Building An Open Wall Shed Off A Steel Building. - Construction - Contractor Talk
Old 02-04-2013, 10:31 AM   #1
mbobbish734's Avatar
Trade: Property Preservation & Remodeling
I'm wanting to build a shed off of my pole barn on one side. Nothing special just something to keep rain and snow off of my tractor and stuff. The barn is corrugated steel and the shed will be wood with shingles. My concerns are how to flash the roof to the corrugated steel. Any ideas?
mbobbish734 is offline
Old 02-04-2013, 10:41 AM   #2
donerightwyo's Avatar
Trade: custom builder
Rewards Points: 100
Re: Building An Open Wall Shed Off A Steel Building.
I would cut the steel so that it can be flashed properly. Anything else is gonna leak. You should cut a section out to properly attach your ledger anyway.
I can't compete with hacks.
donerightwyo is offline
Old 02-04-2013, 11:23 AM   #3
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,222
Second that thought, any other way will turn out to be a mess.
Randy Bush is offline
Old 02-04-2013, 11:31 AM   #4
stombaugh85's Avatar
Trade: Roofing
Rewards Points: 284
Where are you looking to tie into? On the end wall or side wall.
stombaugh85 is offline
Old 02-04-2013, 11:34 AM   #5
Back end wall.
Old 02-04-2013, 11:37 AM   #6
I can see cutting it in, I just don't know what kind of support is behind it. The inside has corrugated steel also.
Old 02-04-2013, 11:56 AM   #7
Randy Bush's Avatar
If it is a normal pole barn it have girths running horizontal to fasten the metal to. Should be able to figure out the pole spacing , Cut the metal where the bottom of the ledger board will be , and I would remove the metal above there, put shed roof on , flash and replace metal above it. Really not not to hard of a job to do just a little time.
Old 02-04-2013, 11:59 AM   #8
Trade: Roofing
Rewards Points: 284
Yup, going to have to cut the steel to install legder. Just a basic L" Flashing should work for shingles. Of course the degrees of your roof slope. Install behind steel and over shingles. I would install a base trim for looks but not needed. I would also remove the steel so I could install ice and water membrane also.
Old 02-04-2013, 12:07 PM   #9
Rewards Points: 100
Double post
Shear Wall Plywood Nailing & Structural Issues sbebuilders Framing 12 02-04-2013 11:35 PM
NEED HELP ASAP with Futures Steel Arch building robbinscards Welding & Steel Trades 4 12-26-2012 08:59 PM
Steel Tubing Lintel Strength 6stringmason Masonry 16 10-04-2012 09:12 PM
Masonry Wall Art Picbrick junie General Discussion 4 07-26-2012 03:51 PM
can any one id this wall sensor HUDSONVALLEYEXT General Discussion 8 06-15-2012 07:20 AM
