Wrapping Window Exterior In Aluminum? - Windows, Siding and Doors - Contractor Talk
Old 03-25-2010, 08:47 AM   #1
AndersonsWworks's Avatar
Trade: Custom Cabinetry
Rewards Points: 75
Any advise/tips from any of you pros on wrapping exterior windows in aluminum? I have worked with a break before in doing facia and soffit trim but never on windows. I know this is a hands-on thing but if someone could point me to a site that has any procedures it would be greatly appreciated. I would like to know the correct bends, sequence of installing pieces, best way to attach aluminum, sealing, etc. Photos would be great! Thanks a ton!
Rocky
AndersonsWoodworks.com
AndersonsWworks is offline
Old 03-25-2010, 07:55 PM   #2
paul100's Avatar
Rewards Points: 60
Re: Wrapping Window Exterior In Aluminum?
One thing that I usually always do is make what I call a template. I bend a thin (3/4") srip of aluminum into the shape i want. I check this around the whole window to make sure it fits. Sometimes I need to make changes to it for what ever reason. I find this method faster and more accurate then trying to measure for every bend.
I also always put a hem bend ( metal folded over against it self) on the part of the capping that goes against the window. It strengthens the edge of the metal and also there are no sharp edges when I run my finger over it smoothing the caulk.
paul100 is offline
Old 03-25-2010, 09:41 PM   #3
DavidC
DavidC's Avatar
Rewards Points: 2,006
We don't do a whole lot of siding and coil work anymore. In fact, my brake is older than some of the posters here and you have to know how to hold your jaw just right to use it.
I would always make what I called a cheat stick for each peice I wanted to repeat. It was a thin 24" long scrap. All the measurements were marked on it for a particular piece, one for window sills, another for sides and tops. All you have to do is cut your coil to length and lay the cheat stick on it to transfer your measures. You can lay out how ever many pieces will fit across the width for mass production.
I also prefer to wrap the coil around the J channel for a better look. Plus I feel it helps keep out the rain better.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 03-26-2010, 10:25 PM   #4
CharlesD's Avatar
Trade: Remodeling/building
Rewards Points: 150
I also made a guage out of a piece of scrap coil about an inch wide. Make a bend on one end to hook over the piece of metal I'm bending so I can just hook and transfer.
Another thing I did was instead of marking with a pencil I took my straight snips and made about a fourth inch cut for the marks. That way I could transfer the cuts to the coil and when you stick the piece in the brake just lift the outside of the cut slightly and it will butt against the jaw of the brake. No looking or guess work. Your bend is always exactly on plus it's lots faster.
On windows your usually cutting the ends off anyway so the cuts don't really slow you down.
May waste a few inches of coil per roll but the time it saves in laying out and eliminating screw ups makes up for it
CharlesD is offline
Old 03-26-2010, 10:31 PM   #5
CharlesD's Avatar
Rewards Points: 150
I just noticed I hit 200 posts after three years. If I live to 100 I might hit 2000.
This is a great board. I wish I had it while I was out beating my brains out trying to make a go of it.
CharlesD is offline
Old 03-26-2010, 10:45 PM   #6
genecarp's Avatar
Rewards Points: 2,000
Congrats Charles, GMOD
genecarp is offline
Old 03-26-2010, 10:47 PM   #7
genecarp's Avatar
Start at the bottom, and like an boss used to tell me, "THINK LIKE A RAINDROP",GMOD
genecarp is offline
Old 04-27-2010, 12:50 PM   #8
USMC_Buckaroo's Avatar
Trade: Energy-related improvements/Alternative Energies
And, if you happen to work on the east coast, Think like a waterfall!
Buck
USMC_Buckaroo is offline
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
wrapping windows w/ aluminum siding AustinDB Windows, Siding and Doors 7 10-24-2009 06:42 PM
Aluminum window question davinci Windows, Siding and Doors 7 09-16-2009 07:35 AM
instructions for aluminum coil wrapping an outside corner sill t2tiam Windows, Siding and Doors 12 12-24-2008 12:44 AM
Reno Window Screw Up Bummie Windows, Siding and Doors 15 12-22-2008 10:33 PM
