Window Trim Install - Windows, Siding and Doors - Contractor Talk
Window Trim Install
Old 05-07-2013, 06:22 PM   #1
MattK's Avatar
Trade: Framing, Roofing, Siding
Rewards Points: 1,096
Window Trim Install
Installing 5/4 x 4 primed cedar FJ around Anderson windows. I like to remove about an 1/8" x 1 5/8" all the way so the trim sits flat against the sheathing and not the window nail flange.
Usually, I rip the trim on edge through the saw with a wide kerf blade. That gives me the rabbit all the way without a secondary cut needed. I like to also rip a 5 degree in the short edge so the trim sits perfectly against the window. Anderson makes a solid product but the side of the window turns into the flange on a sweeping curve, not a 90 so without the 5 degree rip the trim won't get closer than 3/16"...not acceptable.
My question is does anyone have a more efficient way of rabbitting the stock? Considering a longer flute on my router but don't want to burn out the motor (50 boards at 20' long). I don't currently own a router table as well, will buy one if a solid idea calls for it as I've rabbitted trim for yrs.
Thanks
--MATT
Add your Facebook Business Site to "THE LIST"
https://www.contractortalk.com/f12/if...-should-79504/
Page 77 has the updated, complete list.
MattK is offline
Old 05-07-2013, 07:21 PM   #2
Joseph A. Capece
CENTERLINE MV's Avatar
Trade: Builder - General
Rewards Points: 1,432
Re: Window Trim Install
Shim out the trim rather than rabbet. Pin nailer works great for this.
Follow us on FACEBOOK
www.centerlinebuilders.net
Martha's Vineyard General Contractors - Builders -
Commercial/Residential - Additions - Renovations
CENTERLINE MV is offline
The Following User Says Thank You to CENTERLINE MV For This Useful Post:
Tom Struble (05-13-2013)
Old 05-07-2013, 07:33 PM   #3
The Sheriff
Jaws's Avatar
Trade: Builder
Rewards Points: 16,140
FJ outside?
I usually install concrete siding and trim if not stucco with stucco trim. When using Hardie, I rip down some siding to shim the trim out proud of the siding, cut the siding against the trim. Looks better to me.
"The sound of the saftey clicking off is the only warning your gonna get......., so cover your ears" Northeast Wyoming 2016
John
Jaws is online now
Old 05-07-2013, 07:43 PM   #4
MattK's Avatar
I've shimmed in the past, maybe I'll mess with that idea again. It takes a long time to rabbit all this stock so I figured the router might be an alternative...having trouble finding the bit online too.
Up here, FJ is very common for exterior in pine and cedar.
--MATT
MattK is offline
The Following User Says Thank You to MattK For This Useful Post:
Jaws (05-07-2013)
Old 05-07-2013, 07:45 PM   #5
The Sheriff
Jaws's Avatar
Trade: Builder
Rabbiting probably looks good, I just like the way the the trim looks proud of the siding.
John
Jaws is online now
The Following User Says Thank You to Jaws For This Useful Post:
CENTERLINE MV (05-07-2013)
Old 05-07-2013, 07:57 PM   #6
MattK's Avatar
Agreed. I push for the 5/4 so it projects a good distance. I like that look as well. With the rabbitted trim sitting flat against the sheathing, the trim will stick out approx 1/4" to 3/8" past the white cedar siding.
--MATT
MattK is offline
Old 05-07-2013, 08:02 PM   #7
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
I prefer the rabbitedpocket to shims as well. If it was 3/4"' shims would be the way to go so it stands proud of the clap board. I've done and do both methods - table saw and router. If you can do the rabbit in one pass on the table saw, I don't see how any efficiency can really be gained.
EricBrancard is offline
Old 05-07-2013, 08:12 PM   #8
MattK's Avatar
Ideally, I would like to rabbit all 50 - 20' boards, than bevel all 50 as well. Doing with a table saw sometimes requires a 2nd guy as well as 40+' of work area. I pictured me stacking a half dozen on the bench, one pass and time to stack um, another half dozen up. I think what I need to do is get a 5/8" diameter flush bit 1 5/8" long and change out the bearing to 1/4" so I'll have 3/16" on each side hanging over the bearing. Then I can set the depth and go.
