Anchoring Square Steel Bracing To 3' Steel Vertical Pole. - Construction - Contractor Talk
Old 04-03-2018, 01:01 PM   #1
ConceptCreation's Avatar
Trade: General Construction
Rewards Points: 8
Question
Hi Forum,
What ill be doing is anchoring steel bracing system for LED lighting to a 3' Diameter vertical steel hollow pole.
Steel square tubing is a 1.5"Hx1.5"Wx1/8"T that will extend from the vertical hollow pole out 6' with a slanted tube underneath to prevent bending/arcing with the shape of the entire brace being a y if you turn it counterclockwise 90 deg.
Ive had plates welded to the ends where the bracing will be secured from the brace to the pole.
Im considering using sleeve anchors. Is there a better anchor style I could use or would 1/2"+ sleeve anchors be suitable for this?
ConceptCreation is offline
Old 04-03-2018, 03:25 PM   #2
rustyjames's Avatar
Rewards Points: 1,818
Re: Anchoring Square Steel Bracing To 3' Steel Vertical Pole.
Sleeve anchors are typically used for attachment to masonry, your description sounds like you're connecting the steel square tube to the round tube? I would drill and tap, or drill and nut/bolt if you have access.
rustyjames is online now
Old 04-03-2018, 07:26 PM   #3
PacificCanvas's Avatar
Trade: Awnings
Rewards Points: 164
Go to a nut and bolt store and get some 3/8" or 1/2" self threading bolts. Then pick up the correct size drill bit that corresponds to whatever size bolt you got and pre-drill your hole then use an impact driver to set the bolt.
And get the Type 23, far superior than any of the others.
PacificCanvas is offline
Old 04-04-2018, 01:09 PM   #4
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,274
Why not just weld your hangar in place?
Fishindude is online now
Old 04-04-2018, 04:34 PM   #5
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Use a pipe hanger or strap a pipe bracket, or strut clamp.
[IMG]https://ae01.alicdn.com/kf/HTB1EaWhHV***Xa1XFXXq6xXF***a/Universal-Pole-Mounting-Bracket-Arm-Base-holder-for-CCTV-Security-PTZ-Camera-Bracket-clamp-With-Ring.jpg_640x640.jpg[/IMG]
Inner10 is offline
overanalyze (04-04-2018)
Old 04-05-2018, 10:35 AM   #6
Rewards Points: 8
the hanger is horizontal to the vertical pipe, so strapping wont work unfortunately
Thread forming or thread cutting bolts?
Edited:
Now im considering drilling and taping the holes.
Guess ill know once I get up in the air and make a few test holes
Old 05-28-2018, 12:33 PM   #7
madmax718's Avatar
Trade: General
Rewards Points: 3,276
Buy 6" steel pipe. Slice in half. Those are your mating brackets. To the vertical pole. Trace out the curve of the boxed end, grind to curve. Weld. I suggest you use use a horizontal joint on the top and vertical joint for the bottom. This will make final fitment way easier. Also drill and tap the pieces before mounting the arms. Will make life much easier. Then band clamp the adapters. The tapped bolts are to provide sheer strength. The clamp will provide tearout strength. The clamps you can get from a HD truck shop for a 6.5" exhaust, or make your own by threading and bending rod.
At least that's what I would do, but I do metal work as a hobby.
madmax718 is offline
Old 05-29-2018, 03:23 AM   #8
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,797
~ 3' diameter stainless steel "hose clamps" at the top and bottom of the "shingle" sign, double or triple as required for wind load, and ice?
Look at some local traffic light poles and all the "crap" attached to them...
See these "Hollo-bolts" at http://www.lindapter.com/american/Pr..._HB_Hollo-Bolt
Fouthgeneration is offline
Old 05-29-2018, 06:58 PM   #9
Mike-B's Avatar
Rewards Points: 1,236
1. Weld it on.
2. Structural blind fasteners such as Ajax One-Side, Lindapter hollo bolt, All Fasteners Next Gen
3. Buy a mount designed for monopoles. Lightweight ring mount or a chain mount would work well. https://www.sitepro1.com/store/cart....duct_list&c=52
4. The place linked to above sells heavy duty banding and tools. Ive seen it used to hang some big stuff off light poles. We just use this method to stap conduit and cables.
Mike-B is online now
source of low price steel tubing to purchase burntside bob Excavation & Site Work 8 11-27-2014 10:14 PM
Steel Beam in the Family Room herbdavey Welding & Steel Trades 16 07-13-2014 04:41 PM
3/16" 1x19 stainless steel cable lukehatfield Contractor Swap 0 09-14-2012 10:06 AM
24' x 45' Patio with 4 Steel Post Only buddyb1201 Remodeling 11 08-10-2012 12:14 AM
A look at Vertical Deco-Concrete SgtSurf Concrete & Paving 9 02-08-2009 04:56 PM
