Brick Veneer On Foundation Only - Construction - Contractor Talk
Old 03-11-2019, 09:56 AM   #1
wooddoug1's Avatar
Rewards Points: 2
We often use brick veneer on the foundation of vinyl siding homes. This presents anchor bolt placement difficulties, especially on slab houses or on the garage of crawl space houses.
To be clear, in this situation the exterior wall is sitting on the brick. In the past I have cut away the inside of the bricks where the anchor bolts go, and then bent the bottom of the anchor bolt in to the thickened slab. This is very labor intensive and a little sketchy, although allowed by local inspectors. I have considered switching to split face header blocks rather than brick.
Does anyone have a more efficient method of solving this problem?
wooddoug1 is offline
Old 03-12-2019, 09:10 PM   #2
Kblank11's Avatar
Trade: Homes
Re: Brick Veneer On Foundation Only
We use Stone Veneer on our Custom Outdoor Kitchens! maybe an engineer could help
Kblank11 is offline
Old 04-13-2019, 10:22 AM   #3
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Bending the anchor bolts is not a little sketchy,it is a lot sketchy. Even if the inspector is alright with it,it is a bad practice and if not mistaken,against code.
Depending on height of veneer,how about casting stab bolts into concrete brick ledge. They are longer and stouter.
fjn is offline
What qualities should a brick possess ? fjn Masonry 2 12-29-2014 07:41 PM
Thin brick or stone veneer over existing brick wall red_cedar Masonry 5 08-01-2014 12:58 AM
Deck attachment with brick veneer jar546 Carpentry 5 08-23-2013 07:47 AM
Brick Veneer installation issue/questions.. ferd144 Masonry 19 01-14-2013 09:39 PM
thin brick veneer michiganmason Masonry 8 12-31-2010 07:37 PM
