Bad Pour. Lots Of Honeycombing - Construction - Contractor Talk
Old 03-24-2019, 04:53 PM   #1
DKMarty's Avatar
Trade: Concrete
Rewards Points: 4
We had a bad wall pour.. Results are a lot of honeycombing and segregation of concrete (In some places we can see the original colors of the small rocks used. It's like they never touched cement paste)
The wall is 7inch thick with a good deal of rebar in it. It is a wall inside the house, so no water intrusion worries there. The wall must carry a first floor deck, appr 3 tonnes per meter wall.
We have chipped off some of the honeycombing, as seen in the pics. It comes off quite easily with a hammer. Some places I can chip it off almost through the entire wall. Other places It's more superficial.
Is this wall usable if we simply chip off the honeycomb and replace with non-shrinking grout?
IMAGES
https://imgur.com/a/h60m7QN
DKMarty is offline
Old 03-24-2019, 06:20 PM   #2
Joseph A. Capece
CENTERLINE MV's Avatar
Trade: Builder - General
Rewards Points: 1,432
Re: Bad Pour. Lots Of Honeycombing
You’re joking.....
Follow us on FACEBOOK
www.centerlinebuilders.net
Martha's Vineyard General Contractors - Builders -
Commercial/Residential - Additions - Renovations
CENTERLINE MV is offline
The Following 2 Users Say Thank You to CENTERLINE MV For This Useful Post:
Bull Trout (03-24-2019), dayexco (03-24-2019)
Old 03-24-2019, 06:48 PM   #3
buildercn's Avatar
Trade: Construction Management
Rewards Points: 146
Check with your engineer, there are procedures to fix this. In areas where it's particularly bad they may ask you to chip it back to the rebar, re-form and repour the areas.
I've personally repaired areas that are far worse that what you have here.
Construction Project Manager - 10+ Years
Toronto Market - Construction Manager
buildercn is offline
Old 03-24-2019, 06:55 PM   #4
dayexco's Avatar
Rewards Points: 762
were i the project owner, it'd be tore out, and somebody else replace it.
i'm sure they don't want to pay for a repaired new wall
dayexco is offline
The Following 2 Users Say Thank You to dayexco For This Useful Post:
Bull Trout (03-24-2019), Calidecks (03-25-2019)
Old 03-24-2019, 07:15 PM   #5
Joasis's Avatar
Rewards Points: 1,938
It would cost as much, IMO, to repair that, then it would to simply reform it and repour it.
I know what we would do if it was on our job sites, or if an inspector was on site.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
The Following 2 Users Say Thank You to Joasis For This Useful Post:
Old 03-24-2019, 11:56 PM   #6
Bull Trout's Avatar
Rewards Points: 134
Why are you pouring walls in the middle of the city dump?
Bull Trout is offline
Old 03-25-2019, 12:09 AM   #7
GC/carpenter
Calidecks's Avatar
Rewards Points: 10,042
Do you not vibrate that?
Mike.
_______________
Calidecks is online now
Bull Trout (03-25-2019), ScipioAfricanus (03-25-2019), Seven-Delta-FortyOne (03-25-2019)
Old 03-25-2019, 05:28 AM   #8
rjconstructs's Avatar
Trade: Residential remodel
Rewards Points: 322
It almost looks like someone mixed that by hand.
Vibrating the concrete would have helped tremendously.
How much rebar is in it?
What is the mix design of the concrete?
I'm guessing this is a customers house? What do they think?
rjconstructs is online now
Old 03-25-2019, 05:40 AM   #9
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,840
Mike.
_______________
I've never seen that type of form before, but I bet that they wouldn't stand up to vibrating.
It looks like an ICF with no I, bad C, and barely any F.
Home Designer Series Software
B.Johnson is offline
The Following 2 Users Say Thank You to B.Johnson For This Useful Post:
Bull Trout (03-25-2019), Calidecks (04-02-2019)
Old 03-25-2019, 08:04 AM   #10
Joasis's Avatar
I tried to do a search for that style of ply form, and no luck. Looks interesting. But with the number of ties, it would have to be expensive as hell...but any snap tie system can be expensive.
You can buy a style of ICF connector that is screwed to plywood, and they remain in place when you strip.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
My Facebook Page
Joasis is offline
Old 03-25-2019, 10:23 AM   #11
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,834
$#Itty job.
Looks like a hand mix, with possibly multiple cold joints, no vibration or consolidation at all, and a messy job site.
What could go wrong?
Yes, it can be fixed.
Yes, it should be fixed.
No, you shouldn't fill it with mortar. It should be cut out and re-formed, and re-poured.
Bathe 'Em, Baptize 'Em, and Brand 'Em.
Old 03-25-2019, 11:58 AM   #12
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
oh my...
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Old 03-26-2019, 04:53 PM   #13
DKMarty's Avatar
Trade: Concrete
Rewards Points: 4
Thanks for the replies.
Yes it's an ICF-system. Well spotted! The ply-forms are removed after pouring, so one ends up with EPS on one side and raw concrete on the other. The forms can be reused and can also be used for walls without EPS in which case one uses the ply forms on both sides. Thats what we did here.
The concrete supplier sent a specialist to look at the wall and he deemed the it as "certainly usable" for the purpose it's intended to fulfill.
The rationalization for this was
A a rebound hammer test shows the wall as absolutely fine
B The honeycombed areas do not chip off that easily. It takes the backside of a hammer or some other sharp object to get the stones out.
He advised us not to chip off anymore honeycombing. Just to coat it with some special two-component mortar in two layers with the same product.. First coating should be mixed to a thin solution, second to a thicker solution.
DKMarty is offline
Old 03-26-2019, 05:43 PM   #14
John the Builder
My take is you are across the pond.
All I can say is - you folks get away with chit there that would be buried here like a cat discovering he accidentally pooped on the carpet.
Old 03-26-2019, 05:45 PM   #15
rblakes1's Avatar
Rewards Points: 4,012
Are they going to take responsibility if their solution fails in the future?
-Rich
rblakes1 is offline
Old 03-26-2019, 07:11 PM   #16
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,784
I’d be finding a new redi-mix supplier.
Big Johnson is online now
Fouthgeneration (04-03-2019)
Old 04-02-2019, 10:00 PM   #17
buildercn's Avatar
Rewards Points: 146
Big Johnson is right - I'd review with your concrete supplier as well. That could be the problem.
The Following User Says Thank You to buildercn For This Useful Post:
Lots of self-leveling cement? onmywayup General Discussion 15 08-11-2017 07:15 AM
Pour stop for concrete over corrugated steel CENTERLINE MV Commercial Construction 33 02-21-2015 09:13 PM
Pizza oven pour htieksquest Masonry 8 08-17-2014 12:18 PM
Im getting lots of leads BUT wellbuilthome General Discussion 20 09-11-2008 08:13 PM
