Basement Egress Window: Minimum Height? - Construction - Contractor Talk
Old 12-29-2014, 04:24 PM   #1
jacselee's Avatar
Rewards Points: 204
Is there a minimum height off of finished floor for a basement egress window? I know Max is 44" but can't seem to find minimum
jacselee is offline
Old 12-29-2014, 04:27 PM   #2
Lugnut1968's Avatar
Trade: Painting and Finish Carpentry
Rewards Points: 460
Re: Basement Egress Window: Minimum Height?
Which state? .. and at times... which county in that state...
Lugnut1968 is offline
Old 12-29-2014, 04:28 PM   #3
CompleteW&D's Avatar
Trade: Windows, Doors, Siding, Enclosures
Rewards Points: 2,936
I would think that a minimum height from the floor would be irrelevant. The maximum height is there for a reason obviously, but I wonder if a minimum height makes a difference.
Obviously, I haven't got a clue and would like to know as well.
- John Williams
Complete Window and Door
Originally Posted by TNTSERVICES View Post
As accomplishments go, getting me to talk is an easy one.
CompleteW&D is offline
Old 12-29-2014, 04:39 PM   #4
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
I would like to know what happened with the last couple of problems the OP has asked for help with ???
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
Old 12-29-2014, 05:36 PM   #5
Tom M's Avatar
Rewards Points: 3,538
No minimums, only tempering kicks in.
Afterall you could put a sliding door in there if you want.
Tom M is online now
The Following 5 Users Say Thank You to Tom M For This Useful Post:
CarpenterSFO (12-30-2014), concretemasonry (03-29-2015), greg24k (04-14-2015), hdavis (12-29-2014), Keeyter (12-29-2014)
Old 12-29-2014, 05:54 PM   #6
XJCraver's Avatar
Trade: Building Official
Rewards Points: 28
No minimum. From the '09 IRC:
R310.1 Emergency escape and rescue required. Basements, habitable attics and every sleeping room shall have at least one operable emergency escape and rescue opening. Where basements contain one or more sleeping rooms, emergency egress and rescue openings shall be required in each sleeping room. Where emergency escape and rescue openings are provided they shall have a sill height of not more than 44 inches (1118 mm) above the floor. Where a door opening having a threshold below the adjacent ground elevation serves as an emergency escape and rescue opening and is provided with a bulkhead enclosure, the bulkhead enclosure shall comply with Section R310.3. The net clear opening dimensions required by this section shall be obtained by the normal operation of the emergency escape and rescue opening from the inside. Emergency escape and rescue openings with a finished sill height below the adjacent ground elevation shall be provided with a window well in accordance with Section R310.2. Emergency escape and rescue openings shall open directly into a public way, or to a yard or court that opens to a public way.
Exception: Basements used only to house mechanical equipment and not exceeding total floor area of 200 square feet (18.58 m2).
XJCraver is online now
Old 12-29-2014, 06:24 PM   #7
danjann's Avatar
Rewards Points: 80
Just remember under a certain height you may be required to use tempered glass. I think here in MI it's anything under 24".
danjann is offline
The Following User Says Thank You to danjann For This Useful Post:
Old 12-30-2014, 03:38 AM   #8
CarpenterSFO's Avatar
Rewards Points: 2,044
Yes, you're unlikely to fall to your death out of a basement window with a low sill, but yes, tempered.
- Bob
CarpenterSFO is offline
The Following User Says Thank You to CarpenterSFO For This Useful Post:
Old 12-30-2014, 09:15 AM   #9
Tom M's Avatar
Well guards and fall potential is another consideration if it were not as you pointed out a basement.
Tom M is online now
Old 01-13-2015, 11:20 PM   #10
4uRemodel New york
4uremodel's Avatar
Trade: general contractor
Rewards Points: 42
as long people can get out from the basement in case of emergency , i guess its ok
but i recommend to check with the town before doing anything about it , have permit its good
4uremodel is offline
Old 03-29-2015, 10:42 PM   #11
Anti-wingnut's Avatar
Rewards Points: 3,414
Above the dirt
Anti-wingnut is offline
Old 04-12-2015, 08:55 AM   #12
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,262
I am working on a house that has its basement windows right at the concrete floor. We will be raising them a few inches only to make room for baseboard. Even for second floor or higher windows there is no minimum I'm aware of. That might change someday with all the deaths and accidents from kids falling out windows.
KennMacMoragh is offline
Old 04-12-2015, 09:59 AM   #13
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,220
Daylight basement? I would think that the tempered glass rule might come into play here as much as anything.
Randy Bush is online now
Old 04-12-2015, 11:39 AM   #14
Not sure about the tempered glass, architect specified the windows so I'm assuming he got them right.
Old 04-12-2015, 11:50 AM   #15
kiteman's Avatar
Rewards Points: 16
Here we have to be tempered within 14" of the floor or x inches from a door.
An old framer once told me "For years I thought I was the best damn carpenter in California. Come to find out I'm just competent."
kiteman is offline
Old 04-12-2015, 01:01 PM   #16
Tom M's Avatar
The code does have a rules for window guards. If your 6 ft off the ground you need to have a minimum 24 inches off the floor and either a limiting device on the window or a guard to prevent falls.
It should bein the building planning section of the code but its at the end of the wall section. I always forget where it is.
Tom M is online now
Old 04-12-2015, 03:22 PM   #17
Do you know the exact section in the code? It must be new because I framed hundreds of houses with 12" high window sills, no guards or anything. All on second stories.
Old 04-12-2015, 03:51 PM   #18
Tom M's Avatar
Its not that new. Look in 612
Tom M is online now
Old 04-13-2015, 09:27 AM   #19
Are you talking IBC? There is no 612.
But this is a new one, 1015.8, http://www.astm.org/Standards/F2090.htm There is a bar beside the code in the 2015 IBC. But you have to pay $50 to find out what it is.
Old 04-13-2015, 09:47 AM   #20
Tom M's Avatar
No IRC. Here I found it for you.
http://publicecodes.cyberregs.com/ic...9_6_par294.htm
Tom M is online now
Window trim install MattK Windows, Siding and Doors 24 05-18-2013 10:19 AM
Leaking window MEL Masonry 33 02-03-2013 09:12 AM
Pressure Washing & Window Cleaning Tips Jas2012 New Member Introductions 13 08-14-2012 05:22 PM
Window Height RedOak Windows, Siding and Doors 9 08-14-2011 12:27 PM
