Cement Block Pier Adjustable Bracket - Construction - Contractor Talk
Old 05-20-2015, 11:25 AM   #1
mac_will's Avatar
Trade: general contractor
Rewards Points: 6
Hello,
I am building a small addition to a cottage that is built on concrete block piers on 2x2 footings. The soil is sand and nothing moves according to the owners. The plans is to build the addition on 8 new footings with similar concrete block piers up to the support beams. It is a very simple 1 story building and the crawl space under the building is open and not heated. (it is located in Canada) I sub contracted the footings and I am looking for a good solution to build the concrete block piers up to the right height (all 8 are different heights ranging from 1' to about 4'.)
Options I am considering:
Blocks capped with a few layers of bricks
PT wood shims
Some sort of adjustable bracket to sit the posts on
I was wondering what people thought would be best and if anyone has any bracket suggestions?
Thanks.
Mac
mac_will is offline
Old 05-20-2015, 04:59 PM   #2
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
Re: Cement Block Pier Adjustable Bracket
put the bricks and/ or plywood shims at the bottom.
That way nobody will see them..
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
Old 05-21-2015, 07:22 PM   #3
Knight-Builder's Avatar
Trade: Builder
Rewards Points: 526
With any luck, you've subbed it to a contractor that can anticipate the height multiples of the blocks and can locate the bottom of his footings on undisturbed soil accordingly.
Out of curiosity, how did you get out of not having to go below frost level to meet code? We'd never get passed that in this area, unless it's engineered for such.
Knight-Builder is offline
Old 05-22-2015, 07:39 AM   #4
mac_will's Avatar
Rewards Points: 6
Ya right. Not likely that this will happen.
As far as I know the National Building Code of Canada does not require all foundations to be bellow the frost penetration depth. In fact, is may be contrary to code to mix foundation types such that the addition does not move in the same fashion as the main building.
I don't have the code reference(s) with me but see Table 3 of appendix A here (http://www.cmhc-schl.gc.ca/odpub/pdf/61010.pdf)
In this situation I am dealing with coarse grain soil (sand), no heat, and great drainage.
I am really looking for ideas/opinions around some sort of adjustable bracket. If I recall the code correctly I need to fill the cement blocks with concrete (at least the top 4 inches) so why not use a bracket if I can find a good one.
Something like this but not for decks: http://www.homehardware.ca/en/rec/in...jwf/R-I2683023
mac_will is offline
Old 05-22-2015, 12:59 PM   #5
Trade: Builder
Rewards Points: 526
As the GC, you could specify that it happens (making sure they understand the blocks must finish at a specified height - matching the existing block foundation heights). Shims/packers, unless absolutely necessary, just present an additional potential problem area... a shim that shrinks 1/4" within a year (or even wedged shims that loosen) can equal an awful lot more in settling and separation on the indside where new meets old.
As for matching new foundations to old, you're lucky. We're currently on an addition job in Ontario and the inspector insisted the new stuff goes on footings below frost (circa 6 ft here). Meanwhile, the rest of the cottage is on blocks. Thankfully, the property owner understands the likelihood of a differential in movement between new and old from freeze to thaw.
Anyway, good luck with the job!
Compressed Earth Block Construction Jaws Construction 12 02-07-2013 03:33 PM
Fixing deteriorating block face. NYCB Masonry 11 04-14-2011 06:23 PM
Cutting Fiber Cement Burns-Built Windows, Siding and Doors 7 01-25-2010 10:27 PM
block work rebar question paintbob7 Masonry 4 05-31-2009 10:46 AM
window return in concrete block house bmancanfly Remodeling 10 05-15-2009 03:30 AM
