Angled Footing Layout - Construction - Contractor Talk
Old 04-05-2020, 08:20 AM   #1
Tom M's Avatar
Rewards Points: 11,096
So I have a series of footings to dig, about 10 on an sloped terrain. Squaring a finished height and uniform footprint would be rather elementary positioning sono tubes.
However what I am going to attach is an "A" frame pipe configuration. So the plan view foot provided is based on a point where the legs of the "A" end up at 9' apart. They start at 10'6" They are recommended to be done in two stages. One to depth, place pipe onto footing then shim and top cover to secure.
This is going to be all over the place. Any keep it simple stupid methods to reduce my over thinking would be appreciated.
Tom M is offline
Old 04-05-2020, 10:15 AM   #2
Designer/Contractor
Rio's Avatar
Rewards Points: 1,058
Re: Angled Footing Layout
Having a little trouble interpreting the one drawing with the information given, maybe put up a few more referenced drawings, think it would help.
Rio is online now
Old 04-05-2020, 12:06 PM   #3
Tom M's Avatar
I know I couldn't get just the one page blueprint. I'll try again in a few
Tom M is offline
Rio (04-05-2020)
Old 04-05-2020, 12:11 PM   #4
Tom M's Avatar
It's a commercial grade galvanized swing set. So they give you a finished grade footprint with a recommended burial at 23" deep. Then shim and lock it in place.
So they diagram footing like that.
Tom M is offline
Old 04-05-2020, 12:19 PM   #5
Designer/Contractor
Rio's Avatar
Okay, so the diagram is of one of the off vertical supports that will hold up the pipe up in the air that the swing will connect to, correct?
I would think the tricky part on that would be to get the angle correct for all 4 supports, would probably make a simple jig of some sort to use to check the hole as I excavated it, just something out of plywood and some 2x stock, have one piece plumb and the other at the angle of the dangle?
Rio is online now
Old 04-05-2020, 12:40 PM   #6
MarkJames's Avatar
Rewards Points: 18,855
How about just digging straight down, allowing for a bell shape on the bottom to lock it in place? Just a thought.
MarkJames is offline
Old 04-05-2020, 01:14 PM   #7
Tom M's Avatar
This was my initial thought but you need an excessive size footing diameter since the combined below grade/ angle would punch out the form towards the top.
Tom M is offline
Old 04-05-2020, 01:18 PM   #8
Tom M's Avatar
The set has 10 legs and it's on a slope. I totally thought about a jig.
It's also 10 ft high and we already assembled it because the owner wanted to fuss with specific placement.
Tom M is offline
Old 04-05-2020, 01:23 PM   #9
Tom M's Avatar
Im real temped to use my santagelo bar to dig it. I'll drive it parallel to the legs placement. Then pull a leg out finish hole, put leg back in and use a fast set mux........it's a challenge.
They should have a mounted receiver I could attach to the footing in normal fashion. Would make life easier.
Tom M is offline
Old 04-05-2020, 02:19 PM   #10
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,262
I'd just dig the footers however it was easiest, given the equipment I had. Would either run a power auger at an angle, or scoop them out with a narrow bucket on a mini excavator knowing they would be over sized. Not a big deal if you have to buy an extra yard of concrete, get it done and on the the next project.
Fishindude is offline
The Following 3 Users Say Thank You to Fishindude For This Useful Post:
Rio (04-05-2020), rrk (04-06-2020), tgeb (04-05-2020)
Old 04-05-2020, 02:49 PM   #11
Tom M's Avatar
Owner wanted this done for Passover. While we were placing rough location Friday a team of landscapers laid about 30 pallets of fresh sod.
I pushed for the machines to dig but too many sprinklers and wiring running around unmarked to risk it.
Tom M is offline
tgeb (04-05-2020)
Old 04-05-2020, 05:57 PM   #12
tgeb's Avatar
Rewards Points: 810
I think if I had to do this, I would dig vertical footings in the correct places.
Place concrete in each hole lasered in on level.
Set the swingset in place and fill around it with more concrete.
Probably would add some rebar into the footing so the two pours are tied together...
It is a swing set after all, not a bridge abutment.
Sent from my SM-G970U using Tapatalk
www.gebcon.com
tgeb is offline
The Following 2 Users Say Thank You to tgeb For This Useful Post:
Rio (04-05-2020), Tom M (04-05-2020)
Old 04-05-2020, 06:13 PM   #13
Tom M's Avatar
My brain keeps thinking that too but with less embedded pipe. I don't know why it should be 22" deep.
Tom M is offline
tgeb (04-05-2020)
Old 04-05-2020, 07:04 PM   #14
Designer/Contractor
Rio's Avatar
There's a lot of force being generated when someone's working it on a swing, better to err on the side of caution.
Rio is online now
The Following User Says Thank You to Rio For This Useful Post:
Tom M (04-05-2020)
Old 04-05-2020, 07:23 PM   #15
MarkJames's Avatar
I once toppled an anchored swing set with some friends. We were going for record height and had the idea we could achieve a loop-de-loop if we only tried hard enough.
Old 04-05-2020, 07:34 PM   #16
Tom M's Avatar
Manufacturer has poor instructions of course.
One drawing shows a 12" footing 16" in another.
Tom M is offline
Old 04-05-2020, 08:01 PM   #17
Tom M's Avatar
A visual
angled footing layout-swings.jpg   angled footing layout-plan-view.jpg   angled footing layout-elevation.jpg
Tom M is offline
Old 04-05-2020, 08:53 PM   #18
GC/carpenter
Calidecks's Avatar
Rewards Points: 8,592
I once toppled myself on a swingset. That was the first time I broke the left arm.
Mike.
_______________
Calidecks is online now
MarkJames (04-05-2020)
Old 04-05-2020, 10:20 PM   #19
tjbnwi's Avatar
Rewards Points: 3,958
No matter how hard I tried I never could do the loop-de-loop, don't no anyone who achieved the feat.
tjbnwi is online now
Old 04-06-2020, 07:47 AM   #20
rrk's Avatar
Rewards Points: 4,822
so much for social distancing
rrk is offline
