Stamped Asphalt Intersection We Did - Specialty Trades Picture Post - Contractor Talk
Old 11-15-2012, 02:03 AM   #1
Decorative Asphalt Guy
oktex56's Avatar
Trade: Decorative Asphalt/Concrete restoration/Carpentry
Rewards Points: 326
We did this intersection a few years ago. It was over 80' x 120'.
Struck a circle then filled in with running bond which was offset.
Framed by crosswalks on all 4 sides, then filled in with running bond between crosswalks and circle.
Fun and when done the stamped concrete contractor I beat on the bid (owner) came over and shook my hand and gave me a sincere compliment on how it turned out.
Stamped Asphalt intersection we did-hawk-ridge-work-3-.jpg   Stamped Asphalt intersection we did-hawk-ridge-work-6-.jpg
oktex56 is offline
Old 11-15-2012, 02:11 AM   #2
VinylHanger's Avatar
Rewards Points: 13,726
Re: Stamped Asphalt Intersection We Did
That's sweet looking.
VinylHanger is online now
The Following User Says Thank You to VinylHanger For This Useful Post:
oktex56 (11-15-2012)
Old 11-15-2012, 02:23 AM   #3
oktex56's Avatar
Rewards Points: 326
Another intersection.
Won an award for best asphalt job in Missouri that year.
Stamped Asphalt intersection we did-jefferson-city-mo-crosswalks-027.jpg   Stamped Asphalt intersection we did-jefferson-city-mo-crosswalks-034.jpg   Stamped Asphalt intersection we did-jefferson-city-mo-crosswalks-032.jpg
oktex56 is offline
The Following 3 Users Say Thank You to oktex56 For This Useful Post:
donerightwyo (02-03-2013), Kent Whitten (02-03-2013), ohiohomedoctor (02-03-2013)
Old 02-03-2013, 11:30 AM   #4
Deck Builder
Cedar Springs's Avatar
Trade: Decks, Fences, Demolition
Rewards Points: 75
Wow! can't tell its asphalt Great job
Cedar Springs Decks & Fences
844 Westminster Windsor, Ontario, 519-817-4318
www.cedarspringsdecksandfences.ca
http://www.facebook.com/CedarSpringsDecksandFences
Cedar Springs is offline
Old 02-03-2013, 11:55 AM   #5
oktex56's Avatar
Rewards Points: 326
Thanks, one of the best compliments we can get
oktex56 is offline
Old 02-03-2013, 12:54 PM   #6
Self Leveler
JBBS's Avatar
Trade: Epoxy Flooring - Concrete Overlays - EIFS
Rewards Points: 550
Looks pretty good. How do the colors hold up to high heat? Are they integral?
JBBS is offline
Old 02-03-2013, 01:08 PM   #7
oktex56's Avatar
Rewards Points: 326
Heat isn't an issue. The coating holds up extremly well under heavy abuse such as snow plows, etc.
The reason I came on board with this is that asphalt is a somewhat flexible substrate and typically you sacrifice durability with a flexible coating designed to move with the base.
Not so with these coating products. They are applied in multiple layers (4) and are polymerized and loaded with aggregete which makes for an very tough and long lived wear surface.
Some of our applications are in 20,000 vehicle passes per day and holding up well.
Not integral. Multiple layers applied and allowed to dry between each layer.
oktex56 is offline
The Following User Says Thank You to oktex56 For This Useful Post:
JBBS (02-03-2013)
Old 02-03-2013, 01:53 PM   #8
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,582
That's nice looking. Our city redid its main street and did the walks like that. It's been a couple years now and it's holding up well!
overanalyze is online now
oktex56 (02-03-2013)
stamped asphalt dlcj Concrete & Paving 36 08-29-2017 04:29 PM
Sealer removal advice over exposed aggregate and stamped? oktex56 Concrete & Paving 10 01-14-2013 03:57 PM
Stamped Asphalt at Norfolk Naval Station My Driveway Dr Specialty Trades Picture Post 3 11-15-2012 01:44 AM
Stamped Asphalt Driveway My Driveway Dr Specialty Trades Picture Post 2 05-11-2011 01:08 PM
Stamped Asphalt jk0055 Concrete & Paving 1 06-19-2009 08:15 PM
