Vinyl Board And Batten Siding Questions - Windows, Siding and Doors - Contractor Talk
Old 12-05-2012, 06:03 PM   #1
dave_dj1's Avatar
Trade: general contractor
Rewards Points: 1,168
I've done a ton of vinyl but it's all been horizontal, I'm doing a small amount of vertical on this job and I would like some info. The GP site doesn't show much detail. The J channel on the bottom, I drilled a bunch of holes in it so the water would run out of it (no other way for it to get out). Also on the tall gable they show a "H" channel for stacking, problem is they don't sell it in the color I need (Hampton Red).
If any of you have done B&B vinyl, what is to say you can't lap it just like horizontal, I am thinking a couple of quick cuts so it can lap just like horizontal. The B&B only comes in 10' lengths.
Side note, the only place I have to do that would require this is on the back and won't be seen, it's 12 wide and about 16 tall (shed type gable).
thanks for any insight,
dave
dave_dj1 is offline
Old 12-05-2012, 08:07 PM   #2
Wayfarer Doors's Avatar
Trade: windows and doors/ construction supervisor
Rewards Points: 150
Re: Vinyl Board And Batten Siding Questions
just did board and batten recently, Instead of a jay on the bottom I used a drip edge, you can buy it or bend it like I did, and I screwed the b and b directly to it. All other fasteners were loose to allow expansion. As for over lapping, I can't imagine any way would look good as you'll be looking up at the gap. Maybe bend an H out of matching aluminum.
Wayfarer Doors is offline
The Following User Says Thank You to Wayfarer Doors For This Useful Post:
Legendary (12-06-2012)
Old 12-05-2012, 08:55 PM   #3
dave_dj1's Avatar
WD thanks for the reply. If I went with the formed H how would water get out of it? I don't like the idea of water sitting in a channel. I thought about looking up at the lap but hey, it's vinyl siding! LOL Aside from that, the rest of the house has T-111 with 4" spacing and looks like crap with it being bowed, aluminum z flashing and all not a pretty sight.
dave_dj1 is offline
Old 12-05-2012, 09:11 PM   #4
OneAboveAll
Legendary's Avatar
Trade: Home Remodeling Expert
Rewards Points: 25
Diffently bend some metal that has a upper nail flange and is at least a wider then the width of the J-channel your using, still drill your holes on the J on your upper trim and caulk the J on your lower trim! A 3" face on your trim looks real nice and brings a nice actscent to your work!
Hope this helps you out!
Legendary is offline
Old 12-05-2012, 09:14 PM   #5
oldfrt's Avatar
Rewards Points: 94
I have used this flashing detail on the bottom of vertical siding
to avoid the gutter affect of J.
The vertical will sit on the horizontal lip,giving a straight
enough line to be pleasing to the eye,just keep this edge straight.
Any expansion will be upwards,and as long as the siding moves
freely.the line will remain straight..
When extending past the length of the panel on high walls, the
narrow profile of the flashing shouldn't be too obtrusive.
You could also incorporate a clad 1x,covered in matching coil,
to brake up the long vertical lines.
I would install this at the height of the transition from the shorter
walls so there is some continuity to the installation.
Vinyl board and batten siding questions-untitledbb.jpg   Vinyl board and batten siding questions-untitledbbb.jpg
oldfrt is offline
Old 12-06-2012, 07:12 AM   #6
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
not banb but an example of my transition
Vinyl board and batten siding questions-p1010061.jpg   Vinyl board and batten siding questions-p1010066.jpg   Vinyl board and batten siding questions-p3170014.jpg
Tom Struble is offline
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
HomeSealed (12-06-2012), oldfrt (12-12-2012)
Old 12-06-2012, 07:44 AM   #7
Trade: siding
Rewards Points: 20
While you ''can'' bend your own, the H divider should not be used horizontally in sidewall applications unless the top is flashed
Vinyl board and batten siding questions-p3160011.jpg   Vinyl board and batten siding questions-p3170019.jpg   Vinyl board and batten siding questions-p3170020.jpg
Old 12-06-2012, 02:33 PM   #8
windows & siding
HomeSealed's Avatar
Trade: windows and exterior remodeling
Rewards Points: 618
No miter on the soffit corner? ..... Nice work all around.
