Screwing Aluminum Trim To Window. - Windows, Siding and Doors - Contractor Talk
Old 06-29-2008, 08:42 PM   #1
Patrick's Avatar
Rewards Points: 2,364
We are constantly evolving our trim system, to make it look as clean as possible. We are currently experimenting, with the following, instead of nailing through the side of our aluminum trim into the old wood trim, bending a 5/8" - 3/4" flange that comes over the face of the replacement window. We would apply a bead of silicone on the face of with window, our "flange" would then be pushed into the caulking, and we will then use small white screws to screw the trim into the window, rather than the wood trim.
Ill take some pics, we have experimented a few times and it looks very neat. Hides the caulking, and if you mess up its easier to remove a screw than a nail.
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 06-29-2008, 09:09 PM   #2
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
Re: Screwing Aluminum Trim To Window.
I agree that it would look cleaner but wouldnt you see the head of the screw? If so the the head of the screw may collect/hold contaminates making them look even bolder. The screw would have to have a flat head too or it will dimple the metal. Just my opinion.
woodchuck2 is offline
Old 06-29-2008, 09:15 PM   #3
Patrick's Avatar
We have been using the really tiny screws that are provided with the windows for holding on the head expanders, which we discard anyways. The flange is bent at about 100 degrees rather than 90, so that it hugs the window, and the screw is set just enough, so there is no ripple effect.
We bend a special J channel for our siding, and our trim snaps onto the J channel. by screwing to the window, it is saving use from having to be super detailed about bumping out our trim exactly perfect.
Patrick is offline
Old 06-29-2008, 10:00 PM   #4
Rewards Points: 2,000
I appreciate how fussy you are about
your install technique and finished product.
So I'm wondering if you are taking into
consideration that the screws will
corrode if they aren't aluminum or
stainless?
neolitic is offline
Old 06-29-2008, 10:13 PM   #5
Patrick's Avatar
stainless?
Non magnetic stainless. We are getting away from rivits, as the hole in the center sticks out too much. The screws Looks better than a rivet, and the paint holds better than a trim nail. Last week we experimented, and made the reveal between our trim and the siding 1-1/4 instead of the 3/4 we normally do, and it looked really sharp, and the neighbors and customer loved it. I will get some pics up. My final goal will be to get our trim snap so tight that ZERO fasteners will be needed. We are getting very close to that point
Patrick is offline
Old 06-29-2008, 10:20 PM   #6
I admire your dedication to detail.
neolitic is offline
Old 06-29-2008, 10:24 PM   #7
Professional Instigator
rbsremodeling's Avatar
I use titanium kryptonite screws on my window trim those seem to work well but it raises the price per window to 14mil per window
rbsremodeling is offline
Old 06-29-2008, 10:35 PM   #8
Patrick's Avatar
is that for the window and trim, or just for the trim?
Patrick is offline
Old 06-29-2008, 10:40 PM   #9
Trim only baby, the window is $189 installed
Old 06-29-2008, 10:42 PM   #10
Patrick's Avatar
Makes sense, I usually tell people our trim is the best part of having us install their windows
Patrick is offline
Old 06-29-2008, 10:47 PM   #11
Yep we usually install a window for 189, trim is 300 bucks. Unless we use the krypton screws
Old 06-29-2008, 11:55 PM   #12
grob62's Avatar
Trade: Windows and Doors
Rewards Points: 75
I'm really looking forward to seeing pics of your method, Patrick. No visible fasteners is something I try to achieve, but doesn't always happen. On one such occasion after wrapping a patio door without using any nails and caulking it in place with a nice straight bead of Quad, the homeowner asked me why there was no nails. You see the last installer who did the other patio door used nails to fasten their aluminum... SIGH.. Sometimes you can't win.
grob62 is offline
Old 07-01-2008, 06:54 PM   #13
W-Tinc's Avatar
Trade: Student
Rewards Points: 250
That is a neat idea, especially the idea of no caulk showing.
If the window has an accessory groove you can use a pea shooter and nail the metal into the groove and tap it in with a small flat bar, a small bead of caulk will cover the nail head nicely and be barely noticable.
Another thing I have tried is to use glazing tape and bend the flange opposite of how you are doing it now and basically stick the flange to the tape, looks pretty clean if you use a nice thin tape.
W-Tinc is offline
Old 07-01-2008, 08:23 PM   #14
Patrick's Avatar
I will try to get some pictures up tomorrow. Very Clean look, the guys love it, we are also installing a lot faster too. It also makes it very easy to adjust for out of whack windows and walls as you just stretch the trim to where it needs to be and screw it.
Patrick is offline
Old 07-01-2008, 08:51 PM   #15
j_builder's Avatar
Trade: Specializing in residential remodeling
Rewards Points: 250
Sounds to me to be well thought out way for detailing the window trim. I'm looking forward to seeing some pic's of your work Patrick. I know that you use either stainless steel/titanium kryptonite screws so I was just wondering if you could add a plastic snap cap onto the screw head? Just throwing out an idea of course. http://www.pro-dec.com/
j_builder is offline
Old 07-01-2008, 09:07 PM   #16
Patrick's Avatar
They really blend in, the key is to try to put the screws in the same place on every window. We are using phillips head zip screws because I found the hex head ones get torn up by the socket bit. Now I just need to find a source for buying these in bulk quantities
Patrick is offline
Old 07-01-2008, 09:22 PM   #17
Handyman Jim's Avatar
Trade: Handyman,Doors,Carpentry
Rewards Points: 150
I'm not sure if they carry the type of screw that you use ,but you can try http://www.boltdepot.com
Handyman Jim is offline
Old 07-01-2008, 09:46 PM   #18
Patrick's Avatar
Yes they do, thanks for the link, Im on a virtual shopping trip there right now
Patrick is offline
Old 07-02-2008, 04:26 PM   #19
Siding Windows Doors
easy sider's Avatar
Trade: Exteriors
Rewards Points: 250
Screws on the exterior frame not installed by the manufacturer some times voids the waranty. On 60% of the houses we do we buy the J chanel trim installed by the window manufacturer.
easy sider is offline
Old 07-02-2008, 05:45 PM   #20
Sophisticated Siding Guy.
thesidingpro's Avatar
Trade: Roofing, Siding, Windows, Decks, and more!
Rewards Points: 164
That's one hell of a statistic.
Here's how I like to do it.
http://thecontractorsclub.com/album_...DESC&user_id=2
I hate inserts. I'll do them but try to stay away from window work. It's a blood bath around here.
thesidingpro is offline
Replacement Window Question? Max10 Windows, Siding and Doors 41 11-03-2013 12:01 PM
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Exterior Window and Door Trim MikeNeufeld Carpentry 5 10-30-2007 01:57 PM
Proposals...... AAPaint Painting & Finish Work 3 08-25-2007 08:47 AM
trim coil window stops ,casing, quad caulk for sale ..closing shop window man Contractor Swap 7 07-05-2006 08:46 PM
