Vinyl Siding Issue - Windows, Siding and Doors - Contractor Talk
Vinyl Siding Issue
Old 07-24-2015, 11:37 PM   #1
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 496
Vinyl Siding Issue
Ok, I was a siding contractor(amongst other things) in Calif and never even saw any vinyl siding, much less installed it.
I'm looking for a new cheap house and I took a look at this one. It's not a bad house, but it definitely has some siding issues. Is vinyl siding susceptible to deteriorating close to the ground. As you can see in the pics, there is a problem and it seems prevalent all around the house on the bottom pieces, including the vinyl trim.
What's the story and is it going to migrate upwards eventually.
Vinyl siding issue-1449-out-west-ct-r2.jpg   Vinyl siding issue-1449-out-west-ct-r1.jpg
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
Old 07-24-2015, 11:49 PM   #2
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 22
Re: Vinyl Siding Issue
That looks like a wild grass trimmer operator...
overanalyze is online now
The Following 14 Users Say Thank You to overanalyze For This Useful Post:
baerconstructio (07-25-2015), CompleteW&D (07-25-2015), Framer53 (07-25-2015), Framer87 (07-25-2015), greg24k (07-25-2015), hdavis (07-25-2015), jb4211 (08-03-2015), KAP (07-25-2015), MDjim (07-25-2015), SamM (07-25-2015), slowsol (07-25-2015), Tom Struble (07-25-2015), wallmaxx (07-25-2015), Youngin' (07-25-2015)
Old 07-24-2015, 11:54 PM   #3
mako1's Avatar
Rewards Points: 1,094
My thoughts exactly and also some vinyl siding is much thinner than others .The good stuff is round .046.
mako1 is offline
Old 07-24-2015, 11:58 PM   #4
redwood's Avatar
Rewards Points: 496
You know that makes sense, though I think I would have learned a little quicker then they did apparently.
I think there was a box of siding in the garage and I think it was Royal, but I could be wrong.
How hard is it to replace the bottom layer?
Mark
Pioneer, CA
redwood is offline
Old 07-25-2015, 12:12 AM   #5
Always Learning
Rewards Points: 22
Not hard at all. Unzip the lap, remove the damaged row, install new row, and re-lock the lap.
Old 07-25-2015, 12:36 AM   #6
SouthonBeach's Avatar
Rewards Points: 4
I'd second the weed eater damage.
Watch some lawn guys and you'll know why it happened, they only care to make sure no grass is left untrimmed
Sent from my iPad using Tapatalk
SouthonBeach is online now
Old 07-25-2015, 12:39 AM   #7
hdavis's Avatar
Rewards Points: 268
Easy, unless it's REALLY old. Then it can be stiff and crack.
hdavis is online now
overanalyze (07-25-2015)
Old 07-25-2015, 12:40 AM   #8
Always Learning
Rewards Points: 22
Or worse...trying to replace old vinyl when it's cold outside.
hdavis (07-25-2015)
Old 07-25-2015, 01:05 AM   #9
KAP's Avatar
Trade: Custom
Rewards Points: 110
As long as the one above doesn't crack...
KAP is offline
Old 07-25-2015, 05:07 AM   #10
SamM's Avatar
Trade: Carpenter/Handyman
Rewards Points: 1,484
Just use one of these
http://www.amazon.com/gp/aw/d/B00826...NPL&ref=plSrch
Stick it in the seam and pull down and out. The piece will disconnect. Then pull the nails in the lower piece, swap it for a new piece and nail it back on (leave nails proud so siding can move).
Then pull the old siding down over the new piece with that same tool and push it in to lock it. It may make you curse a little of it doesn't wanna go back easy.
Your Dreams won't work unless you do.
SamM is offline
Old 07-25-2015, 06:52 AM   #11
Box Builder
Morning Wood's Avatar
Rewards Points: 6
With vinyl you never know what you are going to get underneath. Hopefully correctly lapped building paper because vinyl leaks.
Morning Wood is offline
Old 07-25-2015, 08:03 AM   #12
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
Azek makes a nice skirt board that would take much more of a beating than vinyl clap.
EricBrancard is offline
The Following 4 Users Say Thank You to EricBrancard For This Useful Post:
CompleteW&D (07-25-2015), flynnworx (08-04-2015), SamM (07-25-2015), slowsol (07-25-2015)
Old 07-25-2015, 08:29 AM   #13
hdavis's Avatar
Rewards Points: 268
Still in Cali?
Old 07-25-2015, 09:20 AM   #14
Tom M's Avatar
Rewards Points: 156
I have repair my share of weed whacker vinyl damage. Its not the siding thats sucks to repair its the corner post.
Tom M is online now
NYgutterguy (07-25-2015)
Old 07-25-2015, 09:32 AM   #15
Xtrememtnbiker's Avatar
Trade: General Remodeling
When I was around 13, my siblings and some friends had gotten into playing airsoft. We started with the little spring pistols playing around the house. Eventually had some pretty nice full auto guns a bit later.
One day we managed to shoot up the house (including the corner board).
Dad wasn't really happy and said it was a pain to fix. Now I know why...
Xtrememtnbiker is offline
Old 07-25-2015, 10:25 AM   #16
Lazy Millennial
Youngin''s Avatar
In my area you see a lot of vinyl siding. However you don't see it that close to the ground. Usually there is parging or stone taking up the bottom few feet.
Originally Posted by mnld View Post
Home Depot... you can glue it, we can help!
Youngin' is offline
Old 07-25-2015, 10:26 AM   #17
mako1's Avatar
Hope you got a good whippin?I sure would have.
mako1 is offline
Old 07-25-2015, 11:44 AM   #18
Nope, no whoopin. We didn't get whooped for things like that.
Old 07-25-2015, 11:45 AM   #19
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Put some 1x6 pvc around the bottom with drip cap on it.
jlsconstruction is offline
Old 07-25-2015, 12:38 PM   #20
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
what doesn't?
Tom Struble is offline
Dentil Trim as a starter on vinyl siding? RandyB1986 Windows, Siding and Doors 4 08-11-2013 01:56 PM
Vinyl siding question, trimming the bottom for concrete. NYCB Windows, Siding and Doors 9 05-07-2013 09:06 PM
White Vinyl Rail and Trellis killerdecks Decks & Fencing 9 02-13-2013 05:45 PM
Need a vinyl siding meets brick detail Brandon70 Windows, Siding and Doors 2 04-20-2010 07:48 PM
Certainteed Vinyl Siding Lock Issue ricesroofing Windows, Siding and Doors 3 06-08-2008 10:41 PM
