Aluminum Commercial Pivot Door Repair - Construction - Contractor Talk
Old 03-11-2019, 10:21 AM   #1
smack1114's Avatar
Trade: Doors and Windows
Rewards Points: 4
I have a customer that needs a quick fix on a pivot door. The Pivot hinge went bad on the top. I ordered up some aluminum butt hinges that I can just install to the aluminum to the outside of the door and also another pivot install. I do not think I'll be able to install the pivot install do to the salt water corrosion fusing the aluminum. My thought is that I can install the butt hinges to the exterior aluminum on an outswing. I'm afraid that instead of the weight bearing on the bottom pivot hinge it'll now focus on the swing hinges and that could cause a problem.
Please advise.
Thanks
smack1114 is offline
Old 03-11-2019, 10:44 AM   #2
Fishindude's Avatar
Trade: Industrial
Rewards Points: 994
Re: Aluminum Commercial Pivot Door Repair
Assume you are talking about a glass aluminum commercial storefront door? This problem is not unusual. A full glass door is a lot of weight on a couple little pivot hinges.
They make a surface mounted hinge kit to replace the pivots on worn out alum commercial glass doors but they look ugly. If you want it to look right a full replace is in order.
Fishindude is offline
Old 03-11-2019, 10:55 AM   #3
smack1114's Avatar
Rewards Points: 4
Can you link me to an image of the surface mounted hinge kit. I'm curious if it's what I bought as I have the surface hinge kit and, if I can get it installed, pivot hinge kit.
Here is the surface hinge I bought https://www.homedepot.com/p/Global-D...1-AL/203384269
I'd prefer to just install the surface hinge as it'll be really simple.
Old 03-11-2019, 11:06 AM   #4
Fishindude's Avatar
Trade: Industrial
Rewards Points: 994
I always used a subcontractor for commercial glass doors. Go to your local glass shop that regularly installs these and they can hook you up.
The Following User Says Thank You to Fishindude For This Useful Post:
smack1114 (03-11-2019)
Old 03-11-2019, 11:28 AM   #5
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,258
First I thought this was a swinging door in a restaurant kitchen --- you can get repl parts.
I've seen your method used. Ghetto fix I guess ?
At the box store get 4" sq edge --- ball bearing butt hinges.
I would tap threads in the alum. for machine screws and put some Locktite Blue on the threads.
Hope this helps ?
I see your hinges now -- could work -- I still would tap the alum. rails.
Steve
We Fix Houses is offline
The Following User Says Thank You to We Fix Houses For This Useful Post:
Old 03-11-2019, 02:19 PM   #6
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,466
Screw on a Roton hinge.
Inner10 is online now
Old 03-11-2019, 06:50 PM   #7
rrk's Avatar
Rewards Points: 2,590
they also have a giant size screw on piano hinge style replacement
rrk is offline
Im bidding for a commercial painting job. any advice? BaranG Painting & Finish Work 13 02-25-2014 01:54 AM
Commercial Front Entry Overlay Issues jadleybray Concrete & Paving 1 05-26-2012 07:23 AM
RRP Commercial hiteams Lead RRP Discussion 1 12-13-2011 12:31 AM
What do you pay a year for commercial auto insurance? CarrPainting Business 8 05-16-2011 03:30 PM