When looking for this bit, it seems all bearings are the equal width to the diameter of the shank. Hadn't thought of downsizing the bearing to create the bit for this specific application. Of course, this all works out great at my laptop!
--MATT
MattK is offline
Old 05-07-2013, 08:17 PM   #9
MattK's Avatar
Just so we're on the same page, the rabbit is on the inside(window edge of the trim, not siding edge of the trim). Just realized I typed "siding" instead of "sheathing" in OP. Sorry for any confusion.
--MATT
MattK is offline
Old 05-07-2013, 08:27 PM   #10
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Just use longer nails and more caulk....
ohiohomedoctor is offline
Old 05-07-2013, 09:01 PM   #11
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
think about using a drainable matrix like strips of Cedar Breather
shim and drainage all in one
http://www.benjaminobdyke.com/visito.../cedarBreather
Tom Struble is offline
aptpupil (05-13-2013)
Old 05-07-2013, 09:46 PM   #12
designer + carpenter
NINZAN STUDIO's Avatar
Trade: carpentry
Rewards Points: 510
Just did some Anderson casements with S4S FJ cedar 2x4 trim. We ended up shimming the corners out, or held them off with mini prys while hand driving 10d's. I suggested the same exact thing OP said, however boss man didn't want to spend the extra time cutting the rabbet or even a back bevel.
If I were running miles off this stuff, I would setup a sacrificial fence (1x something) on the table saw with a stack dado and feather boards. One time setup and plow it all through.
Window trim install-image-3842313073.jpg   Window trim install-image-1660159644.jpg
NINZAN STUDIO is offline
The Following 2 Users Say Thank You to NINZAN STUDIO For This Useful Post:
Tom Struble (05-08-2013), Windwash (05-12-2013)
Old 05-07-2013, 10:19 PM   #13
VinylHanger's Avatar
Rewards Points: 13,448
I don't think I could get FJ cedar if I wanted to. The only FJ stuff I see nowadays is the casing on prehung exterior doors. Never glued and they always fall apart as you install them.
VinylHanger is offline
Old 05-12-2013, 08:26 PM   #14
Jajgthompson's Avatar
Pocket screws,finish nails ,no rabbit
Jajgthompson is offline
Old 05-12-2013, 09:52 PM   #15
Windwash
Windwash's Avatar
Rewards Points: 150
Good idea. Are you ripping the strips with straight edge and utility knife or is there a better way?
Windwash is offline
Old 05-13-2013, 06:25 AM   #16
Trade: siding
Rewards Points: 20
I have only seen it being used that way,Jason Whipple did a project in upstate N.Y.he let me help with where all the trim and siding was ventilated..not sure how it was cut
Old 05-13-2013, 09:14 AM   #17
Eaglei's Avatar
Trade: carpenter & Masonry
Rewards Points: 1,510
I think were talking about two different things here . The way I read it was the OP was talking about cutting a kerf in the back side of the window trim so it would sit flush against the sheating . Without kerfing the trim the window nailing flange would keep the trim from sitting flush . I also kerf the trim with a table saw , much faster than using a router table . The only thing I don't like about it is that you either have to paint , prime or seal the wood before installing . Gotta love pvc trim .
Eaglei is offline
Old 05-13-2013, 09:19 AM   #18
Trade: siding
Rewards Points: 20
yea well..shimming accomplishes the same thing..right?
Old 05-13-2013, 09:57 AM   #19
CarpenterSFO's Avatar
Rewards Points: 2,044
Yes, if you're only talking about how it looks and functions.
- Bob
CarpenterSFO is offline
The Following User Says Thank You to CarpenterSFO For This Useful Post:
Old 05-13-2013, 10:01 AM   #20
Eaglei's Avatar
Yea just takes longer .
Eaglei is offline
Nailing Utility Trim Under Window for Vinyl Nick R Windows, Siding and Doors 3 07-16-2012 05:25 PM
Interior Window Trim KennMacMoragh Painting & Finish Work 20 04-16-2012 07:04 AM
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Looking for window install crews in Florida 08sgt0331 Help Wanted or Looking For Work 0 05-11-2010 03:39 PM
IQ window trim by Mid-america WarnerConstInc. General Discussion 4 10-01-2009 12:20 AM
