Patching Early Generation PVC/ Foam Exterior Door Trim - Windows, Siding and Doors - Contractor Talk
Old 06-18-2019, 04:19 AM   #1
zmusashi's Avatar
Trade: carpentry, remodeling
Rewards Points: 47
I replaced an entry door with sidelites, and pulled off the fluted trim casings and crown/header detail, found they were some kind of yellow foam/ plastic. they pulled right off, in most cases right through the siding nail heads. Client would like to put them back on- and they're in pretty good shape. Does anyone know what'd be best to fill these nail holes with? New PVC trim would be $400 for wide fluted casings and small top shelf alone. I am building a new PVC header with crown. Thanks for any advice. The old stuff is like a hard-packed styrofoam that you can break fairly easily. They think it's early 90's.
Patching early generation PVC/ foam exterior door trim-img_0090.jpg
zmusashi is offline
Old 06-18-2019, 06:37 AM   #2
rrk's Avatar
Rewards Points: 1,650
Re: Patching Early Generation PVC/ Foam Exterior Door Trim
Its called Fypon was very popular and widely used
Usually glued on and held in place with a few brads
rrk is offline
zmusashi (06-19-2019)
Old 06-18-2019, 08:11 AM   #3
washingraccoons's Avatar
Trade: Painting, Post-Contruction Window Cleaning
Rewards Points: 16
This is Fypon
Washing Raccoons - Window Cleaning, Pressure Washing, Painting, Rope Access in Los Angeles
washingraccoons is offline
The Following User Says Thank You to washingraccoons For This Useful Post:
zmusashi (06-21-2019)
Old 06-28-2019, 10:13 AM   #4
rblakes1's Avatar
Rewards Points: 3,150
You could make your own fluted molding out of pvc. I did that on an install earlier this year to replace the wood that was there
-Rich
rblakes1 is online now
