Need 2" More Clear Opening Between 5'0 Bifold Doors - Windows, Siding and Doors - Contractor Talk
Thread Tools
Old 05-21-2015, 08:59 AM
diplomat
Golden view's Avatar
Rewards Points: 710
In a project a recently finished, I have a laundry closet tucked under the sloped roof as drawn. Now with the washer and dryer installed, the door or one of the machines can't open 90 degrees. I need 2" more free opening width.
We've eliminated these options:
slider
french door
curtain
changing hinging on W/D.
Is there any fancy hardware or hinge that would let me open the bifold a little more? The hinge pin and roller thing at the top cause there to be a little wasted space when it's open. Any other type of door I'm not thinking of?
Expensive undesirable options are adding to the 2'9 dimension or buying a different brand new set. The roof of the closet slopes at 12:12 so there is 10" of space above the units at the current back of the closet.
Golden view is online now
Old 05-21-2015, 09:02 AM
diplomat
Rewards Points: 710
Re: Need 2" More Clear Opening Between 5'0 Bifold Doors
Maybe answered my own question: How about a piano hinge or regular matching door hinge at the jamb and remove the pivot pins? Keep the roller at the top for a guide. That might gain enough.
Old 05-21-2015, 09:15 AM
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 17,025
How about widening the opening and using the same doors with a trim piece attached to the center door edges?
MarkJames is offline
Old 05-21-2015, 09:22 AM
diplomat
Rewards Points: 710
Maybe. I didn't think about that as a way to widen the opening without getting custom doors. Widening is not easy, the opening is shoehorned in as it is. But I can replace the jack studs with angle brackets I suppose.
Old 05-21-2015, 10:43 AM
Railman's Avatar
Trade: Railing
Rewards Points: 911
Just do a double hinge door. Basically it's a bifold using std door hinges at the fold and wall. They don't use a top, or bottom track. The door will fold back tight to itself, out of the way. The trick might be your rough opening, or cutting down doors to accommodate a jamb opening.
Joe
Railman is offline
The Following User Says Thank You to Railman For This Useful Post:
Tom M (05-22-2015)
Old 05-22-2015, 06:13 AM
Tech Geek
WarriorWithWood's Avatar
Trade: Remodeling Guru
Rewards Points: 1,366
Joe
I was thinking the same..double door standard hinges and ball catches.
-Dennis
WarriorWithWood is offline
Old 05-22-2015, 06:39 AM
tjbnwi's Avatar
Rewards Points: 1,822
I think the dual swing doors is what he is calling a french door.
Double doors would be the answer.
Seeing as it is not on the list------remove doors completely.
tjbnwi is online now
Old 05-22-2015, 07:18 AM
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
I think this might be it...
Setting the gap would be kinda tricky
-Steve
TimelessQuality is offline
Old 05-22-2015, 09:48 AM
diplomat
Rewards Points: 710
Joe
What keeps them from swinging wild without a track to guide? I'd like them to open with the action of a bifold door.
Maybe this isn't critical.
Old 05-22-2015, 02:51 PM
ACWindows's Avatar
Trade: Windows & Doors
Rewards Points: 18
I agree with the suggestion of a double hinge door.
American Choice Windows & Doors
ACWindows is offline
Old 05-22-2015, 05:02 PM
Tom M's Avatar
Rewards Points: 8,142
I like Railmans idea. Maybe you could use a ball and catch still to hold it at the top and maybe a foot lock on one?
Another thought, how about 3/4" doors on piano hinges that collapse tighter.
Tom M is online now
Thread Tools
Rate This Thread
Best method to paint new wood pre-hung doors BElliottP Painting & Finish Work 7 12-17-2013 06:36 AM
Audio Cabinets - Doors blackte Finish Carpentry 18 11-21-2013 07:13 PM
Mortar in Fireplace doors 6stringmason Masonry 8 07-12-2012 08:23 PM
clear pine for cabinet doors neill Finish Carpentry 8 02-25-2012 09:19 PM
24" exterior doors - where to buy? Panzer5 Carpentry 11 05-07-2009 07:43 AM
