Pvc Trim - Windows, Siding and Doors - Contractor Talk
Pvc Trim
Old 05-04-2014, 06:55 PM   #1
Tylerwalker32's Avatar
Trade: General contractor
Rewards Points: 1,844
Pvc Trim
Looking at doing a project here shortly what involves making radius trim out of PVC, I can't get sheet at my supplier, so I figured is edge glue a couple boards to get the size I need and cut the radius out of that. What the best was to edge clue PVC?
Tylerwalker32 is offline
Old 05-04-2014, 06:59 PM   #2
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 335
Re: Pvc Trim
Pvc glue or for longer working time, get the Azek glue. You can also cut the radius moldings out of 3/4" sheet pvc and not have a joint at the radius.
Easy Gibson
Warren is offline
Old 05-04-2014, 06:59 PM   #3
slowsol's Avatar
Rewards Points: 2,248
Re: Pvc Trim
Call you lumber yard and get a local rep's name. We have had them come out on site bend a radius or two for us. They use heating blankets.
-John
slowsol is offline
Old 05-04-2014, 07:03 PM   #4
Geometrist
Warren's Avatar
Rewards Points: 335
Re: Pvc Trim
Here is one that I did a few months ago.
Easy Gibson
Warren is offline
The Following 3 Users Say Thank You to Warren For This Useful Post:
CENTERLINE MV (05-06-2014), overanalyze (05-04-2014), Tom Struble (05-04-2014)
Old 05-04-2014, 07:05 PM   #5
jb4211's Avatar
Rewards Points: 2,306
Re: Pvc Trim
If you glue them and cut the radius all off the joints will show. I think bending its the easy to go. I've never done it, but saw a few videos on You Tube.
If not that, can you special order from supplier based on a template?
Jon
jb4211 is offline
Old 05-04-2014, 07:14 PM   #6
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 704
Re: Pvc Trim
Heat it, Bend it. Have you ever priced full sheets? Eek! Also a ton of waste that way. I have done both ways and the heat forming was easy. Just a small side note, the wood grain tends to flatten out a bit with the heating process.
overanalyze is offline
The Following 5 Users Say Thank You to overanalyze For This Useful Post:
CENTERLINE MV (05-06-2014), ChimneyHill (05-06-2014), superseal (05-05-2014), TBFGhost (05-08-2014), Tom Struble (05-04-2014)
Old 05-04-2014, 08:46 PM   #7
Working
Cole82's Avatar
Rewards Points: 2,276
Re: Pvc Trim
Heat up Azek to 212F and bend it. Overanalyze has it set up perfect. Another reason to do it this way is so the edges remain sealed. If you cut it out of sheet the open cell is exposed and dirt collects there.
Cole
The boss of awesome
Cole82 is offline
The Following 2 Users Say Thank You to Cole82 For This Useful Post:
Old 05-04-2014, 09:53 PM   #8
Re: Pvc Trim
I would love to bend it I feel like it would be cheaper and easier. What's that setup with the heater you are using?
Old 05-04-2014, 10:13 PM   #9
Aframe's Avatar
Trade: Carpenter/GC
Rewards Points: 550
Re: Pvc Trim
Attachment 111951
Is the left end of duct work left open for air flow or capped?
Aframe is offline
Old 05-04-2014, 10:14 PM   #10
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 306
Re: Pvc Trim
He explains it on post #8
http://www.contractortalk.com/f33/cu...ndants-146576/
Xtrememtnbiker is offline
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
overanalyze (05-05-2014)
Old 05-05-2014, 06:06 AM   #11
Working
Cole82's Avatar
Re: Pvc Trim
Originally Posted by Xtrememtnbiker View Post
HE says 280-290F but at that temp the end swill burn as he said in that post. Azek says it's malleable at 212 and when cooled will remain in that shape. Higher temps are just wasting money on fuel and time on heat.
Another way is to boil the azek in a trough this make sure there is no hot spots and no burnt ends.
