Rigid Insulation - Windows, Siding and Doors - Contractor Talk
Rigid Insulation
Old 03-20-2019, 10:17 PM   #1
nickelec's Avatar
Trade: professional licensed electrician
Rewards Points: 390
Rigid Insulation
I have a question in regards to rigid insulation, in my basement I plan to mount three quarter plywood on to instruct bolted to my cinder block foundation does anybody see a potential problem with sandwiching 2in XPS rigid insulation behind the plywood to have some sort of a r value in my Electrical room.
Sent from my SM-G965U using Tapatalk
nickelec is offline
Old 03-21-2019, 06:44 AM   #2
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 110
Re: Rigid Insulation
Nope as long as drainage, waterproofing, etc... is all good
SLSTech is offline
The Following User Says Thank You to SLSTech For This Useful Post:
HomeSealed (03-26-2019)
Old 03-21-2019, 07:11 AM   #3
nickelec's Avatar
Rewards Points: 390
I ment mount the plywood on strurt. On the interior
nickelec is offline
Old 03-21-2019, 07:30 AM   #4
Sean
SLSTech's Avatar
Rewards Points: 110
I know what you meant though you probably don't have to use a strut & could bolt directly through the foam into the concrete if you wanted but most feel better about either using a strut or 2x stock mounted to concrete & filled in with foam panels in between
SLSTech is offline
Old 03-21-2019, 07:30 AM   #5
hdavis's Avatar
Rewards Points: 2,940
It should be no problem.
hdavis is online now
Old 03-21-2019, 07:38 AM   #6
nickelec's Avatar
Rewards Points: 390
I was asking in regards to possible moisture build up behind the foam but all the research I found says I should be good
nickelec is offline
Old 03-21-2019, 08:40 AM   #7
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,202
I have before used 2" ridge foam board, blue stuff, then stud frame work on top of that. Personally I feel it was better then cutting the foam to fit stud bays and it gave a nice area to run electrical and any plumbing in.
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
hdavis (03-21-2019)
Old 03-21-2019, 04:06 PM   #8
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 8,249
Blue, Pink and yellow boards are great insulator products....
But a tiny piece smoldering INSIDE you home WILL kill you and your loved ones Dead.
Go with inflammable Rock wool, use fire treated plywood around all panels or paperless gyp board products....
Use the polystyrene OUT-side the envelope.
Don't forget to reinstall the panel ground to the ground rod...........
Fouthgeneration is offline
adding rigid insulation to outside of house randynh General Discussion 14 11-17-2011 05:55 AM
Rigid Foam Insulation mpt1123 Insulation 3 02-04-2011 09:04 AM
rigid insulation wdlanger Decks & Fencing 2 06-24-2010 07:06 PM
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 08:57 PM
