Basement Egress Window: Minimum Height? - Page 2 - Construction - Contractor Talk
Old 04-13-2015, 10:02 AM   #21
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,368
Re: Basement Egress Window: Minimum Height?
Originally Posted by Tom M View Post
The same thing is in the 2015 IBC but it changed slightly. It's 36" instead of 24". And it refers to an ASTM which we don't know what it is.
KennMacMoragh is online now
Old 04-14-2015, 01:00 AM   #22
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,797
How is a baby/toddler supposed to fall out of a BASEMENT window with all due respect to Eric Clapton and the ASTM?
Egress windows installed above basement levels perhaps?
Window with less than 18" above FFL do need tempered glass though?
Fouthgeneration is offline
Old 04-14-2015, 04:13 AM   #23
They won't, but that's not in the code we're referring to. There's a minimum height.
Old 04-14-2015, 06:08 AM   #24
General Contractor
greg24k's Avatar
Rewards Points: 8,676
IBC is more strict than IRC, so most Architects specify IRC for residential construction.
With that said, Tom is right , you have to keep in mind the 612 code. Because if you have a daylight or walkout basement 72" measured from the lowest surface of the opening, i.e bottom of a window well, etc and not the grade. So if there is a window on the first floor with a sill height less than 24" from the floor, a window should have a safety stop on it to prevent it from opening more than 4" or window guards or other safety devices must be installed.
greg24k is online now
Old 04-14-2015, 10:45 PM   #25
What's the 2015 IRC say in that section?
Old 04-15-2015, 12:29 AM   #26
Trade: Masonry
Nanny State 2.0, An Egress window is actually an emergency Door/Exit........
Wait till the Regulators get around to making doorways "safe" for mankind.
But an egress window well without a ladder a kidd or grandma can climb is pretty silly/sad.
So the broken glass (untempered) in the basement nursery isn't an issue?
Old 05-28-2015, 04:17 AM   #27
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
18" here before tempered
jlsconstruction is offline
Window trim install MattK Windows, Siding and Doors 24 05-18-2013 10:19 AM
Leaking window MEL Masonry 33 02-03-2013 09:12 AM
Pressure Washing & Window Cleaning Tips Jas2012 New Member Introductions 13 08-14-2012 05:22 PM
Window Height RedOak Windows, Siding and Doors 9 08-14-2011 12:27 PM