Cole
The boss of awesome
Cole82 is offline
The Following User Says Thank You to Cole82 For This Useful Post:
Xtrememtnbiker (05-05-2014)
Old 05-05-2014, 07:16 AM   #12
Always Learning
Rewards Points: 704
Re: Pvc Trim
Cole
Yep..the one end did burn. That was the temp recommended by Kleer PVC. It was fine because we added for waste to our material being bent. I will say there seems to be a sweet spot that makes it workable but not burnt.
The Following 2 Users Say Thank You to overanalyze For This Useful Post:
Cole82 (05-05-2014), Tom Struble (05-06-2014)
Old 05-05-2014, 07:38 AM   #13
Working
Cole82's Avatar
Re: Pvc Trim
I have never used kleer and wasn't sure off the brand you were using that's why I specifically said azek because those are the specs I know.
Good job btw looks great.
The boss of awesome
Cole82 is offline
overanalyze (05-05-2014), Tom Struble (05-06-2014)
Old 05-06-2014, 07:06 PM   #14
Sophisticated Siding Guy.
thesidingpro's Avatar
Trade: Roofing, Siding, Windows, Decks, and more!
Rewards Points: 164
Re: Pvc Trim
I've bent a bunch of PVC myself and I 100% agree there is a sweet spot. Slow in low is my best advice to give. Plan on the end burning a little so make sure you have extra to cut off.
I love your setup overanylze. I'll be building something similar next time I have a job to bend. I just used sonotubes and some rebar. Works fine and stores nicely.
http://thecontractorsclub.com/galler...p-pvc-oven-dp1
Here is some flower boxes I made. I had a couple hundred to make:
http://thecontractorsclub.com/galler...o-flower-boxes
Here is some sheet goods I bent for another project.
http://thecontractorsclub.com/galler...vc-sheet-goods
thesidingpro is offline
The Following 3 Users Say Thank You to thesidingpro For This Useful Post:
Cole82 (05-07-2014), Tom M (05-10-2014), Tom Struble (05-06-2014)
Old 05-06-2014, 07:13 PM   #15
Always Learning
Rewards Points: 704
Re: Pvc Trim
Those are some nice looking projects! The sonatube is a good idea. The reason we did the metal was it was a flat bottom and in 5' sections, also so it stores nice.
Old 05-06-2014, 09:17 PM   #16
Joseph A. Capece
CENTERLINE MV's Avatar
Trade: Builder - General
Rewards Points: 1,432
Re: Pvc Trim
http://www.heatcon.com/industrial/heat-forming-kits
Follow us on FACEBOOK
www.centerlinebuilders.net
Martha's Vineyard General Contractors - Builders -
Commercial/Residential - Additions - Renovations
CENTERLINE MV is offline
Old 05-06-2014, 09:20 PM   #17
EricBrancard's Avatar
Trade: Builder/Renovator
Rewards Points: 740
Re: Pvc Trim
Originally Posted by CENTERLINE MV View Post
That's what we use. And when I say "we" I mean my dad bought one years back and when I need to bend PVC, I snag it.
EricBrancard is online now
Old 05-06-2014, 10:49 PM   #18
Always Learning
Rewards Points: 704
Re: Pvc Trim
Yeah I looked at those...eek! Pricey. If we did pvc bending a lot, I could see it, but not for the couple times a year we might do it. You definitely get more even controlled heat with those.
Old 05-10-2014, 08:30 PM   #19
Re: Pvc Trim
We'll I've been trying to get it heated up using a torpedo heater I max out around 190, and it not very even heat, I guess I can't it hot enough. Trying to figure out what I'm going to do to get this stuff bent.
Old 05-10-2014, 08:39 PM   #20
Rewards Points: 740
Re: Pvc Trim
Try this:
Looking for a fresh idea to trim out entry door AustinDB Finish Carpentry 17 02-01-2013 03:12 AM
how should I trim out the window siding?? lewisthepilgrim Windows, Siding and Doors 24 12-02-2012 11:46 AM
Paslode Angle Trim Nailer Problem. MF Custom Tools & Equipment 3 07-16-2012 10:19 PM
Old trim clashing with new, best course of action? saynever Painting & Finish Work 2 01-13-2010 03:33 AM
Proposals...... AAPaint Painting & Finish Work 3 08-25-2007 08:47 AM
