Bluwood Or Other Pre-treated Lumber - Construction - Contractor Talk
Old 02-07-2019, 03:15 PM   #1
GCLA's Avatar
Rewards Points: 8
Building custom home in a termite-prone environment. Anyone have experience building with Bluwood or other pre-treated lumber? I welcome opinions.
House will have a basement. Worth just doing just for the basement, to also have the mold/rot preventive effects? If done just in the basement, does this offer any termite prevention benefits even if main floor done in regular, untreated lumber?
Thanks.
GCLA is offline
Old 02-08-2019, 07:08 AM   #2
TimNJ's Avatar
Rewards Points: 6,838
Re: Bluwood Or Other Pre-treated Lumber
What are doing a wood foundation?
If termites are that bad I would build the whole place out of treated.
TimNJ is offline
Old 02-09-2019, 07:23 AM   #3
builditguy's Avatar
Rewards Points: 2,080
Doesn't answer your question, but what about building out of steel?
builditguy is offline
The Following User Says Thank You to builditguy For This Useful Post:
griz (02-09-2019)
Old 02-09-2019, 07:34 AM   #4
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,246
You can have a basement pretreatment before you pour the slab. Get a termite guy out there to check it out after the hole is dug.
Big Johnson is online now
Old 02-09-2019, 05:21 PM   #5
rblakes1's Avatar
Rewards Points: 3,940
They sheathed my entire house in 1x6 t&g cedar, I haven't seen any signs of termite damage yet
rblakes1 is offline
Old 02-09-2019, 09:48 PM   #6
Talking Head
EthanB's Avatar
Rewards Points: 438
Doing the inside of the basement in PT because of termites doesn't make much sense to me as that means they're already in the house and it needs to be treated. It's definitely a good idea for exterior wood. Make sure that you are identifying the actual preservative used on the product and check the insecticide and concentrations effectiveness against termites, e.g ACQ .6, MCA .15, etc..
Planer.....
EthanB is offline
Old 02-09-2019, 10:16 PM   #7
Fire up the BBQ
griz's Avatar
Rewards Points: 2,004
have a termite guy pre-treat under & around structure.
for liability reasons, i would have the architect spec out what lumber to use where.
it would not be my call.
griz is online now
rescraft (02-10-2019)
Old 02-10-2019, 05:24 PM   #8
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Here in FL we have 2 types of homes, home's that have termites and home's that will get termites, having said that if you disturb soil you treat for mites even if I do a slab outside for a lanai I have to treat for mites.
Most homes here the first floor is block and after that stick, all the furring strips these days are blue along with pt bottom plates for int walls on slab, then when all first floor framing is done we treat the first 24 inches or so up from the slab.
The other thing we like here is a in wall pest defense system I would never build below grade with wood.
The only time I see stick built these days are fast food and apartments
Still "Shakin" the tree boss
sunkist is offline
Are you seeing an increase in lumber prices? Cricket General Discussion 0 10-09-2017 02:04 PM
Treated lumber and membrane roofs? 232323 Roofing 6 11-22-2013 01:54 PM
Pressure treated used in walls Tile man Dan Historical Restoration 21 08-10-2009 08:28 PM
Sticker will ID engineered lumber for firefighters JonM General Discussion 15 08-02-2009 09:03 PM
Wall framing using pressure treated lumber ChuckEA Carpentry 5 03-03-2006 11:23 PM
