walk under illegals/lazy/under manned pouring floors/roofs....
there is an elementary school in Iowa that has 12" thick spots on a 5" design deck, bowed decking on bowed red iron way past D= L/300....
If the ceiling is hanging several inches below the bottom of the trusses, up size the truss depth and use fewer with a tiny bit thicker floor, saving $$ for the GC and big money for the mechanical, Hvac and electrical subs.
Fouthgeneration is offline
need help on bidding for concrete jobs! Bconcretegirl Marketing & Sales 15 12-04-2013 12:25 PM
Summer deck projects C2projects Decks & Fencing 149 01-16-2013 12:24 AM
concrete slab HUDSONVALLEYEXT Construction 4 06-04-2012 12:45 PM
sanding/scarrfying existed painted concrete pool deck ferd144 Masonry 7 01-16-2012 02:07 PM
Concrete pool deck concern montero00 Masonry 3 11-26-2011 12:37 AM
