Styrofoam Insulation Sheets - Windows, Siding and Doors - Contractor Talk
Old 10-11-2014, 04:26 PM   #1
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Rewards Points: 1,014
I have a friend who lives in Brandermille, VA. She had no problems with her house until she had vinyle siding installed. Now her front door sticks during the summer and her hard wood floor which I installed is buckling. She seems to think it may be the sheets of insulation that was installed under the siding. I also am leaning towards that conclusion because there was no problems prior.
Does anyone here think that the insulation may not be allowing the house to breath and trapping moisture in the house? If so I was going to remove it and replace with Tyvek.
I noticed too that there are a lot of trees around, but they can not be cut as the home owner association will not permit it. There is massive amount of mildew on the side of the house too.
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 10-11-2014, 04:46 PM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 8,481
Re: Styrofoam Insulation Sheets
Sounds like the guys who installed the vinyl and the styrofoam tightened up the house quite a bit. And now it's not breathing. Newer homes have systems that allow the house to breathe.
Sounds like the house is having a tightness issue.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 10-11-2014, 05:05 PM   #3
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Get a dehumidifier
jlsconstruction is offline
The Following 3 Users Say Thank You to jlsconstruction For This Useful Post:
hdavis (10-13-2014), thom (10-12-2014), Tom Struble (10-12-2014)
Old 10-11-2014, 05:19 PM   #4
mako1's Avatar
Rewards Points: 1,094
Just a couple thoughts.
Is the roof vented properly?
Did she have new windows put in too?
Does she run air in the summer or leave windows open most of the time?
I agree.Sounds like they sealed it up tight.
As a side note:I live in IL and most of the houses we build around here have a sheet of OSB to stiffen/square the corners and Tuff-r covering the rest.A very big percentage are vinyl over foil backed foam.
mako1 is offline
Old 10-11-2014, 05:23 PM   #5
Tom M's Avatar
Rewards Points: 12,706
Moisture is supposed to stay in the inside in cold climates. Your Area is neutra , I think. What kind of heat?
Tom M is online now
Old 10-11-2014, 05:24 PM   #6
Plumber / Carpenter
Bill's Avatar
Roof has gable end vents, though I prefer ridge vents myself.
Yes she had new windows installed just before the siding was installed. Pella replacement windows
She runs AC
Bill is offline
Old 10-11-2014, 05:25 PM   #7
Plumber / Carpenter
Bill's Avatar
AC / heat pump
Bill is offline
Old 10-11-2014, 05:53 PM   #8
Tom M's Avatar
Is the house on a slab? The dehumidifier idea sounds solid.
Tom M is online now
Old 10-11-2014, 05:57 PM   #9
mako1's Avatar
She runs AC
Is the soffit vented ?Gable end or ridge vents take air out.You need some place to bring air in that is being removed.Such as vented soffits and ridge vents.Your roof acts just like a chimney.Almost.
Sounds like there is a lot of moisture staying in the house with no way to get out.A de humidifier would help but IMO the best thing to do is fix the house.
It was not the foil backed foam causing this problem.All you did was add a little insulation.
mako1 is offline
The Following User Says Thank You to mako1 For This Useful Post:
Old 10-11-2014, 06:16 PM   #10
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 824
It's not complicated.
Air exchanger and dehumidifier.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 10-11-2014, 07:26 PM   #11
hdavis's Avatar
Rewards Points: 7,424
With the new insulation, the AC is now oversized for the load, so it's short cycling and NOT getting humidity out of the air...
hdavis is offline
concretemasonry (10-11-2014), Fouthgeneration (10-12-2014)
Old 10-11-2014, 10:01 PM   #12
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
What humidity levels are you looking at?
I have a hygrometer in the basement and on the main floor and I'm looking at 69 degrees temperature and 50% humidity now. As winter comes, I'll start running the humidifier on the furnace and I'll aim for 50%. I can make it rain inside if I want. The windows will start to condensate and the ceiling as well.
I know a guy who had water dripping down the underside of his roof and into the soffit, where it continued down against the side of the house.
Anyway, I deal in facts. What is the humidity level in the home?
cleveman is offline
Old 10-12-2014, 06:00 AM   #13
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 7,925
Check out every opening for proper rain cap installations....
How did they add foam and not retrim the windows/doors?
gutters rehung/working. shower vented/run, kitchen vent/used?
foam could be causing vapour to condense on wrong side of vapor barrier(s), house could have Two vapor barriers now from faulty install of siding/foaam.........
Fouthgeneration is online now
Old 10-12-2014, 10:44 AM   #14
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
how does 2 vapor barriers constitute ''faulty install of siding/foam''?
Tom Struble is offline
Red Adobe (10-16-2014)
Old 10-12-2014, 11:32 AM   #15
LRG WoodCrafting
Leo G's Avatar
Because 2 vapor barriers trap the moisture between them. And that will lead to all kinds of moisture problems.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 10-12-2014, 02:24 PM   #16
Trade: siding
Rewards Points: 20
well...a yea,but that is not a faulty installation,and can reduce condensation in the wall cavity
Old 10-12-2014, 04:07 PM   #17
Trade: Masonry
You need a little remedial building science.
Entropy increases--ALWAYS.
Heat flows to cold, Moisture is literally sucked to dryer spaces.
Creating walls that has many types of materials in random order can lead to moisture condensing out inside the "rain wall" of the building.
Would you want areas of stagnant moisture/water slowly leaking into your living spaces?-- storing water between two layers of Vapour barrier, under many conditions the vapour passes the original barrier, then condenses INSIDE the new impervious to liquid water Vapour barrier..... Oooops.
If you wear Gore Tex boots inside of waterproof galoshes, the moisture will collect in the rubbers from cooling off, and be trapped.
Old 10-12-2014, 05:27 PM   #18
Trade: siding
Rewards Points: 20
keeping the sheathing warmer increases condensation how?You don't even know what type of foam or if there is actually 2 vapor barriers..
you need some remedial question asking
Old 10-12-2014, 06:01 PM   #19
stacker of sticks
Rewards Points: 590
Originally Posted by Tom Struble
keeping the sheathing warmer increases condensation how?You don't even know what type of foam or if there is actually 2 vapor barriers.. you need some remedial question asking
No he's 4th gen. He knows exactly what's going on in every situation before the question is asked.
The Following User Says Thank You to jlsconstruction For This Useful Post:
Fouthgeneration (10-13-2014)
Old 10-12-2014, 06:02 PM   #20
Trade: siding
Rewards Points: 20
ah..
Fouthgeneration (12-31-2014)
Removing wet insulation Tom Richards Insulation 8 12-16-2012 08:44 PM
Should you pay more for a quality insulation job? ecworks Insulation 8 12-10-2012 10:02 PM
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 08:57 PM
