Polished Concrete Help. - Specialty Trades Picture Post - Contractor Talk
Old 05-05-2015, 08:37 PM   #1
krislemon's Avatar
Trade: Masonry Concrete
Rewards Points: 84
Im working on building a table. It is a pine base with a polished concrete top. Im having a hard time filling all of micro holes. Seems like everytime I do a fill/ slurry coat it creates more holes or just doesnt seem to fill all of them. Looking for some tips on getting my holes filled.
Polished Concrete Help.-img_1503-1-.jpg   Polished Concrete Help.-img_1482-1-.jpg   Polished Concrete Help.-img_1458-1-.jpg
krislemon is offline
Old 05-05-2015, 08:48 PM   #2
Dan_Watson's Avatar
Rewards Points: 2,748
Re: Polished Concrete Help.
Is spreading the slurry pushing through where there are holes covered by a thin layer or just not filling?
What is your slurry mix?
Were you going for that look?
Dan_Watson is offline
Old 05-05-2015, 08:59 PM   #3
krislemon's Avatar
Rewards Points: 84
I wanted an industrial sort of look to it with a slight modern esk. Slurry coats have typically been arcylic admix/water, cement and plasticizer. Tried quite a few times. Also looking for some advice on sealers for the table. Thanks
Old 05-05-2015, 09:08 PM   #4
duburban's Avatar
Trade: building
Rewards Points: 1,800
liquid acrylic is 50% water. only use a liquid acrylic for hydration. I think your problem is that your trying to fill the hole without leaving extra material on the surface. when you do this you will always pull out and leave a depression. slurry the entire top, leave it all messy and proud and polish/sand back down to a level surface.
the only way you should be adding holes to the surface is by polishing down into it. if your only applying slurry then your just not getting them filled.
duburban is offline
Old 05-05-2015, 09:16 PM   #5
krislemon's Avatar
Rewards Points: 84
Tried this one last night but i used water with the acrylic, maybe I will try just straight acrylic. Thanks for the advice. I want to get this table wrapped up here soon.
Old 05-05-2015, 09:40 PM   #6
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,676
Your slurry needs to cure completely as well. You may be trying to polish it to soon and it is to soft.
overanalyze is offline
Old 05-05-2015, 10:49 PM   #7
duburban's Avatar
Trade: building
+1 on that. i try to slurry with majority CSA cement for a 1-3 hour cure.
duburban is offline
Old 05-05-2015, 11:08 PM   #8
Fire up the BBQ
griz's Avatar
Rewards Points: 3,022
Looks like a mix & placement problem.
Awful lot of pock marks/voids to fill & have look good.
griz is online now
Old 05-07-2015, 10:15 AM   #9
krislemon's Avatar
Rewards Points: 84
I have the same feeling about the mix. I think there might have been to much air. I got some topping mix so im going to give that a go to see if it works. Does anyone have any recommendations on sealers?
Old 05-24-2015, 08:33 AM   #10
madrina's Avatar
Trade: roofing and other envied trades
Rewards Points: 1,280
Use a densifier on polished concrete. It fills the holes and then expands to create a unpenetratable/inpenetratable. ...whatever the word is... surface.
madrina is offline
Old 05-24-2015, 08:41 AM   #11
madrina's Avatar
Did you build that upside down on melamine? What was the problem? Should you have vibrated more.. and troweled more?
Oh oh wait.. you didn't use the corner spoon on that did ya? Well that's your problem. Ya didn't know how much concrete was on the form. Need ta get cha wun of them..
madrina is offline
Old 05-26-2015, 10:27 PM   #12
Always Learning
I just polished this one. I did a slurry coat, left it messy, then hit it again the next day.
The Following 3 Users Say Thank You to overanalyze For This Useful Post:
Kowboy (08-20-2016), madrina (06-01-2015), Xtrememtnbiker (05-26-2015)
Polished concrete problems Young mason Masonry 6 03-03-2014 08:48 PM
17-ton concrete slab overhang fell from a bank building in Stroud Township AmeliaP Masonry 27 09-05-2013 07:16 PM
Sealing Stamped Concrete Bill Butler Masonry 1 06-02-2013 04:51 PM
stamped concrete losing its color in spots- TIGHTER MITER Masonry 18 01-19-2013 04:51 PM
concrete slab HUDSONVALLEYEXT Construction 4 06-04-2012 12:45 PM
