Addition Slab Lower Then Original - Construction - Contractor Talk
Old 01-18-2012, 01:03 AM   #1
go terps
peakecg's Avatar
Trade: general contractor
Looking for any tips from anyone who has dealt with this before. New basement slab is 13" below existing slab water is seeping from between the existing slab and footer (which was underpinned with new footing at new foundation level) each slab has its own draintile and sump pump my question is how to seal this joint and handle the water issue. The design would allow me to pour a concrete step along the entire wall above the joint with the idea that path of least resistance would again become the draintile of the higher original slab i have seen some sealents that are designed for bonding two slabs in this manner or should i just use a sealer at the joint of original slab and footing or do you think i need to run a drain tile under the old slab and tie into the newlower sumpcrock
peakecg is offline
Old 01-18-2012, 04:02 AM   #2
General Contractor
greg24k's Avatar
Rewards Points: 8,098
Re: Addition Slab Lower Then Original
You have to provide a channel embedded in the concrete or block to allow water pass externally from under the upper portion of the slab to reach the lower portion of the lower slab and provide drainage to divert the water to the sump on both levels. It's a mess of a job now since its already built and in place...the genius who did this should have thought about this during construction, because it is obvious that the water from the higher point will always find a way to penetrate into the lower point. Since under pinning is in question, you have undisturbed soil under the upper slab and you have the same surrounding the lower slab, where now the lower slab became a basin and takes all the water from the top, not to mention from underground water table if present...and when you get the rain and the seasonal water table rises, hydrostatic pressure pushes the water into the cracks because its finding ways to escape and there is no better way then using the voids in or between the the two slabs.
greg24k is online now
Old 01-18-2012, 03:31 PM   #3
Bigmo
Michael Olding's Avatar
Trade: Masonry Restoration and Repair
Rewards Points: 75
WOW! Now that sounds like a real mess. Pics would be cool to see...
Michael Olding is offline
Old 01-18-2012, 03:39 PM   #4
garagebuilders's Avatar
Trade: Chicago Garage Builder
A combination of the 3 solutions you mentioned may be your best bet at this point, depending on what you want as a finished product and how far you're willing to go to get there. I've run into similar situations before. Good luck!
Chicago Garage Builders
garagebuilders is offline
The Following User Says Thank You to garagebuilders For This Useful Post:
peakecg (01-18-2012)
Old 01-18-2012, 04:19 PM   #5
go terps
peakecg's Avatar
Thanks for the input i think i agree that the upper drain tile needs to be tied into the lower which wont be too hard at this point. I'm thinking the joint still needs to be sealed would you use a flexible sealent or a hydraulic cement? As for the genius who built it, i am the gc but neither the architect, structural engineer, soil engineer, foundation contractor put any detail on the drawings or raised any issues. If we all had perfect foresight like you we probably wouldnt need this forum
Any one have a detail on how you would install the draintile if you were pouring a two level slab from scratch? I may be able to replicate
peakecg is offline
Old 01-18-2012, 05:30 PM   #6
JustaFramer's Avatar
Trade: Exiled For Life
Rewards Points: 2,000
http://www.masco.net/pdf/catalogs/fo...es_page221.pdf
Bentonite waterstop RX
Oddly enough have used this on a underpin along with Volclay panels.
JustaFramer is offline
The Following User Says Thank You to JustaFramer For This Useful Post:
Lower a Floor Ideas elittleton73 Construction 7 01-14-2012 01:02 PM
Features of a California slab foundation. What are they? UpNorth Masonry 17 06-20-2010 05:20 PM
Perf pipe under basement slab wadswob General Discussion 3 04-21-2010 12:22 AM
Walkout basement: Pavers on a slab? bert0168 Masonry 12 08-12-2009 05:52 PM
correcting 'falling' porch slab AustinDB Construction 16 08-03-2009 05:53 AM
