Window Flashing Tape Failure? - Windows, Siding and Doors - Contractor Talk
Old 04-23-2015, 07:43 PM   #1
Windwash
Windwash's Avatar
Rewards Points: 150
We replaced a window during a kitchen remodel last summer and the original flashing tape from when the house was built in 2003 was toast. The tape was cracked all the way through in spots at the line where it overlapped onto the nailing flange. You can see where I stuck my finger through it and pulled on it.
Window faces west so gets afternoon sun. Has anyone else seen this or have any ideas on whats going on?
Window flashing tape failure?-img_5577.jpg   Window flashing tape failure?-img_5573.jpg   Window flashing tape failure?-img_5574.jpg
Windwash is offline
The Following User Says Thank You to Windwash For This Useful Post:
Tom Struble (04-26-2015)
Old 04-23-2015, 09:43 PM   #2
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 186
Re: Window Flashing Tape Failure?
There continually making improvements to tape formulas for good reasons; with that possibly dried out, to much UV, wrong substrate for the tape...
SLSTech is offline
The Following User Says Thank You to SLSTech For This Useful Post:
Old 04-23-2015, 10:22 PM   #3
PCI
PCI's Avatar
Trade: contractor
Rewards Points: 848
I have found this on 4 window or door replacements. I don't know if it's the Western exposure and/or the MN cold winters, but the flashing tape is crap!!! This is usually a white tape, but I did have a black one too.
It makes me want to go back and tear apart one of my protecto tape jobs. That is all I use. Now I want to expose any failure, if any/none.
PCI is offline
The Following User Says Thank You to PCI For This Useful Post:
Old 04-26-2015, 12:55 PM   #4
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
reverse lap..water is getting under the tape,seems to be just at the head
Tom Struble is offline
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
EthanB (05-02-2015), SLSTech (04-26-2015)
Old 04-26-2015, 05:35 PM   #5
Windwash
Windwash's Avatar
Rewards Points: 150
It looks like reverse lap onto tar paper but is actually just the tape stuck to the sheathing which is black Bild-rite.........no paper or house wrap on this house:roll eyes:. You're right either way though, that water was able to sneak behind at the top of the tape.
Any ideas on why the tape would crack if a little water got behind it? Maybe the water froze and pooched it out?
Windwash is offline
Old 04-26-2015, 06:35 PM   #6
Box Builder
Morning Wood's Avatar
Rewards Points: 10,384
I think some vinyl windows ate the tape up, but that doesn't seem to be your issue. Maybe seasonal movement weakened it?
Morning Wood is offline
Old 04-26-2015, 06:57 PM   #7
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
It looks like a combination of all the issues already mentioned in the thread. I would guess that if the tape could actually adhere to the surface it was on, the reverse lap wouldn't be as big of an issue. ZIP system really doesn't have a lap over the tape, but the tape has such an aggressive acrylic binder that the water isn't going to get behind it. But I don't think any tape really sticks to that old Celotex stuff good.
EricBrancard is offline
Old 04-26-2015, 07:54 PM   #8
Windwash
Windwash's Avatar
Rewards Points: 150
I didn't mention it, but the window was replaced with a taller window to let more light into the kitchen, not to replace a leaky or rotten window. There was evidence that some moisture had gotten behind the flashing but we did not need to replace any sheathing.
Windwash is offline
Old 04-26-2015, 08:02 PM   #9
Windwash
Windwash's Avatar
Rewards Points: 150
I love the Advantec subfloor but haven't used the Zip system. I would have a hard time trusting that tape to stay stuck forever.
Windwash is offline
Old 04-26-2015, 08:45 PM   #10
Rewards Points: 986
I used it on my own home. I trust it.
The Following 2 Users Say Thank You to EricBrancard For This Useful Post:
wallmaxx (05-02-2015), Windwash (04-26-2015)
Old 04-28-2015, 09:20 AM   #11
Trade: siding
Rewards Points: 20
idk..but water being the ''universal solvent''possibly some kind of damaging chemical is formed between the tape the vinyl and the composite sheathing
SmallTownGuy (05-09-2015)
Old 04-28-2015, 09:32 AM   #12
KAP's Avatar
Trade: Custom
Rewards Points: 40,202
Tape has to be installed taking into consideration gravity... from the pic, it doesn't look to me like it was... there's nothing preventing the water from getting behind the tape... paper should have been cut back and overlap onto tape after tape being installed and seams taped with skip taping on the window edge... Tape should go over the flange... tape LOVES vynil...
Tape install works from the bottom up so all tape edges are covered and water can't get a vertical hold...
KAP is offline
Old 04-28-2015, 09:36 AM   #13
Trade: siding
Rewards Points: 20
it's Celotex sheathing kap..no paper..perhaps installing some after taping would have prevented it,but that would depend on the particular placement and jobsite conditions
Old 04-28-2015, 09:43 AM   #14
KAP's Avatar
Trade: Custom
You're right... was focused on the tape...
Still... Tape install is bottom up... bottom (behind flange and protecting sill and corner side allowing any water that gets through to vent and not build up), then sides going up and about same width of tape past top (installed over flange into corners - window side and top should already be caulked) and then top top is taped across that with house wrap going down on top of that with seams taped... water has nowhere to go but down and doesn't touch the tape edge as in the pic...
Same principle as paper over paper... if you look at the 2nd and 3rd pic the tape on the flange is still pretty solid as it overlaps the flange... it's a failing above this point because water can get to it on the vertical...
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
Tom Struble (04-28-2015)
Old 05-02-2015, 08:59 AM   #15
Lettusbee's Avatar
Rewards Points: 1,636
That black board celotex should be outlawed. It was used all over the place here for decades. We retrofit windows and tape them properly, but the Celotex is so porous, I sometimes wonder, what's the point.
Fwiw, protectowrap superstick stays put on that carp. The 3m tape does it almost as well.
Lettusbee is offline
The Following User Says Thank You to Lettusbee For This Useful Post:
Old 05-02-2015, 09:59 AM   #16
slowsol's Avatar
Rewards Points: 2,248
That window appears to be lapped correctly.
-John
slowsol is offline
Old 05-02-2015, 11:52 AM   #17
KAP's Avatar
Trade: Custom
Lapped correctly (bottom up) and installed correctly are two different things...
Water has entry points from top to bottom in that photo...
KAP is offline
Old 05-02-2015, 12:20 PM   #18
slowsol's Avatar
I'm confused. The building doesn't have paper on it. Is that what you mean? What else is incorrectly installed on that window?
-John
slowsol is offline
The Following User Says Thank You to slowsol For This Useful Post:
Tom Struble (05-02-2015)
Old 05-02-2015, 02:46 PM   #19
Trade: siding
Rewards Points: 20
i think he's looking at the j channel and thinking it's the flange?
Old 05-09-2015, 09:04 AM   #20
rock16's Avatar
Trade: Commercial Exteriors & Multi Family Remodel
Rewards Points: 274
If you have to tape on top of the Celotex, Eternabond WS tape will stick and you will never have a problem.
rock16 is offline
The Following User Says Thank You to rock16 For This Useful Post:
Tom Struble (05-09-2015)
18 inch rollers and Tape Question dwbrooks Painting & Finish Work 88 09-01-2014 09:30 PM
Pressure Washing & Window Cleaning Tips Jas2012 New Member Introductions 13 08-14-2012 05:22 PM
Pressure washing and window seals. SuperiorHIP General Discussion 9 08-05-2012 07:19 PM
Window flashing advice colotimber General Discussion 10 03-04-2008 11:36 AM
