Base For Concrete - Construction - Contractor Talk
Base For Concrete
Old 03-23-2019, 12:13 PM   #1
arudam's Avatar
Trade: Paving stone
Base For Concrete
Hey all, We built an ICF Pool, and still have one section of the floor to pour. This section is in a shallow end so it is raised about 3 feet off an already poured concrete pad, id like to get this poured soon, i had wanted to continually soak this fill with water to get great compaction but since the walls are ICF and the floor beneath the fill is already concrete, is it an issue if the fill is at all wet prior to pouring on top since technically the moisture would be trapped for good after all the concrete is complete? There will be rigid foam under the new pad as well, it has hydronic floor heat. Does this make sense?
arudam is offline
Old 03-23-2019, 12:18 PM   #2
arudam's Avatar
Trade: Paving stone
Re: Base For Concrete
This sectiom has a solid sealed concrete base already, with about 2-3 feet fill above, and will have concrete floor placed on top now
arudam is offline
Old 03-23-2019, 02:47 PM   #3
buildercn's Avatar
Trade: Construction Management
Rewards Points: 146
I wouldn't pour on top of the wet fill. It's likely to cause issues down the road. Once the moisture drys out it could heave or sag on you.
Maybe consider replacing the fill with u-fill or an engineered fill to backfill it? Neither of those require compaction. U-Fill would take a day to set up but the engineered fill could be poured over the same day.
Construction Project Manager - 10+ Years
Toronto Market - Construction Manager
buildercn is offline
Old 03-23-2019, 02:51 PM   #4
dayexco's Avatar
Rewards Points: 660
you over saturated the soil in hopes of compaction? or did i read that wrong?
what happens when that water migrates out of your excavation? personally, i'd have a civil look at it and give you a plan of attack.
cracks or structure failure isn't worth it.
dayexco is offline
Old 03-23-2019, 02:59 PM   #5
arudam's Avatar
Trade: Paving stone
Thanks guys, I thought of saturating it to assist in compaction but so far have done nothing. removing the fill wouldnt be very fun. Its 2ft deep of fill so not really much (in a 12'x10' area), i could just run my small packer over it a bunch. So far it should still be relatively dry as the fill was dry when i put it down in fall and it has been tarped over winter. being completely sealed would the moisture ever actually leave? grade 10 science has long come and gone lol i would be more worried about heaving in winter as oppose to the fill settling as its a 6" pad getting poured , rebar 12" o.c.
arudam is offline
Old 03-23-2019, 04:37 PM   #6
dayexco's Avatar
Rewards Points: 660
Have you ever seen soil from am excavation that comes out in layers of light clay, heavier clays, layers of course gravel, and layers of fine sand.
Now they're all mixed in your spoil pile and a combination/compaction of dissimilar soils can create problems with future soils expansion and shrinkage due to moisture content of soils changing.
I agree with above, get that soil you placed in the excavation pulled, and go with flowable fill.
Sent from my SCH-I545 using Tapatalk
dayexco is offline
Old 03-23-2019, 10:56 PM   #7
GC/carpenter
Calidecks's Avatar
Rewards Points: 9,138
We are required by our engineers to completely saturate soil that's got a high content of clay in some cases. Then pour a structural slab on top. The idea is to expand the clay first to prevent heaving. Then a structural slab should be designed well enough to support itself if the clay shrinks.
When I say saturate I mean able to stick a prod into the soil about 12 inches without a lot of force.
Mike.
_______________
Calidecks is online now
Rio (03-24-2019)
Glue for rubber cove base to FRP panels? TIGHTER MITER General Discussion 3 10-09-2014 10:23 AM
Replace Base, Caulk, Paint - Without Recutting in wall paint? Spencer Painting & Finish Work 24 08-28-2014 01:03 AM
base trim on island Kent Whitten Finish Carpentry 40 03-03-2012 01:14 AM
Scaffolding - Base Width Question ZachElwood Health & Safety 2 11-09-2010 02:09 PM
Router Table base cabinet. ApgarNJ Tools & Equipment 83 11-06-2010 12:39 AM
