Best Practices Prior To Drywall Close In - Construction - Contractor Talk
Old 06-23-2015, 10:49 PM   #1
3 Jacks 2 Nines
bwiab's Avatar
Trade: Wannabe Homebuilder
Rewards Points: 290
Hey Guys,
Was thinking about checklists we used in the commercial realm after/during rough in and prior to drywall. Realized that some of that could be useful/required in the residential world, but wasn't too sure about it. Couple of questions for you. Appreciate your insight. For these purposes, let's assume this is new construction.
1. Is a plumbing pressure test required in residential construction. Seems like good practice to me. Do you do this as part of your quality control? Code requirement? Water and waste line?
2. What would be a comparable electrical test? Low voltage?
3. Does hvac balancing occur in residential new construction? Do you check for leakage prior to drywall?
4. What checks would you do for insulation? Visual inspection for continuity of barrier?
5. Do you check for blocking in the correct places?
Any other thoughts?
bwiab is offline
Old 06-23-2015, 11:24 PM   #2
JesseCocozza's Avatar
Rewards Points: 810
Re: Best Practices Prior To Drywall Close In
This is per code here.
Nothing in place so far as I know.
Not typical as units aren't usually even powered up prior to drywall, and usually the condensing units aren't even installed until landscaping is going on. So, long after drywall is done.
We have an insulation inspection here. I believe it happens prior to framing inspection.
Naturally any firestop / draft stop blocking would be inspected during framing inspection. Otherwise accessory blocking is usually defined in the SOW with framer and GC and is usually inspected by superintendant prior to drywall.
Only other thing we do is mark out with red marker or paint where anything major is in the wall (plumbing / electrical) at the floor so the trim carpenters know not to nail screw in that area.
JesseCocozza is offline
The Following 2 Users Say Thank You to JesseCocozza For This Useful Post:
bwiab (06-23-2015), griz (06-23-2015)
Old 06-23-2015, 11:41 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 2,290
I have the same answers as Jesse.
griz is online now
Wood framing/furring for suspended drywall ceiling akm Carpentry 30 04-24-2013 09:42 PM
consequences of improper steel stud drop ceiling installation mohdmaruf Drywall 29 04-02-2013 11:43 PM
"Quick" drywall patch robert c1 Drywall 23 01-23-2013 06:10 PM
wanting set of 24' aluminum pump jacks, buy or rent. close to western Pa vaughn59 Contractor Swap 0 06-03-2012 09:18 PM
Looking for drywall hangers and finishers near Pittsburgh, PA Loren Porter Help Wanted or Looking For Work 0 01-25-2010 09:20 PM
