Any Advice For Installing Suspended Ceilings Faster? - Construction - Contractor Talk
Old 01-23-2017, 10:42 PM   #1
Stevarino's Avatar
Trade: General contractor specializing in kitchen and bath remodeling and design
Rewards Points: 415
I am familiar with suspended ceilings. I have installed many. We do a lot in basements and so forth. However I have a commercial job coming up that is 3,000 Sq ft of drop ceiling. We are removing old grids and panels and installing all new. Being that this is 6x larger than any drop ceiling I've done I'm looking for any tips and tricks to speed things up.
I have a stabilator 360 laser that I set up my perimeter line with and I also use it to mark where to bend my drop wires. The laser I know is a huge time saver.
These will all be beveled 2x2 panels that will need back cut along the perimeter which from my experience tends to be one of the most time consuming tasks. I have one person cut and install the panels and then one of us comes behind with a utility knife and marks and back cuts the panel.
Do the make anything better at this task than a utility knife? It is very easy to booger an end and then the tile is trash.
Thoughts? I don't do drop ceilings every week or even every month so I'm hoping there are some tricks or tools I'm unaware of.
Stevarino is offline
Old 01-24-2017, 08:16 AM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 986
Re: Any Advice For Installing Suspended Ceilings Faster?
I've known about this tool for some time, but never quite got around to picking one up. Let us know how it works for you.
https://www.amazon.com/TOOLPRO-05110.../dp/B000A1BDAU
Tinstaafl is offline
asevereid (01-24-2017)
Old 01-24-2017, 10:02 AM   #3
rustyjames's Avatar
Rewards Points: 1,818
I can verify that tool is well worth the little it cost.
rustyjames is offline
Old 01-24-2017, 10:37 AM   #4
Anti-wingnut's Avatar
Rewards Points: 3,430
A 3000 square foot commercial cieling is a different beast than a 500 square foot basement. Depending on your siesmic area you'll need to know if:
1) Are Berc clips required on the perimeter?
2) What are the requirements for bracing and siesmic pods?
3) Who will install the light wires? Will this be an extra to you?
4) Who will install the sparkies wires to pickup their EMT or MC?
5) Who will install support wires for the HVAC diffusers and returns?
6) Will you require a seperation joint?
7) What size wall molding is required? 2" or 3/4"?
Anti-wingnut is offline
The Following 2 Users Say Thank You to Anti-wingnut For This Useful Post:
griz (01-24-2017), Rio (01-24-2017)
Old 01-24-2017, 05:03 PM   #5
Stevarino's Avatar
Rewards Points: 415
Well the nice thing is that the largest area isn't probably more than 400-500 Sq ft. Mostly offices and hallways. Sparky is coming behind me to swap out all the lights so I don't have to deal with electrical.
The scope of work is right in line with what we have done just on a smaller scale.
Old 01-24-2017, 05:04 PM   #6
Stevarino's Avatar
Rewards Points: 415
I will definitely be picking up one of these tomorrow
Old 01-25-2017, 12:50 AM   #7
The size of the room doesn't neccesarily equal the size of the grid ceiling. I've done tens of acres of grid height offices, where the wall is actually attached to the grid ceiling. So never assume unless the plans, SOW or your own eyes tell you that the wall are taller than grid height.
Also make sure that a fire rated grid ceiling isn't required.
Old 01-25-2017, 02:49 AM   #8
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
Hire someone else, mark up their bid and collect the check.
But seriously, the tool Tins posted is pretty slick.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 01-25-2017, 07:24 AM   #9
builditguy's Avatar
Rewards Points: 2,078
The tool is a big time saver. There are a couple different models. I have the one above and I have a wooden one. Either are fine.
The laser is your best time saver. I also use mine to mark my wires. This saves a bunch of time in determining ceiling height. I use it to set the perimeter, then I determine the bend in my wire and set the laser up to that height. As long as you make sure you pull any slack out of the wire, when you make the bend on the laser, you will be good.
When I say slack, sometimes there is a slight curve in the wire, when it is tied off above. I've caught some guys just grabbing the wire with the pliers and making the bend. I want them to pull the wire down, then make the bend in the wire. Takes out any slack.
builditguy is offline
The Following 3 Users Say Thank You to builditguy For This Useful Post:
Joasis (01-25-2017), Sir Mixalot (01-25-2017), TNTRenovate (01-25-2017)
Master Bath remodel advice NINZAN STUDIO Remodeling 25 08-15-2013 07:36 PM
Any advice on how to clean this brick? shanekw1 Masonry 8 06-13-2013 09:39 PM
vaulted ceilings CJKarl Masonry 16 05-04-2013 07:40 PM
Van to truck advice please! renov8r Vehicles 47 05-01-2013 06:28 PM
? new work paint prices need advice! billderboots Painting & Finish Work 10 12-21-2008 05:58 PM