HomeSealed is offline
Old 12-06-2012, 05:58 PM   #9
dave_dj1's Avatar
Yep, tried lapping a piece today and that is a no go. I've decided to have some flashing made of a similar color with a J on top of it.
Thanks for all the input.
dave_dj1 is offline
Old 12-06-2012, 06:37 PM   #10
Trade: siding
Rewards Points: 20
2 different sized soffit never...ever get mitered
besides what your looking at are an eave and a gable end
Old 12-06-2012, 07:07 PM   #11
OneAboveAll
Legendary's Avatar
Rewards Points: 25
Tom I agree I never try to mitre 2 different soffit width's when conjoining them at any juncture!
Question Tom.... if you have a nail flange of 2" on bottom and top with the out being
3/4" pass your J-chnl having " holes drilled through it with the top bent at a downward pitch on the trim do you believe any extra flashing would need to be required? Would like to hear your opinionon on this if you could please, thanks Tom!
Old 12-06-2012, 07:54 PM   #12
elicon's Avatar
Trade: Exterior Home Improvements
Rewards Points: 38
Why not, Tom? If you offset the wall end of the miter, I think the results look better than not mitering them.
elicon is offline
The Following 2 Users Say Thank You to elicon For This Useful Post:
HomeSealed (12-09-2012), Tom Struble (12-06-2012)
Old 12-06-2012, 10:33 PM   #13
Trade: siding
Rewards Points: 20
i don't,but thats a nice job you did there
Old 12-06-2012, 10:38 PM   #14
Trade: siding
Rewards Points: 20
as long as the paper is lapped properly at the flanges i think thats fine if i'm reading it correctly
Old 12-06-2012, 10:41 PM   #15
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
And tom please tell me what would happen if it wasnt lapped just right.
ohiohomedoctor is offline
The Following User Says Thank You to ohiohomedoctor For This Useful Post:
Old 12-06-2012, 11:36 PM   #16
OneAboveAll
Legendary's Avatar
Rewards Points: 25
That's what I thought as well, I been installing it that way for years, just wanted your opinion on the the matter!!! Thanks Tom!!!!
Old 12-09-2012, 12:26 AM   #17
windows & siding
HomeSealed's Avatar
Rewards Points: 618
That red soffit on line 6 is an eave and a gable end? .... Its hard to tell there... Either way, just bustin ur balls. Always impressed by your work.
The Following User Says Thank You to HomeSealed For This Useful Post:
Tom Struble (12-09-2012)
Old 12-09-2012, 09:19 AM   #18
Trade: siding
Rewards Points: 20
yes and i knew that
Old 12-12-2012, 09:56 PM   #19
windowsonwashington.net
WindowsonWash's Avatar
Trade: Exterior Construction
Rewards Points: 1,178
This...from a guy missing a finger.
Windows on Washington
WindowsonWash is offline
Old 12-21-2012, 09:59 PM   #20
Hoover Niebold's Avatar
Trade: Caulking
Rewards Points: 24
Now I'm not to sure this is the proper method or not but what I did here is bend up a T for the bottom that also caps the 3/4" insulation and the old existing siding leaving it about 3/4" below to allow a chase for cable and phone lines.
Hoover Niebold is offline
The Following User Says Thank You to Hoover Niebold For This Useful Post:
Tom Struble (12-31-2012)
Vinyl board and batten Malco or Norandex A&E Exteriors Windows, Siding and Doors 18 09-25-2012 06:10 PM
Paint or stain board and batten siding? Integritybd Painting & Finish Work 13 05-08-2011 10:46 PM
Board & Batten FC Siding jakejorgenson Windows, Siding and Doors 8 10-08-2010 04:10 PM
board and batten siding enforcer Windows, Siding and Doors 4 09-08-2008 06:12 PM
board and batten siding dutchlegacy Windows, Siding and Doors 8 03-21-2008 11:28 AM
