Repairing / Replacing Cement Siding - Windows, Siding and Doors - Contractor Talk
Old 09-28-2014, 01:33 PM   #1
tcleve4911's Avatar
Trade: Remodeling contractor
Rewards Points: 1,008
Hi guys
I've been away for a while but you all look happy and healthy.
I have a project installing a couple of windows into a bare wall covered with cement siding. I've worked with it a little but mostly I install wood siding.
I have to remove enough siding to open the wall, frame my new openings and then reinstall new siding.
I'm sure I can get the siding off but when reinstalling the new siding it leaves the last course with a face nail. Is that how you guys leave it?
I'm using ring shank St Steel nails in my siding gun.
Any tips and tricks on this stuff are greatly appreciated.
....and I hate cutting too...(cough)
Thanks for any help
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 09-28-2014, 03:08 PM   #2
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
Re: Repairing / Replacing Cement Siding
yes you will have to face nail. it is ok by the manufacturers.
Treat it just like you wood wood siding.
Framer53 is offline
Old 09-28-2014, 07:23 PM   #3
Allcity1's Avatar
Trade: Roofing and siding
Rewards Points: 60
Face nail 16 ga. Trim nail. Why remove the siding?
Allcity1 is offline
Old 09-28-2014, 07:34 PM   #4
tcleve4911's Avatar
To: All City
I'm removing 100 sf of the existing cement board siding in order to open the wall, frame the opening and install two windows.
Do you have some secret method that excludes removing the siding that the forum should be made aware of ?
Back in Maine
Dubbin' Around
Old 09-28-2014, 07:42 PM   #5
Allcity1's Avatar
Rewards Points: 60
Originally Posted by tcleve4911
To: All City I'm removing 100 sf of the existing cement board siding in order to open the wall, frame the opening and install two windows. Do you have some secret method that excludes removing the siding that the forum should be made aware of ?
It may not be possible with your project but have you considered opening the wall from the inside?
Allcity1 is offline
Old 09-30-2014, 08:07 AM   #6
tccoggs's Avatar
Rewards Points: 874
If the existing siding is blind nailed, pactool makes a nail cutter than can reach behind the board and cut the nails so you can remove them without damage. From there you would have to face nail to reinstall. I don't think I would rely on a 16ga finish nail to hold. Would rather use stainless siding nails, set them flush and touch up with paint. No guns, hand nail.
tccoggs is offline
Old 10-04-2014, 04:20 PM   #7
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
you could put up some trim to cover the nails..obviously..
Tom Struble is offline
Old 10-04-2014, 04:47 PM   #8
JAH's Avatar
Trade: carpenter
Rewards Points: 1,910
Originally Posted by tcleve4911 View Post
To: All City
Ive done it a few times, pretty straight forward.
From the interior, gut the wall, frame ro and cut out sheathing+siding. Mark out exterior of ro for the unit size plus flanges. At this point if I'm confident Ill figure in the trim and cut back the siding, install window and trim.
If its not going well Ill remove just enough siding to install the window, install the unit then scribe trim on the siding and cut.
JAH is offline
fiber cement lap siding size somerbuilder Windows, Siding and Doors 13 03-30-2014 02:11 AM
individual corners for cement board siding mike gunderson Windows, Siding and Doors 10 05-03-2013 03:37 PM
need some wood siding advice Spike7 Windows, Siding and Doors 47 06-28-2012 10:27 PM
Vinyl and Fiber cement siding questions Bond111 Windows, Siding and Doors 2 06-18-2010 04:03 PM
replacing damaged aluminum siding toolguyny General Discussion 8 01-10-2010 10:22 AM
